Да знам питах за Самсунг 65 инча около тази цена и евентуално сравнение с другите марки.
Благодаря. Извинявам се, че намесих други марки в тази тема. Ще попитам в съответните раздели за предложенията.
Focusing on QLED TV: Samsung Applies for Trademark of QLED TV Instead of Quantum Dot TV | BusinessKorea
How QLED TV could help Samsung finally beat LG's OLEDs - CNET
What is QDLED?
Такива телевизори ще се появят най-рано през 2019 година.
Samsung European UHD TV 2016  Product____________ Certification UHD______________________
Premium
Resolution: 3,840x2,160.
Color depth: 10-bit.
Color gamut: Wide, including the ability to show at least 90 percent of the P3 color gamut .
High dynamic range: Specifically the ability to use SMPTE ST2084's electro-optical transfer function, which Dolby helped create .
Minimum brightness and contrast ratios: There are two possible minimum specs. A minimum brightness of 1,000 nits, along with a black level of a maximum of 0.05 nits (20,000:1 contrast ratio), or a minimum brightness of 540 nits, along with a black level of a maximum of 0.0005 (1,080,000:1) Dolby Vision_______________________________
The metadata is graded in each scene so you get different grades throughout the file. Dolby tells us that scene by scene grading is the superior way to grade a movie, which on paper does sound more efficient.
Standard: Poprietary
Peak Luminance: Up to 10,000 nits
Video Bit Depth: 12-bit
Metadata: Dynamic (scene by scene)
Software Upgradability: No(SoC hardware-embedded)
 HDR 10The metadata is graded and determined, and is then sent at the beginning of the file and covers the entire file. One set of metadata
Standard: Open
Peak Luminance: Up to 4,000 nits
Video Bit Depth: 10-bit
Metadata: Static (per title)
Software Upgradability: Yes
 Videopanel_________________________________________
(type matrix, bit, curvature) Backlight________________________
Dimming Color Space____________________________ Contrast_______________________________________
White & Black level
Viewing angle
_____________ Input Lag_______________________
SoC
CPU
GPU
Platform
OS
_____________ Ports______________________________ Networks_______________________________ Tuner_________________Picture Accuracy
Out-of-the-Box
(score out of 10)
_______________Product KS9800
(curved)
88"
Technically it is a KS9500 – just larger and with a slightly different design.
Yes No 88" - max-1250 cd/m²
Yes HDR1088"- SVA,10bit ?, 120/100Hz, Curvature 4200R
BFI - Scaning Backlight (Led Clear Motion)
Picture Quality Index - 2600
Moth Eye (anti-reflective filter)88" - FALD, Direct Led
? - Local Dimming zones
Blue Leds with RG phosphorus
PWM Freq,-120/100Hz88"-DCI P3- 96% / Rec.2020-
Quantum Dots88" - 88" - 88" - Game mode EXYNOS
