Имам DELL Inspirion 5010 слагам Ubuntu 10.04 (с BackTrack резултата е същия) и не намира никакви мрежи... изобщо не разпознава wifi адаптора...
Покажи изхода от lspci и файла /var/log/dmesg , ако го има все още в Убунту :) . Ако го няма dmesg може /var/log/syslog .
dell@dell-laptop:~$ lspci
00:00.0 Host bridge: Intel Corporation Core Processor DRAM Controller (rev 12)
00:01.0 PCI bridge: Intel Corporation Core Processor PCI Express x16 Root Port (rev 12)
00:16.0 Communication controller: Intel Corporation 5 Series/3400 Series Chipset HECI Controller (rev 06)
00:1a.0 USB Controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 06)
00:1b.0 Audio device: Intel Corporation 5 Series/3400 Series Chipset High Definition Audio (rev 06)
00:1c.0 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 1 (rev 06)
00:1c.1 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 2 (rev 06)
00:1c.2 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 3 (rev 06)
00:1c.4 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 5 (rev 06)
00:1d.0 USB Controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 06)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev a6)
00:1f.0 ISA bridge: Intel Corporation Mobile 5 Series Chipset LPC Interface Controller (rev 06)
00:1f.2 SATA controller: Intel Corporation 5 Series/3400 Series Chipset 6 port SATA AHCI Controller (rev 06)
00:1f.3 SMBus: Intel Corporation 5 Series/3400 Series Chipset SMBus Controller (rev 06)
01:00.0 VGA compatible controller: ATI Technologies Inc Manhattan [Mobility Radeon HD 5000 Series]
01:00.1 Audio device: ATI Technologies Inc Manhattan HDMI Audio [Mobility Radeon HD 5000 Series]
12:00.0 Network controller: Broadcom Corporation Device 4727 (rev 01)
13:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8101E/RTL8102E PCI Express Fast Ethernet controller (rev 02)
dell@dell-laptop:~$
Basic display modes:
-mm Produce machine-readable output (single -m for an obsolete format)
-t Show bus tree
Display options:
-v Be verbose (-vv for very verbose)
-k Show kernel drivers handling each device
-x Show hex-dump of the standard part of the config space
-xxx Show hex-dump of the whole config space (dangerous; root only)
-xxxx Show hex-dump of the 4096-byte extended config space (root only)
-b Bus-centric view (addresses and IRQ's as seen by the bus)
-D Always show domain numbers
Resolving of device ID's to names:
-n Show numeric ID's
-nn Show both textual and numeric ID's (names & numbers)
-q Query the PCI ID database for unknown ID's via DNS
-qq As above, but re-query locally cached entries
-Q Query the PCI ID database for all ID's via DNS
Selection of devices:
-s [[[[<domain>]:]<bus>]:][<slot>][.[<func>]] Show only devices in selected slots
-d [<vendor>]:[<device>] Show only devices with specified ID's
Other options:
-i <file> Use specified ID database instead of /usr/share/misc/pci.ids.gz
-p <file> Look up kernel modules in a given file instead of default modules.pcimap
-M Enable `bus mapping' mode (dangerous; root only)
PCI access options:
-A <method> Use the specified PCI access method (see `-A help' for a list)
-O <par>=<val> Set PCI access parameter (see `-O help' for a list)
-G Enable PCI access debugging
-H <mode> Use direct hardware access (<mode> = 1 or 2)
-F <file> Read PCI configuration dump from a given file
Проблема е с драйвера - http://www.broadcom.com/support/802.11/linux_sta.php пробвай с този!
https://help.ubuntu.com/community/Wi...Driver/bcm43xx
Или ако ти е по-лесно, да си инсталираш bcmwl-kernel-source с apt-get , или както ти е удобно.
претърпях провал... това ми е първия допир с linux...
системата заби нито win нито linux искаше да тръгне резултата в момента на PC-то имам win + два linux-a :D
изписа ми
error: unknown filesystem
grub rescue>
опитах се да преинсталиран win някакъв излязоха някакви грешки изобщо не тръгна...
но за сметка на това инсталацията на Ubuntu нямаше проблем и сега си го имам два пъти
доколкото разбрах за да използвам "bcmwl-kernel-source с apt-get" ми е нужен интернет а това е нещото което се опитвам да пусна
за казаното от glowndark ще го пробвам утре че не ми останаха нерви сега :D
П.С. да направя ли пълен формат и всичко отначало?
Пакетът може да го свалиш от ТУК, да си го замъкнеш на лаптопа, и съсда си го инсталираш. А този лаптоп няма ли Ethernet интерфейс ? Относно двете инсталации на убунту, аз лично бих ги затрил и бих инсталирал едно на чисто.Код:dpkg -i 'imeto na paketa'
това с Ethernet беше гениално :)
вече всичко е ОК :)
