Мисля, че все още никъде ги няма , май есента ще са на пазара - ако не се лъжа, по-назад в темата имаше кога се очакват.
Сега видях, че са пуснали Sony KDL-65W955 на готина цена. Някой има ли впечатления от модела. С моите скромни познания ми се вижда доста добра оферта. Липсата на андроид даже мисля, че е предимство.
Сигурен ли си, че си заслужава ?
Sony KDL55W955/ KDL55W955B (W95) Review
https://www.avforums.com/review/sony...ionAnchor32433Цитат:
There’s just no sugarcoating this: the KDL-55W955B is the worst-performing Sony Bravia flagship HDTV we’ve reviewed in terms of picture quality. It’s a disappointing departure from the excellent heritage of high-end Bravia TVs, all because of the use of IPS-type LCD TV panel that’s notorious for shallow blacks – perhaps it’s a strategic decision by Sony to funnel potential buyers towards the company’s 4K Ultra HD models?
If you can find a set free of the backlight uniformity issues that plagued our sample, and are going to use the television primarily in a bright room, then the KDL-55W955 is not without its virtues. It has great out-of-the-box greyscale accuracy, good colour balance, impressive motion rendition, and first-rate gaming responsiveness. Nevertheless, this year’s midrange Sony W705 and W829, or even better, last year’s top-end Bravia W9 (if you can still find stock) are wiser buys due to their superior contrast performance.
Sony KDL-55W955 : Test complet - Les Numériques
Малко по-добре са спрямо W955. Поне нямат толкова ясно видим клоудинг и слаб контраст.
Ie,rsjd ZD9 (ZD9 in Europe and Z9D in the US. ) ми напомня на една стара технология
https://en.wikipedia.org/wiki/BrightSide_Technologies
През 2011 година демонстрираха нейна професионална версия - пак 16 битов процесинг и яркост от 4000cd/m2
Sony UHD TV 2016 - european models Series
Model
_____________ Certification UHD________
Premium
(1) Dolby Vision____
(2) HDR 10________________
In Windows
2/5/10/20/100% Videopanel_______________________
Type LCD matrix,
Bits of color,
(Operating frequency of T-Con board of the panel)
Curvature,
Index,
Screen Uniformity
Anti-reflective filter Backlight____________________
Type backlight
(Local Dimming zone)
Type LED
MEMC
Backlight Scanning
Black Frame Insertion
Pulsе Wide Modulation Color Space___________________
DCI P3 / Rec.2020 / Delta E Contrast________________________
White & Black level
ANSI
With local dimming
Without local dimming Viewing angle
___________( ° cone) Motion resolution
_____________________Product
_____________ Input Lag___________________________________
Audio_______________________________ SoC_______________________
CPU
GPU
Software
OS Networks____________
Conectors______________________ Tuners______________ Opportunities for_________________________
calibration Note__________________________________________________________________________________
Pros & ContProduct ZD9
(Flat)
KD-100ZD9 (3)
KD-75ZD9
KD-65ZD9
September 2016No Informaly No 100"- max
75"- max 2500cd/m2
65"- max 2500cd/m2
Yes
SMPTE standarts
ST2084, ST 2086
100" - MVA, 10-bit, 120/100Hz
75" - MVA, 10-bit, 120/100Hz
65"- MVA, 10-bit , 120/100Hz
Flat
Motionflow XR 1200
-100" - FALD, 2541zones(77x33) ?
75" - FALD, 1450 zones (58x25) ?
65" - FALD, 798 zones (38x21) ?
Motion Clarity Frame Interpolation
PWM - ?100"- 96% /
75"- 96% /
65"- 96% /
Triluminos Display
phosphorus-based diodes for a wide gamut close to the DCI 4K
(Blue Led + Red/Green phosphorus)
Super Bit Mapping with 14-bit signal processing
(RGB - Led's ??)100" -
75" -
65" - 8000:1 ?