ARMv7
Cortex-A7
Quad Core 1.2GHz
16_DTV_JazzM
Tizen 2,4 OS2 x USB 2.0
1 x USB 3.1
1 x Ethernet RJ45
4 x HDMI 2.0 (ARC, CEC,MHL)
1 x Satelite In (Main: F-type female)
1 x Satelite In (Sub:F-type female)
1 x Optical Audio Out
1 x RS 232 C
1 x Antena (RF) (female)
1 x CI+ 1.3
One ConnectLan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct, Screen Mirroring
Bluetooth
DLNA(RUI2.0/DTCP-IP/DMP/DMR/DMS)Dual tuners
DVB -T/ T2/C/S/S2
with PVR and PIP function + Timeshift
DiSEqC version 1.0
Analog (PAL,SECAM)
HEVCKS9800 KS9500
(curved)
78", 65", 55"Yes No 78" - max 1000cd/m²
65" - 10% window max - 1473cd/m2
100% window max - 615cd/m2
55" - max
Yes HDR10
Delta E <1 of all levels of brightness78"- SVA, 10bit, 120/100Hz, Curvature 4200R
65"- SVA, 10bit, 120/100Hz, Curvature 4200R
55"- SVA, 10bit, 120/100Hz, Curvature 4200R
BFI - Flashing Backlight (Led Clear Motion)
Picture Quality Index - 2700
Moth Eye (anti-reflective filter)78" - FALD, Direct Led
65" - FALD, 15x10 - 150 zones
55" - FALD, Direct Led
PWM Freq. - 120/400Hz78"- DCI P3 -
65"- DCI P3 - 96% / Rec.2020-72%
55"- DCI P3- 96% / Rec.2020- 72%
Quantum Dots78" -
65" - SD - ANSI 3783:1 / 120cd/m2 / 0.014cd/m2
with local dimming - 8571cd/m2 / 0.001cd/m2
55" -78" -
65" - 60° (cone)
55" -
78" - Game mode 2
65" - Game mode 20.5ms
55" - Game mode 20.5ms
EXYNOS
ARMv7
Quad Core
1.2GHz
16_DTV_JazzM
1 x USB 3.1
1 x Ethernet RJ45
1 x RS 232 C
1 x CI+ 1.3
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
DVB -T/ T2/C/S/S2
DiSEqC version 1.0
Analog (PAL,SECAM)
HEVCCMS
White balansKS9500 KS9000
(curved)
78", 65", 55", 49"Yes No 75" - max-1000cd/m2
65" - max-1197cd/m2/ SD- 460cd/m2
55" - max-1000cd/m
49" - max 520cd/m2 full display / 1550cd/m2 for 3 sekonds /
Yes HDR100075"- SVA or AMVA, ? ,120/100Hz,
49"- SVA, 10bit, 120/100Hz, Curvature 3000R
Picture Quality Index - 2400
Moth Eye (anti-reflective filter)75" -
65" - Edge LED - below
55" - 8 vertical columns of dimmable zones
49" - Edge Led
PWM Freq,-120/100Hz75"- DCI P3 -
65"- DCI P3 -
49"- DCI P3- 96% / Rec.2020- 76%
Quantum Dots75" -
65" -
55" - 2688:1 / 0.039cd/m2
49" - ANSI 2900:1 /
75" -
65" -
55" - 20° (cone)
49" -
75" - Game mode
49" - Game mode 20.5ms
EXYNOS
ARMv7
Quad Core
1.2Ghz
16_DTV_JazzM
1 x USB 3.1
1 x Ethernet RJ45
4 x HDMI 2.0 (ARC, CEC, MHL)
1 x RS 232 C
1 x CI+ 1.3
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
DVB -T/ T2/C/S/S2
DiSEqC version 1.0
Analog (PAL,SECAM)
HEVC Rec.2020 settings are not correctKS9000 KS8000
75", 65", 55", 49"Yes No 75" - max
65" - max
55"-2% window max 1410cd/m2
55"-100% window max 490cd/m2
49" - max 1270cd/m2 /SD- 450cd/m2
The TV is able to maintain the maximum brightness for a short time, and after about 15 seconds it drops down to about 450cd/m2.
