В rtings го дават с 120hz панел а тук по форума казват че е с 50. Кое е вярно някой знае ли?
е то тук в таблиците го дават с edge led, a на сайта на сони е с direct led :)
KD-65X9005C: IPS panel (ANSI contrast: 662:1, Black level: 0.198 cd / m2), 100Hz with MCFI + flashing backlight.
XBR-55X810C (KD-55X8005C Europe): VA panel, 100Hz with MCFI + flashing backlight (Motionflow XR 200Hz).
KD-49X8005C specs: IPS panel, 100Hz with MCI + flashing backlight.
48W705C: VA panel, 50Hz + flashing backlight
Under AIDA64 for Sony Bravia Android tvs 2015 series, KDL-W75xC, KDL-W80xC, KDL-W85xC.
CPU: Dual-core ARM Cortex-A17 (32-bit ARMv7), MediaTek MT5890,
GPU: ARM Mali T624 triple core,
Installed RAM: 2GB
Internal Storage Total Space: 8363 MB
Android TV OS v5.0.2 (Lollipop)
http://www.sony.bg/electronics/telev...specifications
Sony UltraHD TV 2015 Product
____________Videopanel & LCD Type
________________________10bit or 8bit
panel
_______________LCD matrix
Refresh Rate
_______HDR
Support
_______Backlight Type
_________________
Local DimmingWide Color Gamut
Support
________________HDMI 2.0a Inpits
_________HDCP 2.2 Support
________HEVC (H.265)
Decoding
___________Flat or
Curved
______UltraHD Streaming Services Tuner
________________Wi-Fi & Smart TV Picture Accuracy Out-of-the-Box (score out of 10)
_______________Product Sony X9405C
(75")
A-MVA AUO 10bit 100Hz
with MCI + flashing backlightFull 75" FALD (80,areas)
55", 65" Edge Led91% DCI P3
(Quantum Dots)? Yes HEVC[H.265]
VP9Flat Yes Double tuner
DVB-T/T2/C/S2
DiSEqC version 1.0yes
a/ac/b/g/n9 Sony X9405C
(75")
Sony X9305C
(55", 65")T650QVN04.0(A-MVA3 AUO) 10bit*
10-bit driving of an 8-bit LCD panel
(8bit + FRC) Dithering100Hz
with MCI + flashing backlightFull Edge Led
Frame Dimming91% DCI P3
(Quantum Dots)2.0a yes HEVC[H.265]
VP9Flat yes Double tuner
DVB-T/T2/C/S2
a/ac/b/g/nSony X9305C
(55", 65")Sony X9105C
(75")T750QVN01.1 (A-MVA3 AUO) 10bit*
(8bit + FRC) Dithering100Hz Limited Edge Led
Frame DimmingYes
DVB-T/T2/C/S2
a/ac/b/g/nSony X9105C
(75")Sony X9005C
(55", 65")S-IPS LG Display
(55", 65")10bit*
with MCI + flashing backlightLimited Edge Led
Frame DimmingYes
DVB-T/T2/C/S2
a/ac/b/g/nSony X9005C
(55", 65")Sonу
X8509C
X8508C
X8507C
X8505C
(55", 65", 75")T750QVN01.1 (A-MVA3 AUO)
T650QVN04.0 (A-MVA3 AUO)
T550QVN04.0 (A-MVA3 AUO)10bit* 100Hz
Frame Dimming85,3% DCI P3
69,4% Rec.2020
(Quantum Dots)2.0a Yes HEVC[H.265]
DVB-T/T2/C/S2
a/ac/b/g/n8 Sonу X8505C
(55", 65", 75")Sony
X8309C
X8308C
X8307C
X8305C
(43", 49")S-IPS LG Display 8bit 100Hz
with MCI + flashing backlightLimited Dynamic Edge Led
Frame Dimming73.5% DCI P3 2.0 Yes HEVC[H.265]
DVB-T/T2/C/S2
a/ac/b/g/n7 Sony X8305C
(43", 49")Sony X8005C
(49", 55")55" - A-MVA3 AUO
49" - IPS LG Display8bit 100Hz
with MCI + flashing backlightLimited ? Direct Led
Frame DimmingNo 2.0 Yes HEVC[H.265]
VP9Flat Double tuner
DVB-T/T2/C/S2
a/ac/b/g/nSony X8005C
(49", 55")
Real
Refresh RateSamsung
Piqture Quality IndexLG
Picture Mastering IndexSony
MotionFlowPanasonic