100" - °
75" - °
65" - °
100" -
75" -
65" -
ZD9
100", 75", 65"
September 2016100" - Game mode
75" - Game mode
65" - Game mode
100" - 2x10W + 2x10W RMS
75" - 2x10W + 2x10W RMS
65" - 2x10W + 2x10W RMS
Dolby digital, Dolby Plus, Dolby Pulse
Android 6.0 Marshmallow
Board: SVPDTV16
Core architecture:
CPU:
GPU:
RAM:
Internal storage total space:Lan
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
802.11 ac
WiFi Direct
DLNA
Blietooth Ver.4.12 x USB 2.0 (DC 5V MAX 500mA)
2 x USB 3.0 (DC 5V MAX 900mA)
1 x Ethernet RJ45
4 x HDMI 2.0 (ARC, CEC, MHL)
1 x Satelite In (Main: F-type female)
1 x Satelite In (Sub: F-type female)
1 x SCART
1 x AV Composite In
1 x AV Component In
1 x Optical Audio Out (Video+L/R)
1 x 3.5mm Audio Out (YPbPr+L/R)
1 x Antena (RF) (female)
1 x CI+ 1.3Twin Tuners
DVB-T/T2/C/S/S2
DiSEqC version 1.0
PIP, Timeshift % PVR
MPEG2, MPEG4
HEVC H.265, VP9White balance -
Gamma -
ISF -
3 gamuts (Rec.709, DCI, Rec.2020)
but no CMS (Color Management System) to calibrate these gamutsZD9 XD9405
(Flat)
KD-75XD9405
successor model
X9405CNo Informaly No 75"- max 740cd/m2
100% - 360cd/m2
Yes HDR10
SMPTE standarts
ST2084, ST 208675" - AMVA3, 10-bit, 120/100Hz
Flat
Motionflow XR 1200
Very good; mild darkening along edges on full-field rasters
Semi-mate75" - FALD - 96 zones (12x8)
Backlight Scanning
PWM Freq. 120/100Hz75"- 95.7% /
Triluminos Display
(Blue Led + Red/Green phosphorus)75" - Black(4x4 ANSI) 0.052 cd/m2 with [Auto Local Dimming] on
75" - 67°
75" - 1080 Horizontal Lines
with [MotionFlow] “Clear & Custom“XD9405
75"
наследник на X9405C75" - Game mode 34.9ms / by default 64ms
75" - 2x7.5W + 2x7.5W
2xTweeter (12x85mm)
2xWoofer (65mm)
2 CH Down firing
Bass reflex
DTS
Dolby Digital Plus
Dolby Pulse
Compatibility
Wireless subwoofer (SWF-BR100)Android 5.1.1 Lolipop
Board: SVPDTV
Core architecture:
CPU: SoC: Mediatek MT
GPU: ARM Mali T624 triple core
RAM: 1,5GB
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
DLNA
Bluetooth Ver. 4.12 x USB 2.0 (DC 5V MAX 500mA)
1 x USB 3.0 (DC 5V MAX 900mA)
1 x Ethernet RJ45
4 x HDMI 2.0a (ARC, CEC, MHL)
1 x Satelite In (Main: F-type female)-
1 x SCART
1 x AV Composite In
1 x AV Component In
1 x CI+ 1.3Twin tuners
DVB-T/T2/C/S/S2
DiSEqC version 1.0
PIP, Timeshift & PVR
MPEG2, MPEG4,
HEVC H.265, VP9White balance- 2/10 points
Gamma - 10 points
ISF - no
but no CMS (Color Management System) to calibrate these gamutsThe out-of-the-box image accuracy was excellent before calibration and reference afterwards, with impressive black levels and a highly effective local dimming system. The video processing was also very good, as was the motion handling and the XD94 delivered the goods with both standard and high definition content. Sadly the Sony wasn't as impressive when it came to 3D, with excessive crosstalk ruining an otherwise good image. The HDR performance was largely very good with a great dynamic range and a decent level colour accuracy. However the peak brightness was limited to around 760nits, which would explain why the XD94 doesn't have Ultra HD Premium certification and the display was also clipping test patterns and certain HDR 10 content. XD94 XD9305(4)
(Flat)
KD-65XD9305
KD-55XD9305
successor model X9305CNo No 65"- 1098cd/m2
2% - 1045cd/m2
5% - 1153cd/m2
10% - 740cd/m2
50% - 550cd/m2
387cd/m2 (SD)
55"- 1265cd/m2
2% - 987cd/m2
50% - 650cd/m2
Yes HDR10
SMPTE standarts
ST2084, ST 2086
65" - AMVA3, 8-bit+FRC, 120/100Hz
55" - AMVA3, 8-bit+FRC, 120/100Hz
Flat
MotionFlow XR 1000