Yes HDR1000
75"- SVA or AMVA, 10-bit , 120/100Hz
Picture Quality Index 2300
Moth Eye (anti-reflective filter)75" - Edge LED - below
65" - Edge Led
55"- 8 vertical columns of dimmable zones
49" - Edge Led
PWM Freq,-120/100Hz75" - DCI P3 -
65" - DCI P3 -
55" - DCI P3- 93% / Rec.2020- 70%
49" - DCI P3 -
Quantum Dots75" -
65" -
55" - ANSI 6820:1 /0.014cd/m2
white - 95.48cd/m2
49" - ANSI 4080:1 / 0.027cd/m2
75" -
65" -
55" - 20° (cone)
49" -
75" - Game mode 20.9ms
65" - Game mode 20.8ms /
55" - Game mode 20.7ms /
49" - Game mode 21.7ms / film - 120.9ms
EXYNOS
ARMv7
Quad Core
1.2GHz
16_DTV_JazzM
1 x USB 3.1
1 x Ethernet RJ45
1 x RS 232 C
1 x CI+ 1.3
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
DVB -T/ T2/C/S/S2
with PVR and PIP function + Tmeshift
DiSEqC version 1.0
Analog (PAL,SECAM)
HEVCKS8000 KS7500
(curved)
65", 55", 49", 43"Yes? No 65" - max
55" - max 1185cd/m² - 1600cd/m2
49" - max
43" - max
Yes HDR100065" - SVA, 8-bit+FRC, 120/100Hz, 4200R
55" - SVA, 8-bit+FRC, 120/100Hz, 4200R
49" - SVA, 8-bit+FRC, 120/100Hz, 3000R
43" - AMVA3, 8-bit+FRC, 120/100Hz, 3000R
PQI - 2000 [43"] / 2200 [≥49"]
Moth Eye (anti-reflective filter)65" - Edge LED - below
(55"- 8 vertical columns of dimmable zones)
49" -
43" -
PWM Freq,-120/100Hz65"- DCI P3- / Rec.2020-
49"- DCI P3- / Rec.2020-
43"- DCI P3- / Rec.2020-
Quantum Dots65" -
55" - ANSI 4000:1/0.03-0.043cd/m2
native 2600:1 /0.046cd/m2/120cd/m2
49" -
43" -
65" -
55" - 30° (cone)
49" -
43" -
65" - Game mode 21,8ms
55" - Game mode 21.7ms / by default
49" - Game mode 21.5ms
43" - Game mode 21 ms
EXYNOS
ARMv7
Quad Core
1GHz
16_DTV_JazzM
1 x USB 3.1
1 x Ethernet RJ45
1 x RS 232 C
1 x CI+ 1.3
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
Bluetooth, Screen Mirroring
DVB -T/ T2/C/S/S2
DiSEqC version 1.0
Analog (PAL,SECAM)
HEVCVertical Blooming
Variable depth of black in HDR mode
Sometimes black in HDR mode is approximately 0.20cd/m², which is comparable to the black level of the panel IPS!KS7500 KS7000
65", 60", 55", 49"Yes ? No 65" - max-1000cd/m²
60" - max-1000cd/m2
55" - 10% window max-1402d/m2/
100% window max - 537cd/m2
SD - 486cd/m2
49" - max-1000cd/m2
60" - SVA, 8-bit+FRC, 120/100Hz
Picture Quality Index - 2100
Moth Eye (anti-reflective filter)65" - Edge Led - below
60" - Edge Led - below
(55"- Edge led - below
49"' - Edge Led - below
60"- DCI P3- / Rec.2020-
55"- DCI P3- 96% / Rec.2020- 71%
Quantum Dots65" -
60" -
55" - native - 4000:1 / 138cd/m2/0.033cd/m2
ANSI 3140:1 / with local dimming 0.002cd/m2
49" -
65" -
60" -
55" - 20° (cone)
49" -
65" - Game mode
60" - Game mode
55" - Game mode 21ms / by default 112ms
49" - Game mode 20ms /
EXYNOS
ARMv7
Quad Core
1GHz
16_DTV_JazzM
1 x USB 3.1
1 x Ethernet RJ45
3 x HDMI 2.0 (ARC, CEC)
1 x RS 232 C
1 x CI+ 1.3
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth ver. 4.0
