Модем ти си https://edigital.bg/led-televizori/t...h-suhd-p424030
Един въпрос към притежателите на смарт ТВ Самсунг от последните модели - смарт дистанционното има ли движещ се по екрана курсор , както на тези от по-предни модели ?
Според тази таблица https://onedrive.live.com/view.aspx?...CyyhTEAhWJJTbU кс 7002 е със 10 битов панел. Това така ли е?
На много места пише 10 битов,ама Hristoslav казва 8(по памет) и съм склонен да му вярвам.
За разлика от KS8000 който е с 10 битов и двойно по-висок контраст,а пък повечето(вкл.Hristoslav) казват,че няма голяма разлика в картината.Тук давам какво пише за двата модела в av forums
KS7000
Black Levels and Contrast Ratios
The KS7000 uses a VA LCD panel, so we would expect a decent black level performance compared to an IPS LCD panel. So it proved with the Samsung delivering a native black level measurement of 0.033nits with the Smart LED local dimming off and 0.002nits with it in the low setting. We set our calibrated SDR mode to 120nits, which the KS7000 had no trouble delivering, and this resulted in an on/off contrast ratio of 4,000:1 and an ANSI contrast ratio of 3,140:1. These are excellent results for an LCD panel and the impressive performance continued when it came to HDR, with the KS7000 hitting a peak brightness of 1,500nits on a 10% window and 537nits on a 100% full screen. This proves that the KS7000 can easily achieve the minimum dynamic range of 0.05 to 1,000 nits required for Ultra HD Premium certification.
KS8000
The KS8000 uses a VA panel and, like Samsung's other SUHD TVs this year, it delivers a very impressive black level measurement of 0.015 nits with the local dimming off and 0.001 nits with it in the low setting. The TV is also bright, easily hitting our target of 120 nits and, as mentioned in the HDR section, delivering a peak brightness of over 1,300 nits. As a result the on/off contrast ratio with the local dimming off was 8,000:1 and the ANSI contrast ratio was 2,800:1, both of which are impressive for an LCD TV.
Вижда се,че контраста е 2 пъти по-добър.Гледал съм ги само на светло в магазините и не мога да кажа дали на практика ще има значителни различия.
И още нещо.По рано на страницата на SAMSUNG за 7 серия пишеше следното:
''Потопете се по-дълбоко в съдържанието
Auto Depth Enhancer (Автоматично увеличаване на дълбочината) прилага различни нива на контраст към различните зони от екрана, за да придаде невероятна дълбочина на изображението. Изпитайте какво означава да гледаш телевизия, като се потапяш в действието.''
Сега го няма.Нещо не ми е ясно,това рекламен трик ли беше има ли го или не и в кои модели точно?
Благодаря колега, но тези са базирани в Будапеща, Унгария, сервиза им също е там, и доста голям зор би видял човек да му изпълнят гаранционни условия.
Моля, някой който е поръчвал от Емаг телевизор, да сподели впечатления (за колко време идва, изглежда ли ползван и т.н.).
В гаранционните им условия на сайта пише-до най-близкия гар. сервиз(разбирам в бг) или до централен сервиз в Будапеща за тяхна сметка.Ако искаш питай на посочения бг телефон и кажи кво са отговорили.Пък и вероятността такъв тв да се развали няма да казвам на каква е.
Таблицата е правена от руският ми колега AlexSSS2
Телевизоры Samsung 2016 года. FAQ в первом сообщении темы. [33] - Конференция iXBT.com
той тепърва тръгва по моят път, така че очаквайте грешки - вярва на официалната информация
в KS7000 - панела е 8-bit + FRC (Frame Rate Control)
Видима разлика между 10-bit и 8-bit + FRC с невъоръжено око трудно ще видиш.
cable
Контрастът няма общо с битността на панела.
Той може да зависи от куп неща
- тип матрица
- тип подсветка и нейната максимална яркост
- наличие на локално затъмняване и типа реализация
- настройки в сервизното меню
Вероятно през 2017 година , в 7-ма серия ще има 10-битов панел
Не знам дали моделите на Samsung поддържат HLG...затова няма такава колонка.