Light bleed from 4 corners; one faint thin vertical band
Semi-mate65"- Edge Led (8x4) 38 zones
55"- Edge Led (7x4) 28 zones
Edge led - Left & Right side
Horizontal Dimming
PWM Freq. 120/100Hz65"- 94.7% / 72.1% / Delta E 1.3
55"- 88.0% / 64.2% / Delta E
Triluminos Display
(Blue Led + Red/Green phosphorus)65" - 4000:1/ 0.036cd/m2
55" - 2600:1/ 0.046cd/m2
with Local Dimming - 0.01cd/m2
65" - 45°
55" - 32°
65" - 1080 Horizontal Lines
55" - 1080 Horizontal Lines
with [MotionFlow] "Clear & Custom"
Responce Time - 11msXD9305
65" (64.6), 55"
наследник на X9305C65" - Game mode 51.0ms / with MotionFlow 82ms
55" - Game mode 35.7ms / with motionFlow 68ms
65" - 2x7.5W + 2x7.5W
55" - 2x7.5W + 2x7.5W
2xTweeter (12x85mm)
2xWoofer (65mm)
2 CH Down firing
Bass reflex
DTS
Dolby Digital
Dolby Plus
Dolby Pulse
Compatibility
Wireless subwoofer (SWF-BR100)Android TV : 5.1.1 Lolipop
Board : SVPDTV15
2x ARM Cortex-A17 (ARMv7)
Instruction Set : 32-bit ARMv7
CPU SoC:MediaTek MT5890 dual core
GPU:ARM Mali T624 triple core
RAM:1,5GB
Internal storage total space: 8,36GB
Lan
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
DLNA
1 x Ethernet RJ45
1 x SCART
1 x AV Composite In
1 x AV Component In
1 x CI+ 1.3
Twin tuners
DVB-T/T2/C/S/S2
DiSEqC version 1.0
MPEG2, MPEG4
Gamma - 10 points
ISF - no
THX no
but no CMS (Color Management System) to calibrate these gamuts.
There is also adjusting the gamma, black level adjustment, contrast and backlight. The Pro Cinema mode is still the cheapest cardboard output with colorimetry with Delta E average of 1.93, but differences can mount a delta E of 3 in the last gray levels. It can therefore be used like that, without calibration, but for the more demanding it is still advisable to have provided an effective probe, because with so few differences, a cheap probe could do more harm than good.The display also supports HDR10 open-source standard out of the box, with accurate PQ tonemapping (from 4K Blu-ray) and a peak brightness surpassing 1000 nits.
In the Japanese TV maker’s pursuit of ultra-slim aesthetics however, backlight uniformity seemed to have taken a hit: 65XD9305 review sample suffered from flashlighting from all four corners of the screen, although there’s always a chance that other units in the wild may fare better. The Sony XD93 suffers quite marked light leakage in the 4 corners of the slab that degrade color uniformity and the perceived contrast. Twitch gamers will also be disappointed to learn that input lag has increased by 16ms (i.e. one frame) from last year’s Sony Bravia Ultra HD models. As for the UHD upscaling XD93 is simply the best of the market, above the TV Panasonic, LG, Samsung and others. If I had made reservations at the launch of the 2015 range, meanwhile, Sony proposed updates that have greatly improved the quality of upscaling and sharpness of the image. The upscaling offers a very natural, with a rich texture and an image with a dive with great precision. The multimedia part is much too unstable and unusable for my hand by the simple fact that the videos are stretched, distorted and that the demosaicing is not correct.
- + Great picture quality for movies
- + Great motion handling
- + Very bright
- + Image processing
- + One of the best upscaling UHD market
- + Reality Creation: the most efficient video post-processing market
- + Simple calibration, fast and efficient!
- + A more responsive interface, many bugs have been fixed, but there are still too ...
