Отговор: LG телевизори (инфо на първа страница)
LG OLED Z2
https://www.lcd-compare.com/index.ph...&LGOLED88Z2=on
LG OLED G2 Gallery Edition
https://www.lcd-compare.com/index.ph...OLED83G26LA=on
LG OLED C2
https://www.lcd-compare.com/index.ph...OLED77C25LB=on
LG OLED42C26LB.AEU бял : Vanilla White (гръб и крака)
LG OLED42C24LB.AEU черен : Meteor Titan
LG OLED B2
https://www.lcd-compare.com/index.ph...&LGOLED77B2=on
LG OLED 4K A2
https://www.lcd-compare.com/index.ph...&LGOLED65A2=on
LG 4K Mini-LED QNED87 Silver Steel
https://www.lcd-compare.com/index.ph...75QNED876QB=on
LG 4K Mini-LED QNED86 Dark Steel
https://www.lcd-compare.com/index.ph...86QNED866QA=on
LG 4K QNED82 Silver Steel 2022 - само големите диагонали имат събуфер
https://www.lcd-compare.com/index.ph...86QNED826QB=on
LG 4K QNED81 Dark Steel
https://www.lcd-compare.com/index.ph...86QNED816QA=on
LG 4K Nanocell NANO826QB
https://www.lcd-compare.com/index.ph...75NANO826QB=on
LG 4K Nanocell NANO786QA
Забележка: 86" има разширена функционалност в сравнение с други телевизори от същата серия (HDMI 2.1, FreeSync, AI Picture Pro и др.)
https://www.lcd-compare.com/index.ph...65NANO786QA=on
LG 4K Nanocell NANO766QA
https://www.lcd-compare.com/index.ph...86NANO766QA=on
LG 4K 43NANO7
LG 43NANO76 : черен
LG 43NANO78 : сребрист
LG 4K UQ9100
https://www.lcd-compare.com/index.ph...86UQ91006LA=on
LG 4K UQ8100 - 43", 50", 70" - MVA матрици
https://www.lcd-compare.com/index.ph...75UQ81006LB=on
LG 4K 43UQ81 vs. 43UQ80 - разлика в стойката
https://www.lcd-compare.com/index.ph...43UQ81006LB=on
LG 43UQ7690 - бял корпус
LG 4K UQ7500
https://www.lcd-compare.com/index.ph...65UQ75006LF=on
Сравнение LG G1 Evo (2021) срещу C2 Evo (2022).
Първият е по-евтин, но показва по-ярко в детайлите, почти черните градации са по-добри и няма розов оттенък, когато се гледа под ъгъл.
https://www.youtube.com/watch?v=A2tdIrZlhGs
https://www.youtube.com/watch?v=ajBZyWC-o4w
https://www.youtube.com/watch?v=Mf4ge_73buE
https://www.rtings.com/tv/tools/comp...threshold=0.10
Интересно пуснали са нов Софтуер (firmware) за Телевизорите LG от 2015г. което е супер понеже поддръжката е само 5 години и последният е от 2020г. Браво на LG.
Откъде е инфото?
До снощи нямаше нищо на моя. Сега проверих и на сайта на ЛГ България е само последната версия от 2020.
Какво е новото и има ли нещо добавено?
Как така откъде е инфото ето виж сам и се убеди Телевизоры LG - Прошивки
Щом не си получил ъпдейта до 1 месец ще го получиш, ще дойде след некоя седмица и при теб.
Никой не го интересува Официалната поддръжка на LG, важното е кво пише във форума дето съм дал. Първо излиза там после става официално след Месец време. Получавал съм ъпдейти преди да станат Официални от LG.
https://www.youtube.com/watch?v=QQxy1_Rt7Ws
We review the LG G2, the company's 2022 flagship 4K OLED TV which features "OLED Evo" technology, supplemented by a heat dissipation layer (marketed as "Brightness Booster Max").
Timestamp
0:00 G2's Secret Weapon
0:23 vs Samsung QD-OLED
1:01 Brightest WRGB OLED!
1:38 vs Sony A90J
1:58 Improvement #1 vs G1
2:50 Improvement #2
3:23 Downgrade #1 vs G1
4:18 Improvement #3
5:13 Worse vs QD-OLED
6:00 HDR quirks
7:18 Gaming powerhouse!
8:00 Downside of 1000 nits
9:00 This remained unfixed.
9:47 Controversial design choice
10:13 Improvement #4
11:20 vs QD-OLED for gaming?
LG 43UP80003LR review
https://geex.x-kom.pl/recenzje/test-...g-43up80003lr/
43UP80003LR: VA panel, 4 domain, RGB, vertical stripe, Direct LED, LCD, 60Hz
In HDR mode on the board of 10%, the maximum luminance after three minutes of measurement was only 284 nits.
https://geex.x-kom.pl/wp-content/upl...asnosc-hdr.png
https://geex.x-kom.pl/wp-content/upl...znamionowa.jpg
LG 60UP80003LR review
https://geex.x-kom.pl/recenzje/test-i-recenzja-telewizora-lg-60up80003/
60UP80003LR: VA panel, 8 domain, RGB, vertical stripe, Direct LED LCD
In addition, the image is too brightened in very dark grays. What's worse, the TV used a very aggressive complete shutdown of the LEDs (not to be confused with dimming). Figuratively speaking, turning off the backlight worked so aggressively that it was not possible to display a tiny window with an area of 1% and a brightness of 5% on the screen at all, because the TV consciously and deliberately turned off the backlight completely. The use of 256-degree gray analysis showed that the complete screen dimming occurs when the brightness drops below 8% !!! Censorship of some kind, or what?