Samsung European UHD TV 2016 Product____________ Certification UHD_________
Premium
Dolby Vision_____
HDR 10The metadata is graded and determined, and is then sent
____________________
at the beginning of the file
and covers the entire file.
One set of metadata
Standard: Open
Peak Luminance: Up to 4,000 nits
Video Bit Depth: 10-bit
Metadata: Static (per title)
Software Upgradability: Yes
Videopanel____________________________________
Type LCD matrix,
Bits of color,
Operating frequency of T-Con board of the panel,
Curvature,
MEMC,
Index,
Anti-reflective filter Backlight______________________
Type backlight
(Local Dimming zone)
Type LED
Puls Wide Modulation Color Space_____________________
DCI P3
Rec.2020 Contrast________________________
White & Black level
ANSI
With local dimming
Without local dimming Viewing___________
angle Input Lag_______________________
SoC
CPU
GPU
Platform
OS
_____________ Ports_____________________ Networks_______________________ Tuner_________________Picture Accuracy
Out-of-the-Box
(score out of 10)
_______________Product KS9800
(curved)
88"
Technically it is a KS9500 – just larger and with a slightly different design.
Yes No 88" - max-1250 cd/m²
Yes HDR1088"- SVA,10bit ?, 120/100Hz, Curvature 4200R
BFI - Scaning Backlight (Led Clear Motion)
Picture Quality Index - 2600
Moth Eye (anti-reflective filter)88" - FALD, Direct Led
? - Local Dimming zones
Blue Leds with RG phosphorus
PWM Freq,-120/100Hz88"-DCI P3- 96% / Rec.2020-
Quantum Dots88" - 88" - 88"- Game mode 2 -
ARMv7
Cortex-A7
Quad Core 1.2GHz
16_DTV_JazzM
Tizen 2,4 OS2 x USB 2.0
1 x USB 3.1
4 x HDMI 2.0 (ARC, CEC,MHL)
1 x Satelite In (Main: F-type female)
1 x Satelite In (Sub:F-type female)
1 x Optical Audio Out
1 x RS 232 C
1 x Antena (RF) (female)
One Connect
1 x USB
1 x Ethernet RJ45
1 x CI+ 1.3
in TVLan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct, Screen Mirroring
Bluetooth
DLNA(RUI2.0/DTCP-IP/DMP/DMR/DMS)Dual tuners
DVB -T/ T2/C/S/S2
with PVR and PIP function + Timeshift
DiSEqC version 1.0
Analog (PAL,SECAM)
HEVCKS9800 KS9500
(curved)
78", 65", 55"Yes No 78" - max 1000cd/m²
65" - 10% window max - 1473cd/m2
100% window max - 615cd/m2
55" - max 1000cd/m
Yes HDR10
Delta E <1 of all levels of brightness78"- SVA, 10bit, 120/100Hz, Curvature 4200R
65"- SVA, 10bit, 120/100Hz, Curvature 4200R
55"- SVA, 10bit, 120/100Hz, Curvature 4200R
BFI - Flashing Backlight (Led Clear Motion)
Picture Quality Index - 2700
Moth Eye (anti-reflective filter)78" - FALD,
65" - FALD, 15x10 - 150 zones
55" - FALD, 12x8 - 96 zones
PWM Freq. - 120/400Hz78"- DCI P3 - / Rec.2020
65"- DCI P3 - 96% / Rec.2020-72%
55"- DCI P3- 96% / Rec.2020- 72%
Quantum Dots78" -
65" - SD - ANSI 3783:1 / 120cd/m2 / 0.014cd/m2
with local dimming - 8571cd/m2 / 0.001cd/m2
55" -78" -
65" - 60° (cone)
55" -
78"- Game mode 21ms / by default
65"- Game mode 20ms /
55"- Game mode 20ms /
