Nakamichi PA-4100 4 канален усилвател. Нов! Само е тестван дали работи 5 мин максимум.
Технически характеристики:
MOSFET Power Supply - Increase The Amplifier's Ability To Respond To Music Peaks Quickly And Efficiently, With Excellent Sound Quality
Stereo & Bridges Mode Application
Continuous Phase Control (0 - 180 deg)
Terminal Layout At Bottom Of Amplifier
4 Way Protection : Output Short, DC Offset, Thermal & Battery > 18 V
Dual LED Indicators (Power & Protect)
Double Power Output When Using A 2 ohms Speaker
Aluminium PCB For All Transistors - Provide Consistent Thermal Stability
Gold-Plated Power And Speaker Connectors
Power Output RMS @ 4 ohms: 100 W x 4
Power Output RMS @ 2 ohms: 200 W x 4
Bridged Output RMS @ 4 ohms: 350 W x 2
Frequency Response: 20 Hz - 20,000 Hz
Crossover (Butterworth): HP 15 - 400 Hz LP 40 - 400 Hz
Bass EQ @ 45 Hz: 0 - 12 dB
S/N Ratio: >90 dB
Total Harmonic Distortion: <0.05%
Dimensions: 535 (W) x 63 (H) x 268 (D) mm 21.06 (W) x 2.48 (H) x 10.55 (D) inches # Weight: 6.61 kg / 14.57 lbs
Реални снимки на усилвателя:
Цена: 550 лева
Намира се в гр. Поморие. Не е проблем да се прати по куриер стига купувача да е сериозен.
За връзка лс. тук във форума или 0886696365 - Иван