- + HDR better performance than the 2015 X93C
- + Colour rendering and Color Range
- + Dual tuner DVB-T2 / S2 compatible with 4K channels, PVR and PIP functions
- - Local dimming is not always optimal
- - Alternating contrast
- - Blooming
- - too soft slab may be veiled
- - Not enough areas Local Dimming for HDR
- - ABL (Auto Bright Limit) too strong in HDR
- - Inputlag a little too high on 65 "(49.8ms)
- - No ISFccc, or Color Management System (CMS)
- - Still too many bugs with Android TV (videos stretched in multimedia playback, frequent reboot, frequent losses HDMI signal with devices HDCP 1.1, remote control does not respond fairly regularly, concern for synchronizing 3D glasses, saccades with KODI, no bitstream audio with 5.1 KODI, bad die-stamping with videos played via USB / DLNA, HDR mode losses in multimedia playback, etc.
- - Too many applications not optimized for Android TV
- - Lacks a little power for a better experience with Android TV
- - No compatibility Dolby Vision
- - Loss of saturation at an angle
- - Average-high input lag
- - Media player ignores aspect ratio
XD93 SD85
(Curved)
KD-65SD8505
KD-55SD8505
successor model S8505CNo No 65" - max - 450cd/m2
55" - max - 450cd/m2
Yes HDR10
SMPTE standarts
ST2084, ST 208665" - AMVA3, 8-bit+FRC, 120/100Hz
Curvature:
MotionFlow XR 1000
Semi-mate65" - Edge Led (below)
55" - Edge Led (below)
(Blue Led)
Frame Dimming
PWM - ?65"-
55"- 85% / 63%
Triluminos Display
Super Bit Mapping which upsample colors in 16-bit internal processing65" -
55" -
65" - °
55" - °
65" -
55" -
Responce Time - 9.8msSD85
(CURVED)
65", 55"
наследник на S8505C65" - Game mode
55" - Game mode
65" - 2x10W
55" - 2x10W
DTS
Dolby Digital
Dolby Plus
Dolby Pulse
Compatibility
Wireless subwoofer (SWF-BR100); bracket for wall mounting (SU-WL450: 60,20 mm)Android TV : 5.1.1 Lolipop
Board : SVPDTV15
RAM:1,5GB
Internal storage total space: 8,36GBLan
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 ac
Wi-Fi Direct
DLNA
1 x Ethernet RJ45
1 x SCART
1 x AV Composite In
1 x AV Component In
DVB-T/T2/C/S/S2
DiSEqC version 1.0
MPEG2, MPEG4
Gamma - 10 points
ISF - no
THX no
but no CMS (Color Management System) to calibrate these gamutsTV can not solve the very first step also correctly (17/255) SD85 XD85
(Flat)
KD-85XD8505
KD-75XD8505
KD-65XD8505
KD-65XD8577
KD-65XD8599
KD-55XD8505
KD-55XD8577
KD-55XD8588
KD-55XD8599
copy of last year's X850xC, but redesigned with IPS panel and without 3DNo No 85" -
75" -
65" - 400cd/m2
55" - 2% - 369cd/m2
Compatible
HDR Processing
(missing hardware for playback HDR)85" - AS-IPS, 8-bit+FRC, 120/100Hz
75" - AS-IPS, 8-bit+FRC, 120/100Hz
65" - AS-IPS, 8-bit+FRC, 120/100Hz
55" - AS-IPS, 8-bit+FRC, 120/100Hz
Flat
8577/8588/8599 - MotionFlow XR 1000
8505/75"/85"- MotionFlow XR 800
There is no visible difference!