ARMv7
Quad Core
1.2GHz
16_DTV_JazzM
1 x USB 3.1
1 x Ethernet RJ45
1 x RS 232 C
in One Connect
1 x USB
1 x Ethernet RJ45
1 x CI+ 1.3
1 x One Connect Port
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
DVB -T/ T2/C/S/S2
DiSEqC version 1.0
Analog (PAL,SECAM)
HEVC
VP9 profile 2CMS
White balansKS9500 KS9000
(curved)
78", 65", 55", 49"Yes No 75" - max-1000cd/m2
65" - max-1197cd/m2/ SD- 460cd/m2
55" - max-1000cd/m
49" - max 520cd/m2 full display / 1550cd/m2 for 3 sekonds /
Yes HDR100075"- SVA or AMVA, ? ,120/100Hz,
49"- SVA, 10bit, 120/100Hz, Curvature 3000R
Picture Quality Index - 2400
Moth Eye (anti-reflective filter)75" -
65" - Edge LED - below
55" - Edge Led
8 vertical columns of dimmable zones
49" - Edge Led
PWM Freq,-120/100Hz75"- DCI P3 - 96% / Rec.2020-
49"- DCI P3- 96% / Rec.2020- 76%
Quantum Dots75" - 3000:1
65" -
55" - 2688:1 / 0.039cd/m2
49" - ANSI 2900:1 /
75" -
65" -
55" - 20° (cone)
49" -
75" - Game mode 21ms / by default -
65" - Game mode 20ms / by default -
55" - Game mode 20ms / by default -
49" - Game mode 20ms / by default -
ARMv7
Quad Core
1.2Ghz
16_DTV_JazzM
1 x USB 3.1
4 x HDMI 2.0 (ARC, CEC, MHL)
1 x RS 232 C
in One Connect
1 x USB
1 x CI+ 1.3
1 x Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
DVB -T/ T2/C/S/S2
DiSEqC version 1.0
Analog (PAL,SECAM)
HEVC
VP9 profile 2 Rec.2020 settings are not correctKS9000 KS8000
75", 65", 55", 49"Yes No 75" - max
65" - 10% window max 766cd/m2
55"- 2% window max 1410cd/m2
100% window max 490cd/m2
49" - max 1270cd/m2 /SD- 450cd/m2
The TV is able to maintain the maximum brightness for a short time, and after about 15 seconds it drops down to about 450cd/m2.
Yes HDR1000
75"- SVA or AMVA, 10-bit , 120/100Hz
In service menu - 55A1MU0QK
Picture Quality Index 2300
Moth Eye (anti-reflective filter)75" - Edge Led - below
20 vertical columns of dimmable zones
65" - Edge Led.
16 vertical columns of dimmable zones
55"- Edge Led,
12 vertical columns of dimmable zones
49" - Edge Led
PWM Freq,-120/100Hz75" - DCI P3 -
65" - DCI P3 -
55" - DCI P3- 93% / Rec.2020- 70%
49" - DCI P3 -
Quantum Dots75" -
65" - 4018:1 / 0.034cd/m2 / 167cd/m2
55" - 6820:1 /0.014cd/m2 / 95.48cd/m2
49" - 4080:1 / 0.027cd/m2 /
75" -
65" -
55" - 20° (cone)
49" -
75" - Game mode 20ms / by default - 120ms
65" - Game mode 20ms / by default - 120ms
49" - Game mode 21ms / by default - 120ms
ARMv7
Quad Core
1.2GHz
16_DTV_JazzM
1 x USB 3.1
1 x RS 232 C
in One Connect Box Mini
1 x USB
1 x CI+ 1.3
1 x Ethernet RJ45
in TV
Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth
DVB -T/ T2/C/S/S2
with PVR and PIP function + Tmeshift
DiSEqC version 1.0
Analog (PAL,SECAM)
HEVC
VP9 profile 2KS8000 KS7500
(curved)
65", 55", 49", 43"Yes? No 65" - max
55" - max 1185cd/m² - 1600cd/m2
49" - max
43" - max
Yes HDR100065" - SVA, 8-bit+FRC, 120/100Hz, 4200R
55" - SVA, 8-bit+FRC, 120/100Hz, 4200R
49" - SVA, 8-bit+FRC, 120/100Hz, 3000R
