Резултати от 1 до 3 от общо 3
Nikon камери и фотоапарати / FAQ - на първа страница, обсъждания, мнения
    http://www.nikon.bg/bg_BG/
    Nikon Europe
    Nikon | Home
    Таблицата ще я допълня когато имам повече време - най вероятно в Сряда или Четвъртък
    Nikon compact digital camera 2012
    Specifications
    coolpix P510
    coolpix P310
    coolpix S9300
    coolpix S6300
    coolpix S4300
    coolpix S2600
    coolpix S3300
    coolpix L810
    coolpix L26
    coolpix L25
    coolpix S30
    Effective pixels 16.1 milion 16.1 milion 16.0 milion 16.0 milion 16.0 milion 14.0 milion 16.0 milion 16.1 milion 16.1 milion 10.1 milion 10.1 milion
    Lens 42x zoom NIKKOR; 4.3-180mm (35mm[135] format angle of view:24-1000mm); f/3-5.9; Digital zoom: up to 2x (35mm[135] format angle of view:Approx 2000mm) 4.2x zoom NIKKOR; 4.3-17.9mm (35mm[135] format angle of view:24-1000mm); f/1.8-4.9; Digital zoom: up to 2x (35mm[135] format angle of view:Approx 2000mm) 18x zoom NIKKOR; 4.5-81.0mm (35mm[135] format angle of view:25-450mm); f/3.5-5.9; Digital zoom: up to 4x (35mm[135] format angle of view:Approx 1800mm) 10x zoom NIKKOR; 4.5-45.0mm (35mm[135] format angle of view:25-250mm); f/3.2-5.98 Digital zoom: up to 4x (35mm[135] format angle of view:Approx 1000mm) 6x zoom NIKKOR; 4.6-27.6mm (35mm[135] format angle of view:26-156mm); f/3.5-6.5; Digital zoom: up to 4x (35mm[135] format angle of view:Approx 624mm) 5x zoom NIKKOR; 4.6-23.0mm (35mm[135] format angle of view:26-130mm); f/3.2-6.5;
    Digital zoom: up to 4x (35mm[135] format angle of view:Approx 520mm)
    26x zoom NIKKOR; 4.0-104mm (35mm[135] format angle of view:22.5-585mm); f/3.1-5.9;
    Digital zoom: up to 4x (35mm[135] format angle of view:Approx 2340mm)
    Focus range
    (from lens)
    50cm to infinity,
    Macro close-up mode:
    1 cm to infinity
    30cm to infinity,
    2 cm to infinity
    50cm to infinity,
    Macro mode:
    4 cm to infinity
    50cm to infinity,
    Macro mode:
    10 cm to infinity
    50cm to infinity,
    5 cm to infinity
    50cm to infinity,
    Macro mode:
    10 cm to infinity
    50cm to infinity,
    Macro mode:
    5 cm to infinity
    50cm to infinity,
    Macro mode:
    1 cm to infinity
    50cm to infinity,
    Macro mode:
    10 cm to infinity
    30cm to infinity,
    Macro mode:
    3 cm to infinity
    30cm to infinity,
    Shoot close-ups/Short under water/Photograph food/Highlifht colcours/the soft pictures/create a diorama effect
    5 cm to infinity
    Monitor 7.5-cm, 921k-dot, TFT LCD
    with antireflection coating
    6.7-cm, 230k-dot, TFT LCD
    7.5-cm, 460k-dot, TFT LCD
    with touch screen control & antireflection coating
    Storage media SD/SDHC/SDXC memory card SD/SDHC/SDXC memory card SD/SDHC/SDXC memory card SD/SDHC/SDXC memory card SD/SDHC/SDXC memory card SD/SDHC/SDXC memory card SD/SDHC/SDXC memory card SD/SDHC/SDXC memory card SD/SDHC/SDXC memory card SD/SDHC/SDXC memory card SD/SDHC/SDXC memory card
    ISO sensitivity ISO 100,200,400,800,1600,3200, Hi1(equivalent to 6400), Auto(auto gain ISO 100-400,100-800, Hi2(equivalent to 12800) (High ISO monochrome in special effect mode) ISO 100,200,400,800,1600,3200, Hi1(equivalent to 6400), Auto(auto gain ISO 100-400,100-800, Hi2(equivalent to 12800) (High ISO monochrome in special effect mode) ISO 125,200,400,800,1600,3200, Auto(auto gain ISO 125-1600), Fixed range auto (ISO 125-400, 125-800) ISO 125,200,400,800,1600,3200, Auto(auto gain ISO 125-1600), Fixed range auto (ISO 125-400, 125-800) ISO 125,200,400,800,1600,3200, Auto(auto gain ISO 125-1600), Fixed range auto (ISO 125-400, 125-800) ISO 80,100,200,400,800,1600,3200*, Auto(auto gain ISO 80-1600), Fixed range auto (ISO 80-400, 80-800) ISO 80,100,200,400,800,1600,3200*, Auto(auto gain ISO 80-1600), Fixed range auto (ISO 80-400, 80-800) ISO 80,100,200,400,800,1600, Auto(auto gain ISO 80-1600) Auto(auto gain ISO 80-1600) Auto(auto gain ISO 80-1600) Auto(auto gain ISO 80-1600)
    Power sources
    Supplied
    Rechargeable Li-ion battery EN-EL5
    Chargering AC Adapter EH-69P
    Rechargeable Li-ion battery EN-EL12
    Rechargeable Li-ion battery EN-EL19
    Power sources
    Optional
    AC Adapter EH-62A
    Battery Charger MH-61
    AC Adapter EH-62F
    Battery Charger MH-65
    AC Adapter EH-62F
    AC Adapter EH-62F
    AC Adapter EH-62FG
    Battery Charger MH-66
    Battery life 240 shots with EN-EL5 battery 230 shots with EN-EL12 battery 200 shots with EN-EL12 battery 230 shots with EN-EL12 battery 180 shots with EN-EL19 battery
    Dimension 119.8x82.9x102.2 mm 103.0x58.3x32.0 mm 108.7x62.3x30.6 mm
    Weight 555 g
    with battery & SD memory card
    194g
    215 g
    160 g
    139 g
    Този пост е редактиран от hristoslav2; 06-12-12 в 18:41.
    Jun 2009
    Отговор: Nikon камери и фотоапарати / FAQ - на първа страница, обсъждания, мнения
    след дълги години с най-различни добри компактни фотоапарати Панасоник, Канон, Олимпус си купих огледално рефлексен фотоапарата на Никон.
    Хора, става въпрос за друга планета.
    По препоръка на мой приятел купих D7000. Пожелавам на повече хора (и форумисти) да могат да си купят.
    May 2011
    Кава е разликата м/у d3200 и d3300.Много ли е голяма?
  1. Отговори: 12
    Последно: 10-06-24, 00:40
  2. Фотоапарати и камери / FAQ - мнения, обсъждане
    От hristoslav2 във форум Фото и видеокамери
    Отговори: 42
    Последно: 10-09-21, 13:37
  3. Отговори: 5
    Последно: 01-11-15, 13:48
  4. Philips LCD / Faq - на първа страница ,обсъждане ,мнения
    Отговори: 1760
    Последно: 26-12-10, 16:39
    Отговори: 2262
    Последно: 06-12-10, 20:51
