Здравейте !
Видях този модел в каталога на техномаркет , но не пише никакви данни за него - http://www.technomarket.bg/product_d...ct_id=09036466 .
Това новата серия плазми на панасоник ли са . Някой може ли да даде повече инфо .
Тези данни ги намерих в нета , надявам се да са вeрни :
HD Plazma televizor PANASONIC TH-42PV80P
HD plazma televizor dijagonale 42 incha/107 cm, dinamičkog kontrasta 1:1,000,000 (prirodni kontrast 1:15,000), rezolucije 1024 x 768 pixela i sa 3 HDMI ulaza.
TH-42PV80 je nasljednik plazme TH-42PV70 - najprodavanije plazme u 2007. i dobitnika EISA nagrade
Opis:
TV Tuner
Tuner Integrated: analog
Tuning System: PLL synthesizer 100-position auto-search tuner
CATV Compatibility : Hyper-band Hyper-band
Broadcast Stereo Reception : NICAM -B, G, I, L, German (A2)
Teletext Reception : 1000P Level 2.5, FASTEXT/LIST/TOP
Receiving System : PAL -B/G/H, -I, -D/K: SECAM -B/G, -D/K, L/L'
Receiving System (AV input): PAL-525/60, SECAM, NTSC, M-NTSC PAL-525/60, SECAM, NTSC, M-NTSC
Display
Screen Size: 42" (106 cm) diagonal
Screen Aspect : 16 : 9 Wide
Panel : G11 Progressive HD Plasma Display Panel
Natural Vision Filter
Progressive Scan
Number of Pixels : 786,432 (1,024 x 768) pixels
Colour System: NTSC/PAL/PAL 60Hz/SECAM/M-NTSC
Applicable PC signals: XGA (SXGA compressed)
Applicable Scanning Format: 525 (480)/60i, 525 (480)/60p, 625 (576)/50i, 625 (576)/50p, 750 (720)/50p, 750 (720)/60p,1125 (1080)/50i, 1125 (1080)/60i, 1125 (1080)/24p (HDMI only), 1125 (1080)/50p (HDMI only), 1125 (1080)/ 1125 (1080)/
Contrast Ratio (in dark surroundings): Native: 15,000:1; Dynamic: 1,000,000:1
Shades of Gradation : 4,096 equivalent steps of gradation
100 Hz Double Scan
24p Playback
3D Colour Management
Sub Pixel Control
Motion Pattern Noise Reduction
C.A.T.S. (Contrast Automatic Tracking System)
Video Noise Reduction
3D Comb Filter
Picture Mode : Dynamic/Normal/Cinema/Eco
Sound
Speakers: Full-Range (160 x 42 mm) x 2 (L,R)
Audio Output : 20 W (10 W x 2), 10% THD
Sound Mode : Music/Speech
V-Audio
Ambience
Terminals
SD Memory Card Slot (SDHC Compatible)
HDMI Input: 3 (rear)
Composite Video Input AV3: RCA phono type x 1 (front)
S-Video Input AV3: Mini DIN 4-pin (front)
Audio Input (for Video) AV3: RCA phono type connectors (L, R) (1 set, front)
PC Input : Mini D-sub 15-pin x 1 (rear)
Component Video Input: RCA phono type x 3 [Y , PB, PR] (rear)
Audio Input (for HDMI, PC, Component): RCA phono type connectors (L, R) (1 set, rear)
21-Pin Input/Output: AV1: AV In/Out, RGB In, Q-Link (rear)
AV2: AV In/Out, S-Video In, RGB In, Q-Link (rear)
Monitor Out: RCA phono type connectors (L, R) (1 set rear)
Audio Output: Headphone jack (1 front)
Features
VIERA Link
Screen Saver: Wobbling
Multi Window: PAT
Q-Link
Aspect Controls : Auto/16:9/14:9/Just/4:3/Zoom1/Zoom2/Zoom3
On-Screen Display Languages : 25 languages
Off Timer : 15/30/45/60/75/90 min
Child Lock
General
Power Supply : AC 220 - 240 V, 50/60Hz
Power Consumption (Rated): 255 W
Dimensions W/O stand (W x H x D) : 1,020 x 679 x 95 mm
Dimensions with stand (W x H x D): 1,020 x 727 x 327 mm
Weight W/O stand : 26 kg
Weight with stand : 28 kg
Operating Temperature : 0°C - 35°C
http://www.ronis.hr/upload/Televizor.../th42pv80p.JPG
