Страница 12 от 89 ПърваПърва ... 210111213142262 ... ПоследноПоследно
Резултати от 166 до 180 от общо 1324
Like Tree257Одобрявам
    #166
    Отговор: Samsung телевизори 2020
    lrn
    пиши за кой модел става въпрос и дай снимка. Иначе на първо четене изглежда проблем с подсветката.
    Samsung QE55Q80TA review
    https://www.homecinemamagazine.nl/20...serie-qled-tv/
    Made in Hungary
    Version No: 02/ QT80
    Samsung QE65Q80TA test
    https://avmania.zive.cz/samsung-qe65...em-test#part=1
    Made in Hungary
    Version No: 01/ QT80
    Samsung UE55TU7102 test
    https://geex.x-kom.pl/recenzje/samsu...telewizora-4k/
    ...It is worth noting that we tested the TV in the hardware version No. 2 (Version No. 02). Is there also version 1 in the market in parallel? This is the manufacturer's secret for now...
    -frame is metal
    UE55TU7102 v. no2: VA panel RGB-vertical stripe,
    50/60Hz, LCD,Direct LED, no WCGq HDR10, HLG , HDR10 +
    Input lag (ms): 9.3
    HDMI : 2
    USB : 1
    Ethernet : 1
    Optical - 1
    Headphone : 0
    Bluetooth : yes
    Wi-Fi : yes
    DVB-T2
    Този пост е редактиран от hristoslav2; 10-06-20 в 23:23.
    DOLBY VISION 4K одобрява това.
    Jul 2009
    #167
    за 49 инча телевизор кой е най-добрия в момента? Колебая се между Samsung qe49q80t R Sony XG 9005. Сонито е със 100 херцов екран, но е стар модел и е андроида. Самсунга е последен модел, но 60 херцов QLED. Има ли проблем с андроида.Благодаря!
    #168
    Samsung QE55Q64TA test
    https://geex.x-kom.pl/recenzje/samsu...lewizora-qled/
    ...The remote control is metal and it is (except the color) that the QE Q64T series differs from the QE Q60T (the one with the plastic remote control) ...
    QE55Q64TA:VA panel-RGB-vertical stripe, Edge(bottom) LED LCD,global dimming, WCG (aka QLED-quantum dot enhancement film)
    ...therefore I recommend changing the shadow detail option from factory "0" to "3" to recover shadow details...
    The TV was brighter than 55TU8502 and in full screen mode I measured the following values:
    maximum: 360 cd / m ^ 2 (50/50),
    by default 199 cd / m ^ 2 (32/50),
    minimum: 14 cd / m ^ 2 (0/50).
    The recommended brightness level for home theater SDR (approx. 120 cd / m ^ 2) provides a brightness setting of 21/50.
    In HDR mode on the 10% board, the maximum luminance after three minutes of measurement was about 365 cd / m ^ 2.
    ...Although this is still not enough brightness, it is 73% better than in UE55TU8502, which means that if someone is looking for a better HDR than Crystal UHD models, then in QLED QE55Q64TA it will be found...
    ...Like the UE55TU8502 , the QE55Q64TA uses a 60Hz class LCD matrix. Despite this, the sharpness of moving images was much higher: 450 lines (out of 1080 maximum). So another point for QLED...
  5. Member Аватара на brabusbg
    Nov 2010
    #169
    Здравейте колеги,
    имам KS7002, обаче дистанционното е.... абе трудно работи вече, който има такова може да разбере само. Та въпроса ми е, ако въобще някой може да каже дали това дистанционо ще стане намоя модел:
    https://www.ebay.co.uk/itm/Replaceme...97c4%7Ciid%3A1
    Модела на дистанционното ми управление е: TM1680A
    Или ако мога някое от тези обикновените да си купя и да станат за модела:
    Този пост е редактиран от brabusbg; 16-06-20 в 12:01.
    #170
    Би трябвало да стават и двете - аз моя го управлявам и със старото от В750
    #171
    We review the Samsung Q95T, a 2020 4K QLED TV from the South Korean brand. Topics covered include local dimming, colour accuracy, video processing, motion performance, screen uniformity, HDR and gaming, as well as occasional side-by-side comparison vs Q90R.
    Our findings can also be applied to the Q90T which shares the same panel, video processing and software as the Q95T, only without the separate One Connect box.
    Our review sample is the 55-inch Samsung QE55Q95T, but the Q95T is also available in larger screen sizes of 65, 75 and 85 inches.
  9. lrn
    lrn е офлайн
    Member
    #172
    Бях решил да пиша отделна тема относно качеството на дистанционните на Самсунг, ама викам може да съм частен случай. Уви, не.
    Аз също съм със КС7002 (49 инча) и моето дистанционно е пред разпадане - предния панел вече е почти разлепен. Работи, обаче не е ясно докога.
    Като цяло съм изключително разочарован от дистанционните на Самсунг (не знам как е при другите марки). Колкото е по-нов модела толкова е по-зле дистанционното.
    Или ще се разлепи или ще му се изтрият надписите на бутоните. На стария телевизор C650, дистанционното не е мръднало. Не стига, че все по-скъпи стават ТВ-тата ами изстискани отвсякъде.
    А иначе понеже моето се разлепи баш по време на извънредното положение се наложи да си поръчам оР'гинално, че то и без дистанционно реално оставаш без телевизор.
    Jun 2012
    #173
    Аз ползвам само смарт дистанционното на моя UH6400 вече 4 години и е като ново. Даже и износване по надписите няма.
