Predvarielno se izvinqvam za pravopisa, no ne sum si opravil kirilizaciqta
Srestam maluk problem s pyskaneto na licq. Poneze sum v lan i inetrneta mi e prez proxy instaliram socks s nastroikite za prosyto:
/configure --with-default-server=172.16.1.1:3128
/make
/make install
Do tuk vsichko e tok i zici
Instaliram samoto licq:
./configure --enable-socks5
do tuk dobre
SOCKS5 support is enabled.
OpenSSL secure channel support is enabled.
obache sled kato napisha make mi se polu4ava slednoto:
make all-recursive
make[1]: Entering directory `/licq-1.0.2'
Making all in share
make[2]: Entering directory `/licq-1.0.2/share'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `/licq-1.0.2/share'
Making all in src
make[2]: Entering directory `/licq-1.0.2/src'
c++ -DHAVE_CONFIG_H -I. -I. -I.. -Wall -I../include -DINSTALL_PREFIX=\"/usr/local\" -Wno-implicit -fPIC -DPIC -D_REENTRANT -O2 -fno-exceptions -fno-check-new -c main.cpp
main.cpp: In function `int main (int, char **)':
main.cpp:32: `SOCKSinit' undeclared (first use this function)
main.cpp:32: (Each undeclared identifier is reported only once for each
function it appears in.)
make[2]: *** [main.o] Error 1
make[2]: Leaving directory `/licq-1.0.2/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/licq-1.0.2'
make: *** [all-recursive-am] Error 2
[root@Matrix /licq-1.0.2]#
Kogato instaliram samoto licq bez socks5 supprot nqma nikakvi problemi - trugva, no estestveno ne moze da se conectne.
People can fly
 Новини
 Новини Форум
 Форум Актуално
 Актуално сървър
 сървър
