Отговор: Samsung телевизори 2020
  lrn
пиши за кой модел става въпрос и дай снимка. Иначе  на първо четене изглежда проблем с подсветката.
Samsung QE55Q80TA review
 https://www.homecinemamagazine.nl/20...serie-qled-tv/
Made in Hungary
Version No: 02/ QT80
Samsung QE65Q80TA test
 https://avmania.zive.cz/samsung-qe65...em-test#part=1
Made in Hungary
Version No: 01/ QT80
Samsung UE55TU7102 test
 https://geex.x-kom.pl/recenzje/samsu...telewizora-4k/
...It is worth noting that we tested the TV in the hardware version No. 2 (Version No. 02). Is there also version 1 in the market in parallel? This is the manufacturer's secret for now...
-frame is metal
UE55TU7102 v. no2: VA panel RGB-vertical stripe,
50/60Hz, LCD,Direct LED, no WCGq HDR10, HLG , HDR10 +
Input lag (ms): 9.3
HDMI : 2
USB : 1
Ethernet : 1
Optical - 1
Headphone : 0
Bluetooth : yes
Wi-Fi : yes
DVB-T2
за 49 инча телевизор кой е най-добрия в момента? Колебая се между Samsung qe49q80t R Sony XG 9005. Сонито е със 100 херцов екран, но е стар модел и е андроида. Самсунга е последен модел, но 60 херцов QLED. Има ли проблем с андроида.Благодаря!
  Samsung QE55Q64TA test
 https://geex.x-kom.pl/recenzje/samsu...lewizora-qled/
...The remote control is metal and it is (except the color) that the QE Q64T series differs from the QE Q60T (the one with the plastic remote control) ...
QE55Q64TA:VA panel-RGB-vertical stripe, Edge(bottom) LED LCD,global dimming, WCG (aka QLED-quantum dot enhancement film)
 https://geex.x-kom.pl/wp-content/upl...ng-55q64ta.jpg
 https://geex.x-kom.pl/wp-content/upl...ga-55q64ta.jpg
 ...therefore I recommend changing the shadow detail option from factory "0" to "3" to recover shadow details...
The TV was brighter than 55TU8502 and in full screen mode I measured the following values:
maximum: 360 cd / m ^ 2 (50/50),
by default 199 cd / m ^ 2 (32/50),
minimum: 14 cd / m ^ 2 (0/50).
The recommended brightness level for home theater SDR (approx. 120 cd / m ^ 2) provides a brightness setting of 21/50.
In HDR mode on the 10% board, the maximum luminance after three minutes of measurement was about 365 cd / m ^ 2.
 https://geex.x-kom.pl/wp-content/upl...ng-55q64ta.png
...Although this is still not enough brightness, it is 73% better than in UE55TU8502, which means that if someone is looking for a better HDR than Crystal UHD models, then in QLED QE55Q64TA it will be found...
...Like the UE55TU8502 , the QE55Q64TA uses a 60Hz class LCD matrix. Despite this, the sharpness of moving images was much higher: 450 lines (out of 1080 maximum). So another point for QLED...
  Здравейте колеги,
имам KS7002, обаче дистанционното е.... абе трудно работи вече, който има такова може да разбере само. Та въпроса ми е, ако въобще някой може да каже дали това дистанционо ще стане намоя модел:
 https://www.ebay.co.uk/itm/Replaceme...97c4%7Ciid%3A1
Модела на дистанционното ми управление е: TM1680A
Или ако мога някое от тези обикновените да си купя и да станат за модела:
  Би трябвало да стават и двете - аз моя го управлявам и със старото от В750
			We review the Samsung Q95T, a 2020 4K QLED TV from the South Korean brand. Topics covered include local dimming, colour accuracy, video processing, motion performance, screen uniformity, HDR and gaming, as well as occasional side-by-side comparison vs Q90R.
Our findings can also be applied to the Q90T which shares the same panel, video processing and software as the Q95T, only without the separate One Connect box.
Our review sample is the 55-inch Samsung QE55Q95T, but the Q95T is also available in larger screen sizes of 65, 75 and 85 inches.
   https://www.youtube.com/watch?v=ne_S8CYKbxU
  Бях решил да пиша отделна тема относно качеството на дистанционните на Самсунг, ама викам може да съм частен случай. Уви, не.
Аз също съм със КС7002 (49 инча) и моето дистанционно е пред разпадане - предния панел вече е почти разлепен. Работи, обаче не е ясно докога.
Като цяло съм изключително разочарован от дистанционните на Самсунг (не знам как е при другите марки). Колкото е по-нов модела толкова е по-зле дистанционното.
Или ще се разлепи или ще му се изтрият надписите на бутоните. На стария телевизор C650, дистанционното не е мръднало. Не стига, че все по-скъпи стават ТВ-тата ами изстискани отвсякъде.
А иначе понеже моето се разлепи баш по време на извънредното положение се наложи да си поръчам оР'гинално, че то и без дистанционно реално оставаш без телевизор.
  Аз ползвам само смарт дистанционното на моя UH6400 вече 4 години и е като ново. Даже и износване по надписите няма.