Semi-mate85" - Edge led (below)
75" - Edge Led (below)
Quantum Dots (+ Blue Led)
Frame Dimming
No PWM85"-
75"-
65"-
55"- 86% / 63%
Triluminos Display
Super Bit Mapping which upsample colors in 16-bit internal processing85" -
75" -
65" -
55" - 850:1 / 0.12cd/m2
85" - °
75" - °
65" - °
55" - °
85" -
75" -
65" -
55" -
XD85
(8505, 8577, 8599)
85", 75", 65", 55"
копие на миналогодишният X850xC, но с нов дизайн, с IPS панел и без 3D85" - Game mode 36ms / with MotionFlow 68ms
75" - Game mode 35ms / with MotionFlow 67ms
65" - Game mode 35ms / with MotionFlow 67ms
55" - Game mode 35.5ms / with MotionFlow 66.5ms
85" - 2x10W
65" - 2x10W
55" - 2x10W
Dolby Digital
Dilby Plus
Dolby Pulse
Magnetic Fluid Speaker & Clear Phase
Compatibility
55", 65" - Bracket for wall mounting (SU-WL450)Android TV : 5.1.1 Lolipop
Board : SVPDTV15
RAM:1,5GB
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
DLNA
1 x Ethernet RJ45
1 x SCART
1 x AV Composite In
1 x AV Component In
DVBT/T2/C/S/S2
DiSEqC version 1.0
MPEG2, MPEG4
HEVC H.265White balance- 2/10 points
Gamma - 10 points
ISF - no
THX - no
There are also several preset gamma, black level adjustment, contrast and backlight. The Pro Cinema mode is still the mode plus the near Cinema colorimetry with Delta E of 2.5 average on the gray scale (for rap, below 3 is considered the excesses are not visible) but spreads may rise to 4 in the last gray levels. The color space is also very fair with an average Delta E of 2.8 on the Color Checker and 3.7 on saturations. The average color temperature is 6770K or 6500K very close to the search. Gamma, meanwhile, is 1.8 by default, so more to view in bright room, but as the Advanced Mode Improvement of Contrasts (ACE) is enabled by default, we see that it is not at all linear. Moreover, this measure gamma is interesting because it shows that this mode does not clog blacks, but whites are still burned, so we lose grayscale. That said, calibrating the XD85 we were able to maintain a linear gamma with ACE enabled to Low or Medium. The XD85 can therefore be used like that, without calibration, but for the more demanding it is still advisable to have provided an effective probe, because with so few differences, a cheap probe could do more harm only good.In Europe it will exist in three design variants named
,KD-XD8505B (black) ,KD-XD8577S (silver) , ,KD-XD8588B (black) ,KD-XD8599B (black).
What differences between references XD8505, XD8577 and XD8599? Let me be clear: no! This is simply references marketed only to please some signs that make large volumes of sales, so they do not suffer from competition on the Internet. You will probably see a little difference, often on the index of fluidity XR1000 instead of XR800, but these are purely marketing indices. There is no visible difference between a Motionflow XR800 and XR1000.
ACE (Advanced Contrast Enhancer), the famous setting "Improvement of Advanced Contrast" could be compared to a very efficient dynamic contrast. Still, I always advise to disable dynamic contrasts, but that ACE is not like the others. Note that I do not say it is faultless, but it brings so many dynamics of the image on an IPS panel that is difficult to do without. Moreover, it enables up to 1200: 1 ANSI contrast. Its main strength is that it can offer a hyper dynamic image, without clogging the black (it is the opposite, it opens totally black and greatly improves readability in dark scenes). In lit room or in daylight, the illusion is so perfect, you'd swear that this TV has a contrast very powerful, even more powerful than some VA panels. Better, this ACE is devilishly effective with UHD Blu-ray because it totally transforms HDR rendering. No, the HDR seems bland, uninteresting and bridled, while if it is active, HDR rendering is very nice.
Indeed, despite a very limited coverage Rec.2020, the XD85 offers one of the best colorimetric market through its IPS panel and its algorithm Triluminos remastered colors in Wide Gamut very effectively maintaining a natural. Only the DX900 who offered me a better colorimetry thanks to its LED red phosphorus that help provide intense red that IPS while retaining the advantages of a VA panel. In addition, Sony XD85 offers colorimetry very fair cardboard output and angles very open visions that allow the whole family to enjoy a good image regardless of his place on the couch.
However, this TV is clearly not recommended for those who watch their movies in dark room. Besides, if you watch your movies in darkened room, there is absolutely no reason to buy the XD85, since the X85C offers exactly the same functionality, but with a VA panel and a very good contrast. True, the colors will be slightly less beautiful but dark room contrast is still paramount.
The Sony XD85 is limited to enjoy the UHD Blu-ray, with a slab 8 bit HDR rendering flanged (bright peak at 425 cd / m², whatever the size of the target HDR), but again, the ACE saves setting and can offer an ultra dynamic image, very pleasant to look lit room. Nevertheless, the IPS puts his HDR limits with enough gray black, which can amount to more than 0.30 cd / m² at the brightest images, so again, you better watch Blu-ray UHD illuminated room .