DLNA(RUI2.0/DTCP-IP/DMP/DMR/DMS)DVB - T/T2/C/S/S2
with PVR function
DiSEqC version 1.0
Analog (PAL,SECAM)
HEVCThe HDR EOTF was extremely good but the colour gamut wasn't tracking Rec.2020 correctly. Vertical Blooming
Sometimes black in HDR mode is approximately 0.20cd/m², which is comparable to the black level of the panel IPS!KS7000 KU6600
(curved)
65", 55", 49", 43"No No 65" -
55" -
49" -
43" -
Compatible65" - SVA, 8-bit, ?Hz, Curvature 4200R
55" - SVA, 8-bit, 60/50Hz, Curvature 4200R
49" - SVA, 8-bit, 60/50Hz, Curvature 3000R
43" - SVA, 8-bit, 60/50Hz, Curvature 3000R
Picture Quality Index - 1600
65" - Direct led
55" - Direct Led
49" - Direct Led
43" - Direct Led
55"-
49"-
43"-
65" -
55" -
49" -
43" -
65" -
55" -
49" -
43" -
65" - Game mode
55" - Game mode
49" - Game mode
43" - Game mode
Quad Core
16_DTV_JazzL
1 x USB 3.1
1 x Ethernet RJ45
1 x AV Composite In 3.5mm jack
1 x V Component In 3.5mm jack
1 x RS 232 C
1 x CI+ 1.3
Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth ver. 4.0
Wi-Fi Direct
DLNA(RUI2.0/DTCP-IP/DMP/DMR/DMS)DVB -T/ T2/C/S/S2
with PVR function
DiSEqC version 1.0
Analog (PAL,SECAM)
HEVCKU6600 KU6500
(curved)
78", 65", 55", 49", 43"No No 78" - max
65" - max
55" - max 290cd/m2 / SD- 290cd/m2
49" - max
43" - max
Compatible78" - VA, 8-bit, Hz?, Curvature 4200R
65" - VA, 8-bit, Hz?, Curvature 4200R
55" - VA, 8-bit, 60/50Hz, Curvature 4200R
49" - VA, 8-bit, 60/50Hz, Curvature 3000R
43" - VA, 8-bit, 60/50Hz, Curvature 3000R
Picture Quality Index 1600
78" - Direct led
65" - Direct Led
55" - Direct Led
49" - Direct Led
43" - Direct Led
PWM Freq,-120/100Hz78"-
65"-
55"-
49"-
43"-
78" -
65" -
55" -
49" -
43" -
78" -
65" -
55" -
49" -
43" -
78" - Game mode
65" -
55" -
49" -
43" -
Quad Core
16_DTV_JazzL
1 x Ethernet RJ45
4 x HDMI 2.0 (ARC, CEC)
1 x CI+ 1.3
Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 ac
Bluetooth ver. 4.0
Wi-Fi Direct
with PVR function
DiSEqC version 1.0
Analog (PAL,SECAM)
HEVCKU6500 KU6400
65", 55", 49", 43", 40"No No 65" -
55" -
49" -
43" -
40" -
Compatible65" - VA, 8-bit, ?Hz
40" - VA, 8-bit, 60/50Hz
Motion Interpolation (30fps)
Picture Quality Index 1500
65" - Edge Led
55" - Edge Led
49" - Edge Led
43" - Edge Led
40" - Edge Led
NO Local Dimming
55"-
49"-
43"-
40"-
65"-
55"-
49"-
43"-
40"-
65"-
55"-
49"-
43"-
40"-
65" -
55" -
49" -
43" -
40" -
16_DTV_JazzL
1 x Ethernet RJ45
1 x CI+ 1.3Lan
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 ac
Bluetooth ver. 4.0 HID
Wi-Fi Direct
DLNA
DVB - T/T2/C/S/S2
with PVR function
DiSEqC version 1.0
Analog (PAL,SECAM)
HEVCKU6400 KU6300
(curved)
65", 55", 49", 43", 40"No No 78" -
65" -
55" - max 440cd/m2
49" -
43" -
Compatible
65" - VA, 8-bit, 60/50Hz, Curvature 4200R
55" - VA, 8-bit, 6050/Hz, Curvature 4200R
40" - VA, 8-bit, 60/50Hz, Curvature 3000R
Picture Quality Index 140065" - Led
55" - Direct Led ?
