Тест и преглед на телевизор Samsung 55QN91B
https://geex.x-kom.pl/recenzje/test-...msung-55qn91b/
https://www.youtube.com/watch?v=1WS2hj8uZ70Цитат:
We review the Samsung QE65QN95C "Neo QLED" mini LED FALD LCD tv, comparing it to the QE55S90C RGB QD-OLED in many aspects of picture quality.
Our review sample is the 65-inch Samsung QE65QN95C, but our findings should also apply to the 55-inch QE55QN95C, 75-inch QE75QN95C & 85-inch QE85QN95C.
HDR : 2056 nits (cd/m²) on a 10% window and 711 nits (cd/m²) full field, after calibration to D65 White point.
QE65QN95C has 1344 independently dimmable zones in a 48 times 28 grid representing almost twice the number of local dimming zones on last year's QN95B.
https://www.youtube.com/watch?v=o1WEvSe4M9AЦитат:
Some 4K HDR footage of the Samsung QE55S90C RGB QD-OLED vs the Samsung QE65QN95C "Neo QLED" mini LED FALD LCD tv, filmed using a Sony A7S3 + Sony FE 24mm f1.4 G-Master lens.
A Sony BVM-HX310 mastering monitor was used as reference in some scenes.
This video was graded & uploaded in HDR10, and so is best watched on a compatible HDR display.
Здравейте
Освен мини леда и баса, има ли някаква друга разлика ? Цената е горе- долу една и съща.
https://www.displayspecifications.com/bg/model/e6272ad0
Samsung QE65S90C review
https://hdtvpolska.com/test-recenzja...na/?showfull=1
S90C 55' и 65', продавани в момента, имат стария панел от 2022 г., същия като този на S95B
https://www.youtube.com/watch?v=91KaTKmSfzghttps://www.youtube.com/watch?v=VgCox8QGR7w
https://www.youtube.com/watch?v=HzarBsPa61Ehttps://www.youtube.com/watch?v=028fzNjWGcM
S95B срещу S95C
https://www.rtings.com/tv/tools/comp...threshold=0.10
Samsung QE65S95C (GQ65S95C german market) test
https://www.computerbild.de/artikel/...-35895553.html
На гърба на Samsung S95C, освен специалния порт за 2,50-метровия кабел за свързване с One-Connect-Box, има само още един порт: USB-C за уеб камера.
Всички останали връзки се възлагат на One-Connect-Box.
От дясната страна на снимката е специалният кабел за свързване към дисплея.
https://i.computer-bild.de/imgs/1/4/...8f71c1188f.jpg
Според мен, външна кутия на която са изнесени всички връзки е много по-удобна и практична от колкото на гърба на телевизора. Особено, когато монтажа е стенен и телевизора е опрян плътно до стената. А и ако се наложи сервизно обслужване, което не засяга панела, просто трябва да се вземе кутията, без да се разнася панела. Жалко, че на S95B всичко е върху панела.
+1
но при кутията имаме проблем - в кутията, заедно са захранването и мейн борда. Поставя се хоризонтално и съответно няма добро охлаждане, а това съкращава живота на някои компоненти в нея.
Може би трябва, да увеличат размера и поставят вентилатор.
Освен това, кабела свързващ дисплея и кутията е с нестандартни портове. Така в случай, че ти изгори дисплея, не можеш, да ползваш кутията с дисплей от друга марка. Samsung трябва да помислят и за изход със стандартен порт.
Моя Самсунг е с One Connect Box и е невероятно удобно. Мoйта кутия обаче е предишния модел, по-голямата
https://image-us.samsung.com/Samsung...esolution-jpg$
83S90C получи южнокорейски сертификат
Сертификационен номер R-R-SEK-KQ83SC90A
производител Samsung Electronics Co., Ltd.
Страна на издаване Корея, Китай, Унгария, Мексико, Словакия, Виетнам
Дата на сертифициране 2023-06-01
https://dprime.kr/g2/bbs/board.php?b...r&wr_id=243205
Очаква се да бъде пуснат през втората половина на годината(на IFA 2023 през септември), тъй като обикновено се пуска в рамките на три месеца след сертифицирането за радиовълни.
https://www.etnews.com/20230607000032
LG все още няма 83” MLA панел.
https://m.news.nate.com/view/20230602n05083
Samsung не изграждат ново WOLED портфолио от 83" и 77", но допълват съществуващите серии и не е необходимо да ги преименуват напълно. Разликата е в инчовия размер. Това не е нов процес за нито един производител и нормалният купувач не се интересува кой панел има там. Той разглежда дизайна, цената...Цитат:
Известно е, че LG Display е доставил хиляди мостри от 83-инчови OLED панели на Samsung Electronics през април.
По-голям размер в инчове от същото разстояние за гледане носи повече потапяне и изглежда по-ярко. След това разликата от 200 нита в светлината вече не се забелязва. Винаги бих жертвал яркостта за по-голям размер в инча, особено ако остане достъпен. В крайна сметка 97/98" вече е новият висок клас, а 75" и 77" отдавна са само междинен етап под 83/85".
Серия S90C явно ще бъде смесена
QE83S90C - WOLED
QE77S90C - QD OLED - 4859 евро
QE65S90C - QD OLED
QE55S90C - QD OLED
Спецификацията 144Hz също би изключила WOLED за момента (в момента само 138Hz се поддържа в UHD), освен ако Samsung не инсталира свой собствен TCON контролер.
Поне трябва да внимавате с 77S90C, Samsung може да "смеси" WOLED панели тук по всяко време. Също така 77 S90C идва сравнително късно. Причината е очевидна: Броят на 77" панелите все още е ограничен и вие (логично) искате да ги използвате първо за серията S95C, преди да ги "пропилеете" в S90C.
Ако Samsung Display не пуснат другата година QD-OLED с размер 83", то Samsung Electronics може да въведат WOLED+MLA панели 83" в серия S95D
https://news-znds-com.translate.goog..._x_tr_pto=wapp
Test Samsung OLED S90C
https://www.rtings.com/tv/reviews/samsung/s90c-oled
https://www.youtube.com/watch?v=5pP-O9AvlRo
Почнаха циганиите!
И Самсуг започва да пробутва OLED-и с мръсни панели. Ако искам WOLED, ще си купя LG...
https://www.youtube.com/watch?v=GhZkzGX1Kls
Чак пък цигании :) Не им достига ресурс, неслучайно се разбраха с LG. Не е нещо ново, а и в горния пост също има обяснение по темата. Единствената "цигания" от страна на Samsung e, че с години се опитваха да окалят LG за олед-а, то не беше антиреклама, не беше чудо. И накрая какво стана :)
Прозряха истината, май.
Добрата новина е, че WOLED панелите ще се слагат само в ниският клас. Мастър серията и на Самсунг и на Сони, ще е само с QDOLED
Samsung QE65QN90C test
https://hifi.de/test/samsung-qn90c-test-145614
GQ65QN90CATXZG was used. The GQ stands for a model adapted to the german market.
VA panel + viewing angle compensation film, 8 domain,RGB, vertical stripe, mini-LED LCD FALD, 100/120Hz + MCFI
40 horizontal and 18 vertical zones=720 independently dimmable zones.