- + Reality Creation: very efficient video post-processing of HD content / UHD
- + one of the best upscaling UHD market
- + Motionflow: best motion compensation market
- + The ACE (Advanced Improvement Contarstes) boosts the dynamics, especially in HDR.
- + A perceived contrast and amazing dynamic to an IPS panel
- + A really beautiful color matching, very fair cardboard output in Rec.709 as HDR
- +Viewing angle twice as wide a VA panel
- +Simple calibration, fast and efficient!
- + ghosting time very good, good precision in movements
- +Inputlag reduced (35ms) + Quick rémance time (9.6ms), excellent for play
- + The possibilities offered by the Android OS TV
- + A more responsive interface, many bugs have been fixed, but there are still ...
- + HDMI 2.0a compatible HDR10, 4K/60, 1080p/120Hz, BT.2020
- + Excellent performances in lit room
- + honorable and good audio quality sound power
- - Contrast too feeble for viewing in dark room
- - Some visible leaks if it is set too high or too low relative to the center of the slab
- - Clouding some, though not visible in lit room
- - average video processing with SD sources
- - Finish and manufacturing quality rather average
- - No Local Dimming
- - The abandonment of 3D on an IPS panel (passive 3D slab UHD is wearing beautiful)
- - A HDR too restrained, too narrow gamut Rec.2020
- - No 10 bit panel
- -Still bugs with Android TV (videos stretched in multimedia playback, reboot, frequent loss of signal with HDMI devices HDCP 1.1, remote control does not respond fairly regularly, saccades with KODI, no audio bitstream with 5.1 KODI)
- -Lacks a little power for a better experience with Android TV
XD85 XD83
(Flat)
KD-49XD8305
KD-43XD8305
No
No
49"
43" -
Compatible
HDR Processing
(missing hardware for playback HDR)49" - AS-IPS, 8-bit+FRC, 120/100Hz
43" - AS-IPS, 8-bit+FRC, 120/100Hz
Flat
MotionFlow XR 800
Semi-mate49" - Edge Led (below)
43" - Edge Led (below)
Phosphorus-based diodes
PWM - ?
49"-
43"-
Triluminos Display phosphorus-based diodes for a wide gamut close to the DCI 4K49" -
43" -
49" - °
43" - °
49" -
43" -
XD83
(flat)
49" - Game mode
43" - Game mode
49" - 2x10W
43" - 2x10W
Dolby Digital
Dolby Plus
Dolby Pulse
Compatibility
Board : SVPDTV15
RAM:1,5GB
Internal storage total space:8,36GBLan
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
DLNA
1 x Ethernet RJ45
1 x SCART
1 x AV Composite In
1 x AV Component In
DVB-T/T2/C/S/S2
DiSEqC version 1.0
MPEG2, MPEG4
Gamma - 10 points
ISF - noTV can not solve the very first step also correctly (17/255) XD83 XD80
(Flat)
KD-55XD8005
KD-49XD8005
KD-43XD8005
No No 55" - max -
49" - max -
43" - max -
Compatible
HDR Processing
(missing hardware for playback HDR)55" - ?, 8-bit+FRC, 60/50Hz
49" - IPS, 8-bit+FRC, 60/50Hz
43" - IPS, 8-bit+FRC, 60/50Hz
Flat
55" - Motionflow XR 400
49 & 43" - Motionflow XR 20055" - Edge Led (below)
PWM - ?55"-
49"-
43"-
Triluminos Display phosphorus-based diodes for a wide gamut close to the DCI 4K55"-
49"-
43"-
55" - °
49" - °
43" - °
55" -
49" -
43" -
XD80