49" -
43" -
40" -
NO Local Dimming
PWM Freq,-120/100Hz65" -
55" -
49" -
43" -
40" -
65" -
55" - 4508:1 /108.2cd/m2 / 0.024cd/m2
49" -
43" -
40" -
65" -
55" -
49" -
43" -
40" -
65" -
55" - 19.8ms
49" -
43" -
40" -
16_DTV_JazzL
1 x Ethernet RJ45
1 x CI+ 1.3Lan
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 ac
Wi-Fi Direct
DLNA
DVB -T/ T2/C
Analog (PAL,SECAM)
HEVCKU6300 KU6100
(curved)
55" -
49" -
43" -
40" -
Compatible65" - VA, 8-bit, ?Hz, Curvature 4200R
Picture Quality Index 130065" - Edge Led
55" -
49" -
43" -
40" -
NO Local Dimming
55" -
49" -
43" -
40" -
65" -
55" -
49" -
43" -
40" -
65" -
55" -
49" -
43" -
40" -
65" -
55" -
49" -
43" -
40" -
16_DTV_JazzL
1 x Ethernet RJ45
1 x CI+ 1.3Lan
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
Bluetooth
Wi-Fi Direct
DLNA
DVB -T/ T2/C
Analog (PAL,SECAM)
HEVCKU6100 KU6000
70", 65", 60", 55", 50", 49", 43", 40"No No Compatible 70" - VA, 8-bit, ?Hz
65" - VA, 8-bit, ?
60" - VA, 8-bit, ?
50" - VA, 8-bit, 60/50Hz
Picture Quality Index 130070" - Edge Led
65" - Edge Led
60" - Edge Led
55" - Edge Led
50" - Edge Led
49" - Edge Led
43" - Edge Led
40" - Edge Led
NO Local Dimming
PWM Freq,-120/100Hz70"-
65"-
60"-
55"-
50"-
49"-
43"-
40"-
70"-
65"-
60"-
55"-
50"-
49"-
43"-
40"-
70"-
65"-
60"-
55"-
50"-
49"-
43"-
40"-
70" -
65" -
60" -
55" -
50" -
49" -
43" -
40" -
16_DTV_JazzL
1 x Ethernet RJ45
1 x CI+ 1.3Lan
a/b/g/n
Wi-Fi Direct
DLNA
DVB - T/T2/C
with PVR function
Analog (PAL,SECAM)
HEVCKU6000 Samsung FHD TV 2016  Product____________Certification
UHD
Premium
_____Dolby
Vision
_____HDR
__________________________Videopanel
_______________________________ Backlight___________________
Dimming Color Space___________________________ Contrast & Black level____________________________
Viewing angle
____________Input
Lag
________SoC
Platform
OS
Out-of-the-Box
(score out of 10)
___________Product K6500
55", 49", 40"No No No 55" - VA, 8-bit, 120/100Hz
49" - VA, 8-bit, 120/100Hz
40" - VA, 8-bit, 120/100Hz
Picture Quality Index55" - Edge Led
49" - Edge Led
40" - Edge Led
55" -
49" -
40" -
55" -
49" -
40" -
55" -
49" -
40" -
55" -
49" -
40" -
16_DTV_HawkM
Tizen 2,4 OSВluеtооth Vеr. 4.0 HID Lan
a/b/g/n
Wi-Fi Direct
DLNA
DVB -T/ T2/C
with PVR function
Analog (PAL,SECAM)K6500 K6300
(curved)
55", 49", 40"No No No 55" - , 8-bit, 60/50Hz
49" - , 8-bit, 60/50Hz
Picture Quality Index 80055" - Edge Led
49" - Edge led
40" - Edge Led55" -
49" -
40" -
55" -
49" -
40" -
55" -
49" -
40" -55" -
49" -
40" --
16_DTV_HawkM
a/b/g/n
Wi-Fi Direct
DLNA
BluetoothDVB - T/T2/C
Analog (PAL,SECAM)K6300 K6000
70",65", 60",55", 50", 43", 40"No No No 70" -
