Отговор: Philips телевизори 2016
  Philips 2016
899 € - Philips 43PUS6501 (43’’, 124 cm)
1 099 € - Philips 49PUS6501 (49’’, 124 cm)
1 399 € - Philips 65PUS6501 (55'', 109 cm)
1 799 € - Philips 56PUS6521 (65'', 165 cm)
22PFK4000/12	FHD LED TV 100PMR Digital Crystal Clear 12 Volt	Direct	€ 229,00
24PHK4000/12	HD LED TV 100PMR Digital Crystal Clear	Direct	€ 249,00
24PFK5211/12	HD, LED, 200Hz Digital Crystal Clear + Bluetooth speaker	Apr	€ 299,00
32PFS5501/12	Full HD, LED, 500Hz, Android TV, Pixel Plus HD, Dual Core	Mei	€ 449,00
40PFS5501/12	Full HD, LED, 500Hz, Android TV, Pixel Plus HD, Dual Core	Mei	€ 549,00
49PFS5501/12	Full HD, LED, 500Hz, Android TV, Pixel Plus HD, Dual Core	Mei	€ 749,00
32PFS6401/12	FHD, Slim LED, Ambilight-2, 1000Hz, Android TV, Pixel Plus UHD, Quad Core	Mrt	€ 549,00
43PUS6401/12	UHD, Slim LED, Ambilight-2, 1000Hz, Android TV, Pixel Plus UHD, Quad Core	Mrt	€ 799,00
49PUS6401/12	UHD, Slim LED, Ambilight-2, 1000Hz, Android TV, Pixel Plus UHD, Quad Core	Mrt	€ 999,00
55PUS6401/12	UHD, Slim LED, Ambilight-2, 1000Hz, Android TV, Pixel Plus UHD, Quad Core	Mrt	€ 1.199,00
43PUS6501/12	UHD, Slim LED, Ambilight-2, 1800Hz, Android TV, Pixel Plus UHD, Quad Core	Mrt	€ 999,00
49PUS6501/12	UHD, Slim LED, Ambilight-2, 1800Hz, Android TV, Pixel Plus UHD, Quad Core	Mrt	€ 1.199,00
55PUS6501/12	UHD, Slim LED, Ambilight-2, 1800Hz, Android TV, Pixel Plus UHD, Quad Core	Mrt	€ 1.399,00
49PUS7101/12	UHD, Slim LED, Ambilight-3, 2000Hz, Android TV, Pixel Plus UHD, Quad Core	Mrt	€ 1.399,00
55PUS7101/12	UHD, Slim LED, Ambilight-3, 2000Hz, Android TV, Pixel Precise UHD, Quad Core	Mrt	€ 1.599,00
65PUS7101/12	UHD, Slim LED, Ambilight-3, 2000Hz, Android TV, Pixel Precise UHD, Quad Core	Apr	€ 2.599,00
75PUS7101/12	UHD, Slim LED, Ambilight-3, 2000Hz, Android TV, Pixel Precise UHD, Quad Core	Mei	€ 5.499,00
65PUS7601/12	UHD, Slim LED, Ambilight-3, 2800Hz, Android TV, Perfect Pixel UHD, HDR premium, Quad Core	Jul	€ 2.999,00
55PUS8601/12	UHD, Slim LED, Ambilight-4, 1800Hz, Android TV, Perfect Pixel UHD, Visible sound, Quad Core	Direct	€ 2.299,00
65PUS8601/12	UHD, Slim LED, Ambilight-4, 1800Hz, Android TV, Perfect Pixel UHD, Visible sound, Quad Core	Direct	€ 3.499,00
  Инчовете? 55 и 65, предполагам...
  Да се похваля...
Вече мога да ползвам пълноценно функцията "Картина в картината" ("Множествен изглед") с два кодирани канала едновременно, както и да записвам предаване по един кодиран канал, докато гледам друг кодиран.
 https://forum.setcombg.com/attachmen...id=19403&stc=1
  Това при използване на един модул и карта или с два модула и карти ?
  Два модула и две карти в два CI слота.
  Здравейте, имам Phillips 55inch TV. Към него има Bluetooth WiFI Speaker на Phillips SWB50, който се връзва към телевизора посредством USB адаптер. Има ли възможност ако го вържа този адаптер на лаптоп да пусна звук от лаптоп.
  Не, доколкото разбирам този USB адаптер е за захранване на самия Speaker. Начини за "пускане" на звук (вероятно имаш предвид музика?) от лаптоп има различни през WiFI към телевизор или друго смарт устройство. Какъв е модела на телевизора и поддържа ли DLNA?
  Някой слагал ли е новия софтуер за телевизори от 4ххх серия. Има ли някакви проблеми ?
  Ревю на модел от 2016 година
 TEST: Android TV Philips PUS 6501 Ultra HD - PHILIPS - HDTV Centrum Polska
49PUS6501/12 - IPS panel,100/120Hz
google превод pl to en
google превод pl to bg
  Да забравим за измерванията при този панел IPS. Реално виждам много по-добро черно в самата картина от колкото VA. Много интересно и положително! Браво.
svetlio1
    What Hi-Fi отдавна не ги чета - това не са ревюта, а прегледи с общи приказки. Не си губи времето с тях.
 Таблица с модели 2016
 http://toengel.net/philipsblog/wp-co...rview_2016.png
UHD
65PUS8901/12 TPT650LS-FJ01 SC1H XM TPV
55PUS8601/12 TPT550U1-FJ04.S SC1B XM TPV
55PUS7181/12 TPT550U2-EQLSHA.G S1E NH TPV
49PUS7181/12 TPT490U2-EQLSHA.G SC2C NH TPV
55PUS7101/12 TPT550U2-EQLSHA.G S1E NH TPV
49PUS7101/12 TPT490U2-EQLSHA.G SC2C NH TPV
55PUS6581/12 TPT550U2-EQLSHA.G S1B XM TPV
55PUS6561/12 TPT550U2-EQLSHA.G S1B XM TPV - IPS panel - 100hz
49PUS6561/12 TPT490U2-EQLSHA.G SC2B XM TPV - IPS panel - 100hz
55PUS6551/12 TPT550U2-EQLSHA.G S1B XM TPV - IPS panel - 100hz
49PUS6551/12 TPT490U2-EQLSHA.G SC2B XM TPV - IPS panel - 100hz
65PUS6521/12 TPT650UA-QVN04.U S400B NH TPV
55PUS6501/12 TPT550U2-EQLSHA.G S1B XM TPV - IPS panel - 100hz
49PUS6501/12 TPT490U2-EQLSHA.G SC2B XM TPV - IPS panel - 100hz
43PUS6501/12 TPT430U3-EQLSHA.G S2A NH TPV - IPS panel - 100hz
55PUS6401/12 TPT550J1-QUBN0.K S8940A XM TPV
49PUS6401/12 TPT490U2-EQYSHM.G SC1G XM TPV
43PUS6401/12 TPT430U3-EQYSHM.G S1H NH TPV
FHD
32PFS5501/12 TPT315B5-FHBN0.K S49P2H NH TPV
48PFK4100/12 TPT480LS-HN08.S SG01A XM TPV
40PFK4101/12 TPT400LA-J6PE1.N SC2A NH TPV
 Программное обеспечение 000.005.101.054 (для 55x0, 64x0, 65x0). Опыт использования. - Страница 4
 http://4pda.ru/forum/index.php?s=&sh...ost&p=45597798
