Резултати от 1 до 2 от общо 2
phpbb error
    Dec 2002
    phpbb error
    Какво ли означава това:
    Error in posting
    DEBUG MODE
    SQL Error : 1062 Duplicate entry '4199' for key 1
    INSERT INTO phpbb_posts (topic_id, forum_id, poster_id, post_username, post_time, poster_ip, enable_bbcode, enable_html, enable_smilies, enable_sig) VALUES (864, 27, 38, '', 1116155651, 'd4cd9d46', 1, 1, 1, 0)
    Line : 271
    File : functions_post.php
    Когато се опитвам да отговоря на една тема в един друг форум?
  3. Junior Member
    Dec 2002
    phpbb error
    Никой не ми отговори
    Аз намерих решението с това:
    <blockquote id="quote"><font size="1" id="quote"><b id="quote">quote:</b id="quote"></font id="quote"><table border="0" id="quote"><tr id="quote"><td class="quote" id="quote"><font size="1" id="quote"><?php
    // Check and repair all tables in a PHPBB structure
    // verify that we're supposed to run
    // change 'PX42m3' to something unique for your site, so it will only
    // execute if you call it as 'http://mysite.com/fixtables.php?PX42m3=1'
    if (!isset($_GET['PX42m3']))
    header("Location: http://127.0.0.1/");
    die();
    define('IN_PHPBB', true);
    $phpbb_root_path = './';
    include($phpbb_root_path . 'config.php');
    // connect to the database server
    $db = mysql_connect($dbhost,$dbuser,$dbpasswd);
    if (!$db) die("Unable to connect to database!\n");
    // select the PHPBB database
    mysql_select_db($dbname,$db);
    // get a list of tables for this PHPBB
    $tablequery = "show tables like '".$table_prefix."%'";
    $tablelist = mysql_query($tablequery,$db);
    // cycle through them for repair
    while ($tar = mysql_fetch_array($tablelist))
    $tablename = $tar[0];
    // output some verbosity for comfort
    echo "Now checking and repairing table $tablename ... ";
    $repres = mysql_query("repair table $tablename");
    $result = mysql_fetch_array($repres);
    echo $result['Msg_text'] . "<br>\n";
    Ако някой има проблем с БД на phpbb,нека го запази като "fixtables.php" в главната дир на форума и после да отвори това:
    "http://името на сайта/phpbb/fixtables.php?PX42m3=1".
    Това "fixtables.php" поправя и други грешки в таблиците!
    Благодаря!
  1. phpBB
    От DENITO във форум Общ - софтуер
    Последно: 04-05-07, 16:05
  2. Питане за phpbb
    От badboy във форум Уебдизайн и 3D
    Последно: 28-01-07, 13:18
  3. Въпрос за PHPBB
    От Nedko във форум Програмиране
    Последно: 25-03-06, 00:50
  4. Проблем с phpBB
    От .ostrich. във форум Общ - софтуер
    Последно: 08-11-05, 18:21
  5. phpBB error
    От OvErRiD3 във форум Уебдизайн и 3D
    Последно: 14-12-04, 02:47
