Така... сега аз имам два конкретни въпроса. Каква е нашата цел и какво можем да направим за да си потърсим правата ?
Всичко започна с едно ревю на Дейвид Макензи
http://www.hdtvtest.co.uk/news/samsu...1108131337.htm
The vertical resolution check area of our test pattern appeared as a solid grey smudge (it’s supposed to be alternating black and white lines), and the diagonal “stipple” pattern did, too. Unfortunately for Samsung, there is a large “FULL HD 3D” logo displayed prominently on the UE40D6530′s box, which, we’re sorry to say, simply isn’t true. Given that Samsung has publicly denounced its cross-town rival LG over the latter’s usage of the term “Full HD 3D” to describe its passive Cinema 3D displays, this is more than a little ironic. We can only assume this is a promotional mistake of some sort, or that in these early days of 3D, a lack of test patterns (we had to made our own) means that TV makers may simply not be entirely or collectively aware of such limitations.
The Samsung UE40D6530 isn’t the only 3DTV promoted as “Full HD 3D” to actually not be – none of the 2011 Panasonic Plasma TV panels we’ve reviewed have been able to reproduce all 1080 lines of the 3D image, although they’re very close and the limitation is nowhere near as extreme. In fact, the only TV manufacturers we haven’t seen slip up in the resolution area so far have been Toshiba and Sony (although we’ve not seen all of their 3D range). This is unfortunate, because one of the greatest strengths of the active-shutter 3D system that Samsung promotes against the Passive system (which LG are proponents of) is… resolution. With this resolution limitation, we’re only left with the down-sides of the active-shutter 3D method – namely expensive glasses, and some flicker visible in bright areas.
http://www.jocys.com/Hardware/Samsung.htm
http://wiki.samygo.tv/index.php5/D6x...L_HD_3D_Defect
http://forum.samygo.tv/viewtopic.php?f=24&t=2346
http://wiki.samygo.tv/index.php5/Com...r_D_series_TVs
После германските ни колеги започнаха отделна тема по въпроса
http://www.hifi-forum.de/index.php?a...ack=&sort=&z=1
Ефекта беше че им върнаха част от парите, а Самсунг промениха надписа на кашона.
Представителството на Самсун в България http://www.samsung.com/bg/info/contactus.html
е клон на Samsung Еlectronics Romania /Sofia Branch/
http://www.samsung.com/ro/info/contactus.html
Един от вас да събре и направи списък с трите имена, телефон и имейл на всички собственици които желаят да се включат
Пишете им да видим как ще ви компенсират.
Успех :Drinks: дано....После да почерпите :)
Ето това вече е изчерпателен отговор :)
Предлагам да изчакаме няколко дена и да съберем още хора и ще направим списъка да го пратим като предлагам да бъде
1. Трите имена и телефон
2. Дата и място на закупуване
3. Сериен номер на телевизор
Това ще го изпратим до съответните магазини и до предстваителите и да чакаме отговор дали изобщо можем да имаме претенции за компенсаци
Аз съм за. Тук ли ще постваме имена и телефони ?
Повечето от вас са регистрирани и в други форуми. Постнете и там линк към тази тема. Така бързо ще се съберете достатъчен брой, проблема ще стане обществено достояние и Самсун по-трудно ще се покрие..
Изберете един от вас, който ще пише от името на всички и му пратете данните на лични.
аз съм с 40D6530 и съм "за" идеята. Ще следя темата за допълнително инфо и да уточним как ще стане споделянето на телефон и адрес
Аз съм с 46D6500 и участвам на 100%
Ако и в упътването не пише, значи няма как да докажете, въпреки наличния материал в нета, поне така си мисля аз.Цитат:
Първоначално публикувано от ztomov
P.S. Всъщност може, само трябва човек, с кашон от същата серия на който пише Full HD 3D.
В случая повече работа ще ви свърши не КЗП, а КЗК(конкуренцията) - глобите, които налага са в пъти по-солени.
Щом е за ''ползу роду'' влизам и аз с UE32D6510,макар,че и технотата ще кажат,че и те са били подведени без да знаят, или нещо от сорта,та и те да помогнат да се натисне Самсунг-нормално е да има компенсации,но нали ''нема такава държава!''.
Аз съм с 40D6510 и аз участвам на 100%
По едни очила поне да ни обезщетят пак ще съм доволен :) Да не говорим пък за безжична мишка + клавиатура или за Skype камера :ole :lipsrsealed: :yahoo:
Колеги и аз ще участвам ,от онзи ден съм с UE32D6500 :) Я споделете ако обичате мнения какви очила да си взема за същия и стават ли 4-тата серия очила на Самсунг за D моделите и по специално за този модел . Благодаря предварително !
Ми аз си взех 2чифта от SSG-3300GR и съм доволен-зареждаш от USB на телевизора,автоматично се влючват и изключват при сваляне и държат батериите.