43" - AMVA3, 8-bit+FRC, 120/100Hz, 3000R
PQI - 2000 [43"] / 2200 [≥49"]
Moth Eye (anti-reflective filter)65" - Edge LED - below
(55"- 8 vertical columns of dimmable zones)
49" -
43" -
PWM Freq,-120/100Hz65"- DCI P3- / Rec.2020-
49"- DCI P3- / Rec.2020-
43"- DCI P3- / Rec.2020-
Quantum Dots65" -
55" - ANSI 4000:1/0.03-0.043cd/m2
native 2600:1 /0.046cd/m2/120cd/m2
49" -
43" -
65" -
55" - 30° (cone)
49" -
43" -
65" - Game mode 21,8ms
55" - Game mode 21.7ms / by default
49" - Game mode 21.5ms
43" - Game mode 21 ms
ARMv7
Quad Core
1GHz
16_DTV_JazzM
1 x USB 3.1
1 x USB
1 x Ethernet RJ45
1 x CI+ 1.3
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
Bluetooth, Screen Mirroring
DVB -T/ T2/C/S/S2
DiSEqC version 1.0
Analog (PAL,SECAM)
HEVC
VP9 profile 2Vertical Blooming
Variable depth of black in HDR mode
Sometimes black in HDR mode is approximately 0.20cd/m², which is comparable to the black level of the panel IPS!KS7500 KS7000
65", 60", 55", 49"Yes ? No 65" - max-1000cd/m²
60" - max-1000cd/m2
55" - 10% window max-1402d/m2/
100% window max - 537cd/m2
SD - 486cd/m2
49" - max-1000cd/m2
60" - SVA, 8-bit+FRC, 120/100Hz
Picture Quality Index - 2100
Moth Eye (anti-reflective filter)65" - Edge Led - below
60" - Edge Led - below
(55"- Edge led - below
49"' - Edge Led - below
60"- DCI P3- / Rec.2020-
55"- DCI P3- 96% / Rec.2020- 71%
Quantum Dots65" -
60" -
55" - native - 4000:1 / 138cd/m2/0.033cd/m2
ANSI 3140:1 / with local dimming 0.002cd/m2
49" -
65" -
60" -
55" - 20° (cone)
49" -
65"- Game mode
60"- Game mode
55"- Game mode 21ms / by default 112ms
49"- Game mode 20ms /
ARMv7
Quad Core
1GHz
16_DTV_JazzM
1 x USB 3.1
3 x HDMI 2.0 (ARC, CEC)
1 x RS 232 C
1 x USB
1 x Ethernet RJ45
1 x CI+ 1.3
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth ver. 4.0
DLNA(RUI2.0/DTCP-IP/DMP/DMR/DMS)DVB - T/T2/C/S/S2
with PVR function
DiSEqC version 1.0
Analog (PAL,SECAM)
HEVC
VP9 profile 2The HDR EOTF was extremely good but the colour gamut wasn't tracking Rec.2020 correctly. Vertical Blooming
Sometimes black in HDR mode is approximately 0.20cd/m², which is comparable to the black level of the panel IPS!KS7000 KU6600
(curved)
65", 55", 49", 43"No No 65" -
55" -
49" -
43" -
Compatible65" - SVA, 8-bit, ?Hz, Curvature 4200R
55" - SVA, 8-bit, 60/50Hz, Curvature 4200R
49" - SVA, 8-bit, 60/50Hz, Curvature 3000R
43" - SVA, 8-bit, 60/50Hz, Curvature 3000R
Picture Quality Index - 1600
65" - Direct led
55" - Direct Led
49" - Direct Led
43" - Direct Led
55"-
49"-
43"-
65" -
55" -
49" -
43" -
65" -
55" -
49" -
43" -
65" - Game mode
55" - Game mode
49" - Game mode
43" - Game mode
Quad Core
1GHz
16_DTV_JazzL
1 x USB 3.1
1 x Ethernet RJ45
1 x AV Composite In 3.5mm jack
1 x V Component In 3.5mm jack
1 x RS 232 C
1 x CI+ 1.3
Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 n 5GHz
802.11 ac
Bluetooth ver. 4.0
Wi-Fi Direct
DLNA(RUI2.0/DTCP-IP/DMP/DMR/DMS)DVB -T/ T2/C/S/S2
