Резултати от 1 до 8 от общо 8
DELL WiFi
    Jul 2009
    DELL WiFi
    Имам DELL Inspirion 5010 слагам Ubuntu 10.04 (с BackTrack резултата е същия) и не намира никакви мрежи... изобщо не разпознава wifi адаптора...
    Aug 2006
    Re:DELL WiFi
    Покажи изхода от lspci и файла /var/log/dmesg , ако го има все още в Убунту . Ако го няма dmesg може /var/log/syslog .
    Jul 2009
    Re:DELL WiFi
    dell@dell-laptop:~$ lspci
    00:00.0 Host bridge: Intel Corporation Core Processor DRAM Controller (rev 12)
    00:01.0 PCI bridge: Intel Corporation Core Processor PCI Express x16 Root Port (rev 12)
    00:16.0 Communication controller: Intel Corporation 5 Series/3400 Series Chipset HECI Controller (rev 06)
    00:1a.0 USB Controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 06)
    00:1b.0 Audio device: Intel Corporation 5 Series/3400 Series Chipset High Definition Audio (rev 06)
    00:1c.0 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 1 (rev 06)
    00:1c.1 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 2 (rev 06)
    00:1c.2 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 3 (rev 06)
    00:1c.4 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 5 (rev 06)
    00:1d.0 USB Controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 06)
    00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev a6)
    00:1f.0 ISA bridge: Intel Corporation Mobile 5 Series Chipset LPC Interface Controller (rev 06)
    00:1f.2 SATA controller: Intel Corporation 5 Series/3400 Series Chipset 6 port SATA AHCI Controller (rev 06)
    00:1f.3 SMBus: Intel Corporation 5 Series/3400 Series Chipset SMBus Controller (rev 06)
    01:00.0 VGA compatible controller: ATI Technologies Inc Manhattan [Mobility Radeon HD 5000 Series]
    01:00.1 Audio device: ATI Technologies Inc Manhattan HDMI Audio [Mobility Radeon HD 5000 Series]
    12:00.0 Network controller: Broadcom Corporation Device 4727 (rev 01)
    13:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8101E/RTL8102E PCI Express Fast Ethernet controller (rev 02)
    dell@dell-laptop:~$
    Basic display modes:
    -mm Produce machine-readable output (single -m for an obsolete format)
    -t Show bus tree
    Display options:
    -v Be verbose (-vv for very verbose)
    -k Show kernel drivers handling each device
    -x Show hex-dump of the standard part of the config space
    -xxx Show hex-dump of the whole config space (dangerous; root only)
    -xxxx Show hex-dump of the 4096-byte extended config space (root only)
    -b Bus-centric view (addresses and IRQ's as seen by the bus)
    -D Always show domain numbers
    Resolving of device ID's to names:
    -n Show numeric ID's
    -nn Show both textual and numeric ID's (names & numbers)
    -q Query the PCI ID database for unknown ID's via DNS
    -qq As above, but re-query locally cached entries
    -Q Query the PCI ID database for all ID's via DNS
    Selection of devices:
    -s [[[[<domain>]:]<bus>]:][<slot>][.[<func>]] Show only devices in selected slots
    -d [<vendor>]:[<device>] Show only devices with specified ID's
    Other options:
    -i <file> Use specified ID database instead of /usr/share/misc/pci.ids.gz
    -p <file> Look up kernel modules in a given file instead of default modules.pcimap
    -M Enable `bus mapping' mode (dangerous; root only)
    PCI access options:
    -A <method> Use the specified PCI access method (see `-A help' for a list)
    -O <par>=<val> Set PCI access parameter (see `-O help' for a list)
    -G Enable PCI access debugging
    -H <mode> Use direct hardware access (<mode> = 1 or 2)
    -F <file> Read PCI configuration dump from a given file
  5. Moderator Аватара на glowndark
    Oct 2004
    Re:DELL WiFi
    Проблема е с драйвера - http://www.broadcom.com/support/802.11/linux_sta.php пробвай с този!
    https://help.ubuntu.com/community/Wi...Driver/bcm43xx
    Aug 2006
    Re:DELL WiFi
    Или ако ти е по-лесно, да си инсталираш bcmwl-kernel-source с apt-get , или както ти е удобно.
    Jul 2009
    Re:DELL WiFi
    претърпях провал... това ми е първия допир с linux...
    системата заби нито win нито linux искаше да тръгне резултата в момента на PC-то имам win + два linux-a :D
    изписа ми
    error: unknown filesystem
    grub rescue>
    опитах се да преинсталиран win някакъв излязоха някакви грешки изобщо не тръгна...
    но за сметка на това инсталацията на Ubuntu нямаше проблем и сега си го имам два пъти
    доколкото разбрах за да използвам "bcmwl-kernel-source с apt-get" ми е нужен интернет а това е нещото което се опитвам да пусна
    за казаното от glowndark ще го пробвам утре че не ми останаха нерви сега :D
    П.С. да направя ли пълен формат и всичко отначало?
    Aug 2006
    Re:DELL WiFi
    Пакетът може да го свалиш от ТУК, да си го замъкнеш на лаптопа, и със
    Код:
    dpkg -i 'imeto na paketa'
    да си го инсталираш. А този лаптоп няма ли Ethernet интерфейс ? Относно двете инсталации на убунту, аз лично бих ги затрил и бих инсталирал едно на чисто.
    Jul 2009
    Re:DELL WiFi
    това с Ethernet беше гениално
    вече всичко е ОК
  1. Отговори: 1
    Последно: 15-10-12, 07:51
  2. Продава Чисто Нов - Dell Streak 7 WiFi 16GB - Android Honeycomb 3.2
    От papu4ara във форум Приключили продажби
    Последно: 30-01-12, 22:22
  3. Продавам iPad 64GB WiFi и laptop Dell XPS M1330
    От MMDDMM във форум Приключили продажби
    Последно: 12-10-11, 08:55
  4. Dell пуска в продажба хибрида лаптоп - таблет Dell Duo
    От kod във форум Новини от SetCombG.com
    Последно: 17-11-10, 08:27
  5. wifi
    От bojin1 във форум Мрежи
    Последно: 02-03-08, 19:08