55", 49", 43"55" - Game mode
49" - Game mode
43" - Game mode
55" - 2 x 10W
49" -
43" -
Dolby Digital
Dolby Plus
Dolby Pulse
Mediatek MT5890
2xARM Cortex-A17
ARM mali-624
Storage - 16GB
Android 5.1.1 LolipopLan
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
DLNA
Bluetooth Ver.4.12 x USB 2.0 (DС 5V MAX 500mА)
1 x USB 3.0 (max 0.9A)
1 х Еthеrnеt RJ45
4 х НDМІ 2.0 (АRС,СЕС,MHL)
1 х Ѕаtеlіtе іn(Маіn:F-tуре fеmаlе)->
1 х ЅСАRТ
1 х Соmроѕіtе іn (Vіdео+L/R)
1 х Соmроnеnt іn (YРbРr+L/R)
1 х Орtісаl Аudіо Оut
1 х 3.5mm Аudіо Оut
1 х Аntеnа (RF) (Fеmаlе)
1 х СІ+1.3DVB-T/T2/C/S/S2
DiSEqC version 1.0
MPEG2, MPEG4
HEVC H.265TV can not solve the very first step also correctly (17/255) XD80 SD80
(Curved)
KD-50SD8005
successor model
S8005CNo No 50" - max - 450cd/m2
Compatible
HDR Processing
(missing hardwdre for playback HDR)
(Firmware Update Later)50" - MVA, 8-bit+FRC, 60/50Hz
Curvature:
MotionFlow XR 400
Semi-mate50" - Edge led (below)
PWM - ?50" - 64% /
50"-
50" - °
50" -
SD80
(curved)
50"
наследник на S8005C50" - Game mode
50" - 2x10W
Clear Phase
Dolby Digital
Dolby Plus
Dolby Puls
Compatibility
Wireless subwoofer (SWF-BR100); bracket for wall mounting (SU-WL450: 60,20 mm)Mediatek MT5890
CPU 2xARM Cortex-A17
ARM Mali-624
Storage -
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
DLNA
Bluetooth Ver.4.12 х UЅВ 2.0 (DС5 V МАХ500mА)
1 х Еthеrnеt RЈ45
4 х НDМІ2.0 (АRС,СЕС,MHL)
1 х ЅСАRТ
1 х 3.5mm Аudіо Оut
1 х СІ+1.3Twin tuners
DVB - T/T2/C/S/S2
DiSEqC Version 1.0TV can not solve the very first step also correctly (17/255) SD80 XD75
(Flat)
KD-65XD7505
No No 65" - 500cd/m2
Compatible
HDR Processing
(Firmware Update Later)65" - ? , 8-bit, 120/100Hz
Mitionflow XR 80065" - Direct Led
Phoshorus-based diodes
PWM - ?65" -
65" -
65" - °
65" -
XD75
7505
65"65" - Game mode
65" - 2x10W RMS
Dolby Digital
Dolby Plus
Dolby Puls
Compatibility
CPU 2xARM Cortex-A17 (32 bits ARMv7)
GPU Mali T624 3 Core
Android 5.1Lan
802.11 a
802.11 b
802.11 g
802.11 n
Wi-Fi Direct
DLNA2 x USB 2.0 (DC 5V MAX 500mA)
1 x Ethernet RJ45
1 x SCART
1 x AV Composite In
1 x AV Component In
1 x CI+ 1.3DVB-T/T2/C/S/S2 TV can not solve the very first step also correctly (17/255) XD75 XD70
(Flat)
KD-55XD7005
KD-49XD7005
No No 55" -
49" -
Compatible
HDR Processing
(Firmware Update Later)55" - AS-IPS, 8-bit, 60/50Hz
49" - AS-IPS, 8-bit, 60/50Hz
MotionFlow XR 20055" - Edge Led
49" - Edge Led
PWM - ?55"-
49"-
55"-
49"-
55" - °
49" - °
55" -
49" -
XD70
55", 49"55" - Game mode
49" - Game mode
55" - 2x10W RMS
49" - 2x10W RMS
Clear Phase
Dolby Digital
Dolby Plus
Dolby Puls
Compatibility
Lan
Wi-Fi
802.11 b
802.11 g
802.11 n
Wi-Fi Direct
1 x Ethernet RJ45
1 x SCART
1 x AV Composite In
1 x AV Component In
1 x CI+ 1.3DVB-T/T2/C/S/S2 TV can not solve the very first step also correctly (17/255) XD70
1)Rеѕоlutіоn: 3,840х2,160.
Соlоr dерth: 10-bіt.
Соlоr gаmut: Wіdе, іnсludіng thе аbіlіtу tо ѕhоw аt lеаѕt 90 реrсеnt оf thе Р3 соlоr gаmut .
Ніgh dуnаmіс rаngе: Ѕресіfісаllу thе аbіlіtу tо uѕе ЅМРТЕ ЅТ2084'ѕ еlесtrо-орtісаl trаnѕfеr funсtіоn, whісh Dоlbу hеlреd сrеаtе .