60" - VA, 8-bit, 60/50Hz
50" - , 8-bit, 60/50Hz
43" - , 8-bit, 60/50Hz
40" - VA, 8-bit, 60/50 Hz
60" - Edge Led
55" - Edge Led
50" - Edge Led
43" - Edge Led
40" - Edge Led70" -
65" -
60" -
55" -
50" -
43" -
40" -70" -
65" -
60" -
55" -
50" -
43" -
40" -70" -
65" -
60" -
55" -
50" -
43" -
40" -70" -
65" -
60" -
55" -
50" -
43" -
40" --
16_DTV_HawkM
a/b/g/n
Wi-Fi Direct
DLNA
Analog (PAL,SECAM)K6000 K5600
55", 49", 40", 32"No No No 55" - 8-bit, 60/50Hz
32" - 8-bit, 60/50Hz
Picture Quality Index 40055" - Edge Led
49" - Edge Led
40" - Edge Led
32" - Edge Led55" -
49" -
40" -
32" -55" -
49" -
40" -
32" -55" -
49" -
40" -
32" -55" -
49" -
40" -
32" --
16_DTV_HawkM
-Вluеtооth Vеr. 4.0 HID Lan
a/b/g/n
Wi-Fi Direct
DLNA
DVB - T/T2/C
Analog (PAL,SECAM)K5600 K5500
55", 49", 40", 32"No No No 55" - , 8-bit, 60/50Hz
32" - , 8-bit, 60/50Hz
49" - Edge Led
40" - Edge Led
32" - Edge Led55" -
49" -
40" -
32" -55" -
49" -
40" -
32" -55" -
49" -
40" -
32" -55" -
49" -
40" -
32" --
16_DTV_HawkM
a/b/g/n
Wi-Fi Direct
DLNA
DVB - T/T2/C
Analog (PAL,SECAM)K5500 K5100
40"No No No 40" - VA, 8bit, 60/50Hz
Picture Quality Index 20040" - Edge Led 40" - 40" - 40" - Вluеtооth Vеr. 4.0 HID Lan
a/b/g/n
Wi-Fi Direct
DLNA
DVB - T/T2/C
Analog (PAL,SECAM)K5100
Няма много мнения за това ТВ из нета, гледам в БГ и Румъния ги има. Има ли разлика с този http://www.technopolis.bg/bg/TV/TV-S...HD-LED/p/15986
Някои ако даде повече инфо и мнение ще го бива ли това да каже.Благодаря предварително.
SAMSUNG UE-49KU6672 - Flat + дистанционно с гласов контрол
SAMSUNG UE-49KU6502 - Curved
+ разлика в стойката
Gamme Samsung LED 2016 - line-up - LCD Compare
Samsung KS9800 Series HDR LED TV Review - Reviewed.com Televisions
Колеги реших да взема http://www.technopolis.bg/bg/TV/TV-S...HD-LED/p/15988 интересува ме крачетата на тв може ли да се движат,тоес да се преместят с една идея по навътре и какво е разстоянието между тях че никъде не намирам информация?Благодаря,гледам че няколко колеги тук имат въпросния модел ще съм благодарен ако споделят мнение.:)
Приятно ползване на новата придобивка! С каква версия на HDMI е телевизора?
Sent from my K00Z using Tapatalk
Не би трябвало да има. Но на one connect box -a имаш оптичен аудио изход. Ползвай него. Ако нямаш възможност не знам от къде можеш да се сдобиеш но има цифров към аналогов адаптер... (Между другото трябва да има и 2х 3.5 входа но мисля, че те са компонент и композит, огледай до тях какво има но мисля, че няма...)
The JS7000 offers 4 HDMI 2.0 inputs – all of which are HDCP 2.2 compliant
Под оптиката за звук е и жака за слушалки.