with PVR function
DiSEqC version 1.0
Analog (PAL,SECAM)
HEVCKU6600 KU6500
(curved)
78", 65", 55", 49", 43"No No 78" - max
65" - max
55" - max 290cd/m2 / SD- 290cd/m2
49" - max
43" - max
Compatible78" - VA, 8-bit, Hz?, Curvature 4200R
65" - VA, 8-bit, Hz?, Curvature 4200R
55" - VA, 8-bit, 60/50Hz, Curvature 4200R
49" - VA, 8-bit, 60/50Hz, Curvature 3000R
43" - VA, 8-bit, 60/50Hz, Curvature 3000R
Picture Quality Index 1600
78" - Direct led
65" - Direct Led
55" - Direct Led
49" - Direct Led
43" - Direct Led
PWM Freq,-120/100Hz78"-
65"-
55"-
49"-
43"-
78" -
65" -
55" -
49" -
43" -
78" -
65" -
55" -
49" -
43" -
78" - Game mode
65" -
55" -
49" -
43" -
Quad Core
16_DTV_JazzL
1 x Ethernet RJ45
4 x HDMI 2.0 (ARC, CEC)
1 x CI+ 1.3
Lan - Ethernet RJ45
Wi-Fi
802.11 a
802.11 b
802.11 n
802.11 ac
Bluetooth ver. 4.0
Wi-Fi Direct
with PVR function
DiSEqC version 1.0
Analog (PAL,SECAM)
HEVCKU6500 KU6400
65", 55", 49", 43", 40"No No 65" -
55" -
49" -
43" -
40" -
Compatible65" - VA, 8-bit, ?Hz
40" - VA, 8-bit, 60/50Hz
Motion Interpolation (30fps)
Picture Quality Index 1500
65" - Edge Led
55" - Edge Led
49" - Edge Led below
43" - Edge Led below
40" - Edge Led below
NO Local Dimming
55"-
49"-
43"-
40"-
65"-
55"-
49"-
43"-
40"-
65"-
55"-
49"-
43"-
40"-
65" -
55" -
49" -
43" -
40" -
16_DTV_JazzL
1 x Ethernet RJ45
1 x CI+ 1.3Lan
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 ac
Bluetooth ver. 4.0 HID
Wi-Fi Direct
DLNA
DVB - T/T2/C/S/S2
with PVR function
DiSEqC version 1.0
Analog (PAL,SECAM)
HEVCKU6400 KU6300
(curved)
65", 55", 49", 43", 40"No No 78" -
65" -
55" - max 440cd/m2
49" -
43" -
Compatible
65" - VA, 8-bit, 60/50Hz, Curvature 4200R
55" - VA, 8-bit, 6050/Hz, Curvature 4200R
40" - VA, 8-bit, 60/50Hz, Curvature 3000R
Picture Quality Index 140065" - Led
55" - Direct Led ?
49" -
43" -
40" -
NO Local Dimming
PWM Freq,-120/100Hz65" -
55" -
49" -
43" -
40" -
65" -
55" - 4508:1 /108.2cd/m2 / 0.024cd/m2
49" -
43" -
40" -
65" -
55" -
49" -
43" -
40" -
65" -
55" - 19.8ms
49" -
43" -
40" -
16_DTV_JazzL
1 x Ethernet RJ45
1 x CI+ 1.3Lan
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 ac
Wi-Fi Direct
DLNA
DVB -T/ T2/C
Analog (PAL,SECAM)
HEVCKU6300 KU6100
(curved)
55" -
49" -
43" -
40" -
Compatible65" - VA, 8-bit, ?Hz, Curvature 4200R
Picture Quality Index 130065" - Edge Led
55" -
49" -
43" -
40" -
NO Local Dimming
55" -
49" -
43" -
40" -
65" -
55" -
49" -
43" -
40" -
65" -
55" -
49" -
43" -
40" -
65" -
55" -
49" -
43" -
40" -
16_DTV_JazzL
1 x Ethernet RJ45
1 x CI+ 1.3Lan
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
Bluetooth
Wi-Fi Direct
DLNA
DVB -T/ T2/C
Analog (PAL,SECAM)
HEVCKU6100 KU6000
70", 65", 60", 55", 50", 49", 43", 40"No No Compatible 70" - VA, 8-bit, ?Hz
60" - VA, 8-bit, ?Hz
50" - VA, 8-bit, 60/50Hz
Picture Quality Index 130070" - Edge Led
65" - Edge Led
60" - Edge Led
55" - Edge Led
50" - Edge Led below