Real Motion Rate
Backlight Motion RatePhilips
Picture Motion RateSharp
Active motion50 Hz
50 (1080p)
100 (1080p)
200 (1080p)
400 (1080p)
800 (4k)
900 (4k)
1000 (4k)
1200 (4k)100 (1080p)
300 (1080p)
400 (1080p)
450 (1080p)
800 (1080p)
700 (4k)
900 (4k)
1000 (4k)
1300 (4k)100 (1080p)
200 (1080p)
200 (4k) ??200 RMR (1080p)
400 RMR (1080p)
100 BMR (1080p)
200 BMR (1080p)
200BMR (4k)100 (1080p)
200 (1080p)
400 (4k)
700 (4k)
800 (4k)100 (720p)
100 (1080p)
200 (1080p)100 Hz 800 (1080p)
1300 (4k)
1400 (4k)
1900 (4k)900 (1080p)
1500 (4k)
1600 (4k)800 (1080p)
900 (1080p)
1000 (1080p)
900 (4k)
1000 (4k)400 BMR (1080p)
800 BMR (4k)
1000 BMR (4k)
1600 BMR (4k)500 (1080p)
800 (1080p)
1400 (4k)
1800 (4k)400 (1080p) 200 Hz*
2000 (4k)
2400 (4k)2000 (4k)
2300 (4k)1200 (4k) 2000 (4k 2014)
3000 (4k 2014)2400 (4k) 800 (1080p)
800 (4k)
49" е леко трагичен :)
https://www.youtube.com/watch?v=SS8T5eQaelQ
Поправих таблицата в горният пост.
https://www.youtube.com/watch?v=3_bP1-fhGfQ
Преди малко цъкнах да ми се обнови софтуера на Тв -то и забелязах на черния фон, един пиксел който свети в червено. Тв -то го купих преди няколко дена.Какво мога да направя в случая?
Ако си го купил онлайн,имаш 14 дни за връщане,ако не-7
Действай бързо и късмет
За 1 пиксел, ще го приемат ли?Това влиза в гаранциията, че да го подменят? Да не би да трябва повече броя да са изгорели пиксели?
Преди малко и моя KD-65X8509C се ъпдейтна. Тепърва ще се види какво са променили! :-)
Здравейте. Появиха ли се обещаните функции като картина в картината например и записа на флашка след ъпдейта???
Аз съм с W807C...
Преди да се ъпдейтне бях на 5.1.1 андроид. Вчера ми излезна съобщение, че има нова версия и я сложих. Андроида си е пак 5.1.1, но не съм имал време да видя промените. Вчера след ъпдейта видях в сайта на Сони, че стои още стария ъпдейт от 04.11.2015. Този новия трябва да е от вчера, понеже телевизора вчера го изтегли.
Не. Явно не следиш написаното в темата.
SONY EU | Support - Актуално състояние на многоочаквания ъпдейт на Sony Android TV
SONY EU | Support - Upcoming Services for Sony's Android TV: NETFLIX, BBC iPlayer, Internet browser, YouView etc.
Firmware update PKG2.647_EUA - Sony Bravia Android TV FHD
Firmware update PKG2.647_EUB - Sony Bravia Android TV UHD
Забелязах, че и при телевизорите с андроид има скрито меню "Опции на програмиста" както при телефоните с андроид. Натискате HOME бутона - Настройки - Информация - слизате до Версия и натискате на нея няколко пъти докато изпише "Вие вече сте програмист". Връщате един път назад с Back бутона и слизате два пъти надолу до "Системни предпочитания" и най в дясно се появява нов бутон "Опции на програмиста". Може да се променя скоростта на анимацията при смяна на екраните и доста други. Разгледайте ги ако искате. Дано да не е коментирано преди и да се повтарям!
http://i73.fastpic.ru/thumb/2015/120...49ef7fd91.jpeg http://i73.fastpic.ru/thumb/2015/120...9a54bb201.jpeg http://i75.fastpic.ru/thumb/2015/120...5fca24772.jpeg