    Sent from my BLA-L29 using Tapatalk
  11. Member Аватара на brabusbg
    Nov 2010
    #174
    Цитат Първоначално публикувано от lrn Виж публикацията
    За съжаление това е най-грозното и неприятно наистина, все по-скъпи, с все по-ниско качество (говоря и за самите телевизори). При мен бутоните освен че са изтрити, трябва да натискам с неимуверна сила Back или Power бутона докато задейства на 10-я път.
  12. Junior Member
    Sep 2008
    #175
    Преди малко си дадох ясна сметка, че хората с право се оплакват от качеството на съвременните модели.
    Ето как изглежда дистанционното управление на модел от 2008 година, който още си работи при мен. Най-странното за мен е, че още е с оригиналните батерии на които пише 08.2010. Работи си без проблем.
    Наскоро изхвърлих два телевизора с кинескопи Самсунг от 1993 и Панасоник от 1998 г. И двете дистанционни работеха и бяха без изтрити надписи. Рекордьор за мен си остава дистанционното на аудио система Панасоник, която е от 1996 година и до сега се използва. Работи вече само радиото, но дистанционното също като по-горе е с оригиналните батерии и работи перфектно. Няма изтрити надписи а е ползвано през първите 10 години ежедневно и многократно.
    #176
    Samsung QE65Q74TA (QE65Q70T) тест
    https://geex.x-kom.pl/recenzje/samsu...a-granicznego/
    - дистанционното управление е метално. И по този начин серията QE Q74T се различава от "обикновения" QE Q70T (този с пластмасово дистанционно управление.
    - версия на хардуер панел № 1 (версия № 01)
    QE65Q74TA: panel from service menu 65A1AU7RT, which is of Samsung Display,
    Edge (bottom-global dimming ( frame dimming )) LED LCD
    -The color temperature of white in film mode was 7496K, so it was almost 1000 Kelvin higher than normal.
    -I recommend to change the shadow details option from "0" to "3" because the black level is set incorrectly.
    -When it comes to luminance, the TV was clearly brighter than 55Q64T, because in full-screen mode I measured the following values:
    maximum: 557 cd / m ^ 2 (50/50),
    by default 254 cd / m ^ 2 (32/50),
    minimum: 19 cd / m ^ 2 (0/50).
    The recommended brightness level for SDR home theater (approx. 120 cd / m ^ 2) ensures that the brightness setting is 15/50.
    -In HDR mode on the 10% board, the maximum luminance after three minutes of measurement was 556 cd / m ^ 2.
    Motion mapping
    In 2019, we could find 120Hz class matrices in Samsung TVs from the RU8002(55" and up) series. Unfortunately, in 2020 Korean product planners decided to "castrate" a series of TVs up to and including Q6xT, which means that we can find 120Hz class matrices only from Q7xT (55" and up). This can be easily seen when a new blur reduction option appears in the menu:
    -Μείωση θολότητας (Blur reduction) :ρυθμιστικό αλογορίθμου για τα 100/120Hz
    Made in Hungary
  15. lrn
    lrn е офлайн
    Member
    #177
    Дайте едно рамо, че се омотах яко. Значи на баща ми му писна да гледа стария телевизор (тоя с петната, 4-5 поста по-назад и естествено мен пита к'во да вземе.
    Изходните филтри са: Най-доброто до около 1500 лв., 49 или 55 инча. Телевизията се гледа през външния модул на виваком, демек като монитор. Ползва и интернета + HBO GO.
    Та гледах, гледах и сведох избора до 49(55)Q60R и ако се навие за още 200 лева над бюджета - 49Q70R.
    Обаче в сайта на Самсуг има филтър ПРЕМИУМ UHD и излиза в същия ценови клас 49(55)RU8002.
    Q-серията доколкото разбрах е доста по-добра картина (общо казано), ама пък с този бюджет сме в ниския клас, пък другия е "премиум".
    Кое от двете е по-добро за технически грамотен пенсионер, който после няма да ми пили, че съм му натресъл някаква простотия?
    Струва ли си в този диапазон да се ровя и при другите марки?
    Този пост е редактиран от lrn; 20-06-20 в 21:02.
    #178
    lrn одобрява това.
  17. Senior Member Аватара на cable
    Dec 2010
    #179
    Samsung Q800T QLED TV Review
    Tested using Methodology v1.5
    https://www.rtings.com/tv/reviews/samsung/q800t
    #180
    Samsung QE65Q950TS review
    https://www.homecinemamagazine.nl/20...led-televisie/
    QE65Q950T: MVA panel+viewing angle compensation film(new v.2020)+ antireflection filter
    Full Array backlight with local dimming . It uses 24 x 14 (336) segments, fewer than the QE Q950R that offered 30 x 16 (480) segments.
    100/120H + MCFI
    Samsung QE55Q80TA test
    https://geex.x-kom.pl/recenzje/test-...icz-na-oled-y/
    -I tested the TV in hardware version No. 1 (Version No. 01)
    QE55Q80TA:VA panel-RGB-vertical stripe
    Full Array backlight local dimming,50 zones in a 5 x 10 layout (five horizontally and ten vertically)
    LED LCD
    WCG (aka quantum dot enhancement film-marketing term QLED)
    100/120Hz + MCFI + Flashing Backlights
  1. Samsung телевизори 2019
    Отговори: 493
    Последно: 29-01-20, 08:06
  2. Samsung телевизори 2017
    Отговори: 1079
    Последно: 01-01-18, 06:34
  3. Samsung телевизори 2016
    Отговори: 821
    Последно: 01-01-17, 17:42
  4. Samsung Телевизори 2015
    Отговори: 1121
    Последно: 02-01-16, 09:17
    Последно: 21-10-14, 23:00