Below is a short summary showing the behavior of the TV when trying to display test boards:
window 1% – extinguishes everything below 8%,
window 5% – extinguishes below 3%,
window 10% – extinguishes below 2%,
window 25% – extinguishes at 0% (i.e. at zero signal).
My appeal to the manufacturer: please disable this function, because because of it I had to lower the rating of this TV.
HDR
In HDR mode on the board 10%, the maximum luminance after three minutes of measurement was only 297 nits.
https://geex.x-kom.pl/wp-content/upl...g-60UP8003.jpg
LG 32LQ630B6LA review
https://geex.x-kom.pl/recenzje/grubc...a-lg-32lq630b/
32LQ630B: VA panel, RGB, 4-domain,vertical stripe, Direct LED, LCD, 60Hz, webOS 7.1
In HDR mode on the board, 10% maximum luminance after three minutes of measurement was only... 196 nits.
https://geex.x-kom.pl/wp-content/upl...g-32lq630b.jpg
Хубава новина сега виждам че Новите ъпдейти на Софтуера за всички телевизори модели от 2014 и 2015г. вече са официални във Азия и до 1 месец ще дойдат и в БГ. Браво на LG за дългата поддръжка.
Ето вижте сами и се убедете: Телевизоры LG - Прошивки
И в Англия е пуснат Новият Ъпдейт на Официалната страница на LG, сега проверих понеже аз се намирам в Лондон.
И на българския сайт го има вече version 04.06.75 / 02.05.2022.
Нещо важно променено ли е, че в описанието пише само Improved voice recognition performance, което мен лично не ме интересува.
Ами да и аз това прочетох, но със сигурност са премахнати или обновени някои програми или други неща защото новият Софтуер е със 13 Mb. по-малък от предишния като ги сравнявам.
Все пак има разлика от 2 години и са премахнати някои програми, но не са написали кои.
Аз си обнових и Дистанционното с AN-MR700, което е по-ново и модерно и замества старото но много трудно го намерих да го купя. То става само за Моделите от 2015, 2016 и 2017г.
Това, което се нарича LG OLED C2, е цяло семейство модели с редица опции (цвят на корпуса,гърба, краката/стойката). Те могат да бъдат разпознати по цифрите и буквите след C2.
LG OLED C29LD - може да се върти върху стойката(55",55",77"). С изключение на големите диагонали (83C29LA без завъртане). WiSA (Аудио от безжични високоговорители)
Двете най-малки опции 42", 48" - няма опции за въртящи на стойка.
Ако откриете още информация и разлики, пишете в темата.
LG OLED C2 |
Model | Frame (рамка) | Basement (основа) | Back (гръб) | -- | Tuners (тунери) | Audio (аудио) |
LG OLED C21LA | -- | -- | -- | -- | DVB-T/T2/C/S/S2 | -- |
LG OLED C22LB | -- | -- | -- | -- | DVB-T/T2/C/S/S2 | -- |
LG OLED C23LA | -- | -- | -- | -- | DVB-T/T2/C/S/S2 | -- |
LG OLED C24LA | Dark Titan Silver | 48,55,65,77,88" - Metal Central Leg
42" - Dark Titan Silver Bipolar Base | Meteor Titan | -- | DVB-T/T2/C/S/S2 | 2x10W + Sub 2x10W (42" 2x10W, no Sub)
Only 42", 48" have headphones out |
LG OLED C25LB | Silver | Metal Central Leg | Vanilla White | -- | DVB-T/T2/C/S/S2 | 2x10W + Sub 2x10W (42" 2x10W, no Sub)
LG OLED C26LB | Silver | Vanilla White | Vanilla White | -- | DVB-T/T2/C/S/S2 | -- |
LG OLED C27LA | -- | -- | -- | -- | Twin triple tuners
LG OLED C28LB | Grey | -- | -- | -- | Twin triple tuners
LG OLED C29LD | -- | 55,65,77" - Rotating
42,48" - Bipolar Base | -- | -- | Twin triple tuners
DVB-T/T2/C/S/S2 | WiSA |
Допълнена таблица
LG OLED C2 |
LG OLED C24LA | Dark Titan Silver | 48,55,65,77,88": Metal Central Leg 42": Dark Titan Silver, L-shaped feet | Meteor Titan | -- | DVB-T/T2/C/S/S2 | 2x10W + Sub 2x10W (42" 2x10W, no Sub)
LG OLED C27LA | -- | 83": the "old" wide C-Alpine stand 77/65/55": new 2022 stand, non-rotatable 48": the "old" wide C-Alpine stand 42": the new lateral L-shaped feet | dark anthracite
"Dark Titan Silver"/"Titanium Gray" | -- | Twin triple tuners
LG OLED C28LB | Grey | 77/65/55": new 2022 stand, non-rotatable 48": the "old" wide C-Alpine stand | cream-white shade
"Calming Beige | -- | Twin triple tuners
LG OLED C29LD | -- | 83": the "old" wide C-Alpine stand 77/65/55": rotating new 2022 stand 48": the "old" wide C-Alpine stand 42": the new lateral L-shaped feet | cream-white shade
"Calming Beige" | -- | Twin triple tuners
Според вас кой вариант е по-добър - LG OLED C1 серията или серия LG NanoCell 90?
Тоя "наноцел" ;) не е добре и спрямо другите LCD-та, а какво остава да го сравняваш с ОЛЕД .
Според нуждите може и да вземеш ЛСД, но ми се струва, че има по-добри предложения от тоя "нано..." , освен ако не е на някаква супер изгодна цена спрямо другите (ма едва ли щом питаш за ОЛЕД)
