Zdraveite opitvam se da namerq kod za razkodirvane na LG-KU990 kodiran ot ORANGE Franciq ne sam zapoznat kade da tarsq zatova molq vseki koito moje da mi pomogne IMEI:353638-02-444338-4
SUPPORTED MODELS:
KU800 2007 VERSIONS !!!/U990/KU990/KU380/CU400/CU405/CU500/CU500V/CU320/TU500/TU550/MU500/MU550
1. DOWNLOAD LGMDP AND MAKE BACKUP OF NV (USE WINDOWS ENABLE SOFT TO SELECT NV BACKUP ONLY AND ENABLE START AFTER THAT YOU CAN GET FROM HERE
http://www.filestube.com/3e140ab4b1b6bd8603e9/go.html ( archive pass: www.52lg.com )
2. DOWNLOAD MTTY FROM
https://forum.setcombg.com/******************.com/files/96122802/mtty.exe.html
3. OPEN MTTY AND SELECT PORT ON WHICH MODEM USB PORT OF PHONE IS ASSIGNED
4. AFTER WINDOW OPENS TYPE 'AT%SWV' (WITHOUT QUOTES) AND PRESS ENTER. IF YOU GET REPLY ALL IS OK
4. TYPE 'AT%IDDE' (WITHOUT QUOTES) AND PRESS ENTER. IF YOU GET IDDE OK MEAN PHONE SUCCESFULLY UNLOCK
5. DON'T POWER OFF PHONE. USE LGMDP TO RESTORE NV.
6. ENJOY A SUCCESSFULLY UNLOCK PHONE.
P.S: CAN AFTER 'AT%IMEI=WANTED IMEI' TO CHANGE IMEI
THIS SOLUTION WONT WORK ON KU580 SEMC A2 PLATFORM, KS20, KU730, KU950 AND PROBABLY KU250 ASWELL. AND BIG LOLO TO PEOPLE WITHOUT BRAIN HUNGRY AFTER THX AFTER A FIRST IN WORLD UPDATE. YOU PISS ON MY TIME AND MONEY AND ILL PISS ON YOU OVER AND OVER FROM NOW ON.
LGMDP AVAILABLE HERE :
This is LGMDP 1.5 Build 12.10 Program.
- LGMDP_OPEN
- LGMDP_US
- LGMDP_EURO
- LGMDP_H3G
Изпитано преди месец и работи....
