а не сте ли се замисляли, че самата марка леново, може да е реплика?.... Добре добре, излизам :))
Да, да реплика е на Моторола :D
Nqkoi moje li da pomogne pri lenovo a820 displeq raboti a tuch botonite samo svetqt a ne rabotqt
Пиши на кирилица!
mod. edit
Гледам го това телефонче и май скоро ще натисна бутона buy. Характеристиките му ми се струват доста впечатляващи за цената.
Lenovo Golden Warrior A8 / Lenovo A806 MTK6592 Octa Core 1.7GHz Android 4.4 Smartphone 2GB Ram 16GB Rom 5.0 Inch HD Screen 4G LTE Black
Dev-Host - The Ultimate Free File Hosting / File Sharing Service
теглиш A820t_repair_touchscreen_20130515.7z
после следваш:
What you need:
1. Special A820T firmware, taken from lenovohome Chinese forum: A820t_repair_touchscreen_20130515.7z– I have uploaded it in my dropbox folder and removed password protection.
2. Some official A820 firmware, I have used S139 from needrom site: ROM Lenovo A820 | [Official]-[Updated] add the 05/24/2013 on Needrom
3. FlashTools - included in A820T firmware
4. Ofcourse you need MTK drivers, but if you have flashed the wrong firmware first, then you should have them installed.
- Extract all archives into separate folders
- Load A820T scatter file in FlashTools, turn off the phone and leave baterry in. Remove all SIM and external SD cards just for safety. Now click on preloader (not on the checkbox, but on the name inside FlashTools) and a prompt will pop up. Select the preloader from A820_S139 firmware (or from the version you chose on step 2). The phone doesn't start with preloader from A820T. Then hit Firmware->Upgrade and connect the phone to PC.
- After you see the green circle, try to power up the phone. I have tried it on 2 A820 phones. One of them booted into OS, the other one was stuck at Lenovo logo, but both worked after next step.
- Now turn off the phone again, load scatter frile from A820_S139 and flash the full firmware with Firmware->Upgrade. After that touchscreen should work normally.
Ако не ти е ясно за какво иде реч - по-добре не прави нищо.
Днес ми пристигнаха телефончетата - 2 броя:
Голямо разцъкване ще пада.
Честито,как е дисплея като яркост и цветове,че нещо А серията на Леново ме разочарова в това отношение.
На мен ми харесват телефончета. Вчера поръчах още един и за сина.