NO Local Dimming
PWM Freq,-120/100Hz70"-
65"-
60"-
55"-
50"-
49"-
43"-
40"-
70"-
65"-
60"-
55"-
50"-
49"-
43"-
40"-
70"-
65"-
60"-
55"-
50"-
49"-
43"-
40"-
70" -
65" -
60" -
55" -
50" -
49" -
43" -
40" -
16_DTV_JazzL
1 x Ethernet RJ45
1 x CI+ 1.3Lan
a/b/g/n
Wi-Fi Direct
DLNA
DVB - T/T2/C
with PVR function
Analog (PAL,SECAM)
HEVCKU6000 Samsung FHD TV 2016 Product____________Certification
UHD
Premium
_____Dolby
Vision
_____HDR
_______________Videopanel
(type matrix, bit, curvature)
_______________________________ Backlight___________________
Dimming Color Space___________________________ Contrast & Black level____________________________
Viewing angle
____________Input
Lag
________SoC
Platform
OS
__________ Ports_____________________________ Networks_______________________________ Tuner_________________Picture Accuracy
Out-of-the-Box
(score out of 10)
___________Product K6500
55", 49", 40"No No No 55" - VA, 8-bit, 120/100Hz
49" - VA, 8-bit, 120/100Hz
40" - VA, 8-bit, 120/100Hz
Picture Quality Index55" - Edge Led
49" - Edge Led
40" - Edge Led
55" -
49" -
40" -
55" -
49" -
40" -
55" -
49" -
40" -
55" -
49" -
40" -
16_DTV_HawkM
Tizen 2,4 OSВluеtооth Vеr. 4.0 HID Lan
a/b/g/n
Wi-Fi Direct
DLNA
DVB -T/ T2/C
with PVR function
Analog (PAL,SECAM)K6500 K6300
(curved)
55", 49", 40"No No No 55" - , 8-bit, 60/50Hz
49" - , 8-bit, 60/50Hz
Picture Quality Index 80055" - Edge Led
49" - Edge led
40" - Edge Led55" -
49" -
40" -
55" -
49" -
40" -
55" -
49" -
40" -55" -
49" -
40" --
16_DTV_HawkM
a/b/g/n
Wi-Fi Direct
DLNA
BluetoothDVB - T/T2/C
Analog (PAL,SECAM)K6300 K6000
70",65", 60",55", 50", 43", 40"No No No 70" -
60" - VA, 8-bit, 60/50Hz
50" - , 8-bit, 60/50Hz
43" - , 8-bit, 60/50Hz
40" - VA, 8-bit, 60/50 Hz
60" - Edge Led
55" - Edge Led
50" - Edge Led
43" - Edge Led
40" - Edge Led70" -
65" -
60" -
55" -
50" -
43" -
40" -70" -
65" -
60" -
55" -
50" -
43" -
40" -70" -
65" -
60" -
55" -
50" -
43" -
40" -70" -
65" -
60" -
55" -
50" -
43" -
40" --
16_DTV_HawkM
a/b/g/n
Wi-Fi Direct
DLNA
Analog (PAL,SECAM)K6000 K5600
55", 49", 40", 32"No No No 55" - 8-bit, 60/50Hz
32" - 8-bit, 60/50Hz
Picture Quality Index 40055" - Edge Led
49" - Edge Led
40" - Edge Led
32" - Edge Led55" -
49" -
40" -
32" -55" -
49" -
40" -
32" -55" -
49" -
40" -
32" -55" -
49" -
40" -
32" --
16_DTV_HawkM
-Вluеtооth Vеr. 4.0 HID Lan
a/b/g/n
Wi-Fi Direct
DLNA
DVB - T/T2/C
Analog (PAL,SECAM)K5600 K5500
55", 49", 40", 32"No No No 55" - , 8-bit, 60/50Hz
32" - , 8-bit, 60/50Hz
49" - Edge Led
40" - Edge Led
32" - Edge Led55" -
49" -
40" -
32" -55" -
49" -
40" -
32" -55" -
49" -
40" -
32" -55" -
49" -
40" -
32" --
16_DTV_HawkM
a/b/g/n
Wi-Fi Direct
DLNA
DVB - T/T2/C
Analog (PAL,SECAM)K5500 K5100
40"No No No 40" - VA, 8bit, 60/50Hz
Picture Quality Index 20040" - Edge Led 40" - 40" - 40" - Вluеtооth Vеr. 4.0 HID Lan
a/b/g/n
Wi-Fi Direct
DLNA
DVB - T/T2/C
Analog (PAL,SECAM)K5100
hristoslav.