Sent from my BLA-L29 using Tapatalk
lrn
    За съжаление това е най-грозното и неприятно наистина, все по-скъпи, с все по-ниско качество (говоря и за самите телевизори). При мен бутоните освен че са изтрити, трябва да натискам с неимуверна сила Back или Power бутона докато задейства на 10-я път.
  Преди малко си дадох ясна сметка, че хората с право се оплакват от качеството на съвременните модели.
Ето как изглежда дистанционното управление на модел от 2008 година, който още си работи при мен. Най-странното за мен е, че още е с оригиналните батерии на които пише 08.2010. Работи си без проблем.
Наскоро изхвърлих два телевизора с кинескопи Самсунг от 1993 и Панасоник от 1998 г. И двете дистанционни работеха и бяха без изтрити надписи. Рекордьор за мен си остава дистанционното на аудио система Панасоник, която е от 1996 година и до сега се използва. Работи вече само радиото, но дистанционното също като по-горе е с оригиналните батерии и работи перфектно. Няма изтрити надписи а е ползвано през първите 10 години ежедневно и многократно. https://uploads.tapatalk-cdn.com/202...5072251397.jpghttps://uploads.tapatalk-cdn.com/202...cae5643247.jpg
  Samsung QE65Q74TA (QE65Q70T) тест
 https://geex.x-kom.pl/recenzje/samsu...a-granicznego/
- дистанционното управление е метално. И по този начин серията QE Q74T се различава от "обикновения" QE Q70T (този с пластмасово дистанционно управление.
- версия на хардуер панел № 1 (версия № 01)
QE65Q74TA: panel from service menu 65A1AU7RT, which is of Samsung Display,
Edge (bottom-global dimming ( frame dimming )) LED LCD
 https://geex.x-kom.pl/wp-content/upl...ga-65q74ta.jpg
-The color temperature of white in film mode was 7496K, so it was almost 1000 Kelvin higher than normal.
-I recommend to change the shadow details option from "0" to "3" because the black level is set incorrectly.
-When it comes to luminance, the TV was clearly brighter than 55Q64T, because in full-screen mode I measured the following values:
maximum: 557 cd / m ^ 2 (50/50),
by default 254 cd / m ^ 2 (32/50),
minimum: 19 cd / m ^ 2 (0/50).
The recommended brightness level for SDR home theater (approx. 120 cd / m ^ 2) ensures that the brightness setting is 15/50.
-In HDR mode on the 10% board, the maximum luminance after three minutes of measurement was 556 cd / m ^ 2.
 https://geex.x-kom.pl/wp-content/upl...ng-65q74ta.png
 Motion mapping
In 2019, we could find 120Hz class matrices in Samsung TVs from the RU8002(55" and up) series. Unfortunately, in 2020 Korean product planners decided to "castrate" a series of TVs up to and including Q6xT, which means that we can find 120Hz class matrices only from Q7xT (55" and up). This can be easily seen when a new blur reduction option appears in the menu:
-Μείωση θολότητας (Blur reduction) :ρυθμιστικό αλογορίθμου για τα 100/120Hz
 https://geex.x-kom.pl/wp-content/upl...ng-65q74ta.jpg
Made in Hungary
Дайте едно рамо, че се омотах яко. Значи на баща ми му писна да гледа стария телевизор (тоя с петната, 4-5 поста по-назад и естествено мен пита к'во да вземе.
Изходните филтри са: Най-доброто до около 1500 лв., 49 или 55 инча. Телевизията се гледа през външния модул на виваком, демек като монитор. Ползва и интернета + HBO GO.
Та гледах, гледах и сведох избора до 49(55)Q60R и ако се навие за още 200 лева над бюджета - 49Q70R.
Обаче в сайта на Самсуг има филтър ПРЕМИУМ UHD и излиза в същия ценови клас 49(55)RU8002.
Q-серията доколкото разбрах е доста по-добра картина (общо казано), ама пък с този бюджет сме в ниския клас, пък другия е "премиум".
Кое от двете е по-добро за технически грамотен пенсионер, който после няма да ми пили, че съм му натресъл някаква простотия?
Струва ли си в този диапазон да се ровя и при другите марки?
  Samsung Q800T QLED TV Review
Tested using Methodology v1.5
 https://www.rtings.com/tv/reviews/samsung/q800t
  Samsung QE65Q950TS review
 https://www.homecinemamagazine.nl/20...led-televisie/
QE65Q950T: MVA panel+viewing angle compensation film(new v.2020)+ antireflection filter
Full Array backlight with local dimming . It uses 24 x 14 (336) segments, fewer than the QE Q950R that offered 30 x 16 (480) segments.
100/120H + MCFI
Samsung QE55Q80TA test
 https://geex.x-kom.pl/recenzje/test-...icz-na-oled-y/
-I tested the TV in hardware version No. 1 (Version No. 01)
QE55Q80TA:VA panel-RGB-vertical stripe
Full Array backlight local dimming,50 zones in a 5 x 10 layout (five horizontally and ten vertically)
LED LCD
WCG (aka quantum dot enhancement film-marketing term QLED)
100/120Hz + MCFI + Flashing Backlights
