Продава се: Cisco Linksys WRP400 Wireless router with 2 VoIP phone ports
Цена: 99 лв.
Регион: София
за контакт: e-mail: tekkno@mail.bg
Снимки на продукта:
[img width=570 height=600]http://www.1-voip.com/residential/assets/img/wrp400.jpg[/img]
Друга информация: Продава се с всички прилежащи аксесоари в оригиналната кутия
Спецификации:
Hardware
• One 10/100 802.3/u (RJ-45) WAN interface
• Four 10/100 802.3/u (RJ-45) LAN interfaces
• Integrated 802.11b/g wireless access point
• Two FXS RJ-11 interfaces
• One USB 2.0 port (support for Mobile Broadband Modem** - available separately)
• Reset button/restore factory defaults
• LEDs: Power, Internet, Ethernet, Wireless, Phone(s), WPS
• Power: external, 5V DC, 2A (full range switching power adapter)
• Wi-Fi Protected Setup (WPS) button
Software
• Static and dynamic routing (Routing Information Protocol [RIP] 1, RIP 2)
• Auto failover and recovery of Ethernet WAN connection enabled with USB Mobile Broadband Modem**
• Multicast pass-through
• Denial-of-service (DoS) prevention
• Web based configuration
• VPN pass-through with IP Security (IPsec), Layer 2 Tunnelling Protocol (L2TP), and Point-to-Point Tunneling Protocol (PPTP)
• Event logging
• Dynamic Host Configuration Protocol (DHCP) server
• Access control lists
• Universal Plug and Play (UPnP)
• Password-protected configuration or management sessions for web access
• Remote management (Session Initiation Protocol [SIP] SUBSCRIBE and NOTIFY message; use NOTIFY message to reset the box remotely) and remote web management
• Internet Group Management Protocol (IGMP) multicast and IGMP snooping (versions 1, 2, and 3) support
• 802.1p prioritization QoS support
• Differentiated Services (DiffServ), type of service (ToS) classification
• Network edge (DMZ) hosting
• Wi-Fi Protected Access (WPA) and WPA2
• Wi-Fi Multimedia (WMM)
• Dual service set identifiers (SSIDs)
Voice
• SIP v2, RFC 3216
• Sending SIP messages via User Datagram Protocol (UDP)/TCP
• G.711a, G.711u, G.729, G.726 codecs
• G.711 pass-through
• Echo cancellation (G.167 and G.168)
• Dynamic jitter buffer
• Simple traversal of UDP through Network Address Translation (NAT) (Serial Tunnel [STUN], RFC 3489)
• Session Description Protocol (SDP), RFC 2327
• Real Time Protocol (RTP)/Real Time Control Protocol (RTCP) over UDP
• Three-way conferencing
• Remote firmware upgrade
• Dual-tone multifrequency (DTMF) tone detection and generation
• Voice activity detection (VAD)
• Silence suppression
• Comfort noise generation (CNG)
• Caller ID generation and detecting (frequency shift keying [FSK] and DTMF)
• Media loopback
• SIP Transport Layer Security (TLS)
• SIP channels support both UDP and TCP transport
• Support for 2 simultaneous T.38 or G.729 calls
• T.38 fax relay, including V.17, V.21, V.27ter, and V.29 and fax pass-through (pulse code modulation [PCM})
• T.38 support is dependent on fax machine and network/transport resilience*
Voice features
• Voice algorithms
• G.711 (a-law and µ-law)
• G.726 (16/24/32/40 kbps)
• G.729 AB
• G.723.1 (6.3 kbps, 5.3 kbps)
• Call forwarding: no answer/busy/unconditional
• Support for 2 simultaneous calls
• SIP TLS
• Call transfer
• Call waiting/hold/retrieve
• Call ID number and name (primary line and on call waiting)
• Call ID block (prevents sending out the caller ID)
• Anonymous call blocking
• Distinctive ringing
• Do not disturb setting
• Repeat dialing on busy
• Call return
• Emergency call support
• Dial plan
• Speed dial
• Auto-attendant
• Multiroom meet-me conference
• In-band/SIP-INFO DTMF translation
Provisioning, administration, and maintenance
• Web browser administration and configuration via integral web server
• Telephone keypad configuration with interactive voice prompts
• Automated provisioning and upgrade via HTTP, TFTP, HTTPS
• Asynchronous notification of upgrade availability via NOTIFY
• Nonintrusive in-service upgrades
• Report generation and event logging
• Stats in BYE message
• Syslog and debug server records
• Per line and purpose configurable syslog and debug options
Physical interfaces
• Four 100BASE-T RJ-45 Ethernet ports (IEEE 802.3)
• Two RJ-11 FXS phone ports-for analog circuit telephone devices
Сайт на производителя и пълни спецификации: http://www.cisco.com/en/US/prod/coll...78-502141.html