знам,че контраста няма нищо общо с битността на панелите,но има много общо с качеството на изображението,поне за мен един от най-важните показатели който се виижда с невъоръжено око много добре за разлика от други.Това е основното предимство на OLED технологията за която трябва да дадем доста пари.Така,че въпросът ми беше дали наистина има осезателна разлика в контраста,защото ти както и в много други ревюта намират картината в 7 и 8 серия почти идентични.Разкиката в битността не съм сигурен,че ще разбера ,но двойна разлика в контраста със сигурност.
Картината е идентична, тъй като в двете серии се използват еднакви шасита и софтуер - различни са само видео панелите.
Хм - тест за интернет скорост на KS7000
Телевизоры Samsung 2016 года. FAQ в первом сообщении темы. [35] - Конференция iXBT.com
Като гледам рекламата в сайта различното при 8 серия е:
Supreme UHD Dimming
(Върховно UHD затъмняване)
Цветовите блокове на екрана се анализират независимо, за да се получи реалистично качество на изображението. Благодарение на оптимизираните цветове и контраст любимото ви телевизионно шоу никога не е изглеждало толкова добре.
....каквото и да значи това
Офф - не се връзвай на рекламните глупости. :)
65KS8000 - има Edge Led с 8 вертикални колони на локално затъмняване
65KS9000 - има Edge Led с 8 вертикални колони на локално затъмняване
65KS9500 - Direct led със 150 зони на локално затъмняване
65JS9000 - Direct led със 150 зони на локално затъмняване
Не се вързвам много.Затова питах дали според теб данните за контраста наAV forums са верни,Не съм срещал другаде(не че и всичко съм прочел де).Освен това не мога да си представя как на тв с edge led ги правят тези зони,ако не са само вертикални(или може би от която страна е подсветката)
Сега се сетих да проверя данните които дават за 9 серия:
.Premium certified TV possesses great contrast and so the KS9000 does, with a calibrated On/Off ratio of 3,783:1 and an ANSI of around 2,900:1, in SDR mode. We should also make mention of the Moth Eye filter the 65KS9000 has equipped which does a really good job of rejecting ambient light and maintaining those impressive looking blacks, in challenging conditions.
Така,че нещо не ми се вързва 8 да е с такъв изумителен контраст,както са го написали.
В ревютата, замерват контраста
- с изключено локално затъмняване
- с включено локално затъмняване
- ANSI контраст (шахматна таблица)
- и напоследък в режим HDR...
За теб като потребител..зрител е важен ANSI, тъй като максимално наподобява телевизионната картина която гледаш.. На екрана има едновременно светли и тъмни зони.
Докато при първите два, се замерва нивото на "черното" при черна заливка и максималната яркост при бяла заливка. Това обаче не е обичайната картина при гледане на филми или каквото и да било друго - в тях няма чисто бели или чисто черни кадри.
Утре отивам да купувам и все още имам големи колебания между 55KS7000 и 55KS8000. Разлика в цената 540 лева.
55KS7000 - краката му имат много голямо разстояние един от друг и ще ми създадат допълнителен проблем/разходи, защото трябва да му мисля нов шкаф или захващне за стена. Гледах също и че масово хората се оплакват от разлепяне на задния панел, което не ме радва хич.
55KS8000 - 10 бит-а панел (каквото и значение да има), по-добър саунд и по-добро качество на изработка + веднага мога да го сложа на шкафа, стойката е идеална. Не изгарям от желание да давам 540 лева повече, но ако го разделя примерно на 7-8 години са едно нищо.
Ще го гледам от 2.30 метра, това как ви се струва? Голямо ли идва?
Какво мислите колеги?