Міnіmum brіghtnеѕѕ аnd соntrаѕt rаtіоѕ: Тhеrе аrе twо роѕѕіblе mіnіmum ѕресѕ. А mіnіmum brіghtnеѕѕ оf 1,000 nіtѕ, аlоng wіth а blасk lеvеl оf а mахіmum оf 0.05 nіtѕ (20,000:1 соntrаѕt rаtіо), оr а mіnіmum brіghtnеѕѕ оf 540 nіtѕ, аlоng wіth а blасk lеvеl оf а mахіmum оf 0.0005 (1,080,000:1)
2)Тhе mеtаdаtа іѕ grаdеd іn еасh ѕсеnе ѕо уоu gеt dіffеrеnt grаdеѕ thrоughоut thе fіlе. Dоlbу tеllѕ uѕ thаt ѕсеnе bу ѕсеnе grаdіng іѕ thе ѕuреrіоr wау tо grаdе а mоvіе, whісh оn рареr dоеѕ ѕоund mоrе еffісіеnt.
Ѕtаndаrd: Рорrіеtаrу
Реаk Lumіnаnсе: Uр tо 10,000 nіtѕ
Vіdео Віt Dерth: 12-bіt
Меtаdаtа: Dуnаmіс (ѕсеnе bу ѕсеnе)
Ѕоftwаrе Uрgrаdаbіlіtу: Nо(ЅоС hаrdwаrе-еmbеddеd)
3) При 100" вариант има възможност за избор - стойка за под или стойка за маса / for the 100” version you have the option between a floor stand and table stand.
4) подсветката в модела XD93 е двойна разположена отляво и отдясно[по две ленти]- така имаме контролирани 4 колони по няколко хоризонтални зони / backlight in model XD93 is a double located left and right [two lanes] - we have 4 columns controlled by several horizontal zones
Може ли да дам едно предложение/съвет относно таблиците ?
Ако е възможно прави таблиците с по-тесни колони , като може горе описанието да го слагаш със звездичка/скобки с номер в пояснение под таблицата - пример :Dolby Vision(2) и съответното обяснение на опцията/функцията под таблицата - (2)- ...... , който не е запознат със значението на съответната функция/опция/съкращение просто ще погледне в обяснението под таблицата. Също мисля е добре в средата на таблиците да има още една колонка за моделите тв .
Струва ми се така ще са по-прегледни и удобни за преглеждане таблиците, че вероятно повечето сме на 15" лаптопи и скролването напред-назад и нагоре-надолу, за да видиш какво поддържа даден модел понякога се получава доста неудобно .
Това са моите предложения - ако е неудобно да ги правиш така или прекалено трудоемко ги пропусни .:) :Drinks:
Това е една от опциите в приложението App Cloner. Отварям ES File Explorer на телефона и на телевизора. Задържам върху запазения файл, избирам Изпрати, избирам телевизора и файлът се прехвърля.
Sent from my Nexus 5 using Tapatalk
Мерси, после ще го пробвам. Някой да сподели какъв браузър ползвате на телевизора. Пробвах с вградения да свалям субтитри от http://subsunacs.net/search.php направо от телевизора, но пробата беше неуспешна. Пробвах да инсталирам google chrome, но не стана. Opera mini се инсталира, но също не успявам да свалям с него. Ползвам Popcorn и понякога субтитрите са от друг филм и трябва да се свалят и да се зареждат от самия телевизор и за това ми трябва. Не, че не мога да си ги сваля на компа и да ги кача на телевизора, но се дразня, че не става.
Uc browser, пробвай него
Инсталирай си Kodi с правилните плъгини и гледането на филми (тип попкорнтайм) и свалянето на субтитри (субс.унакс.бг имат плъгин за Коди) става детска играчка. Пробвах с попкорн.тайм но нещо не ми хареса навигацията с дистанционно/клавиатура. Може да съм попаднал на тъпа версия за тъч скрийн.
svetlio1
Много тежка взе да става таблицата...
Model
________________ Certification UHD________
Premium
In Windows
Type LCD matrix,
Bits of color,
Curvature,
Index,
Screen Uniformity
Type backlight
Type LED
MEMC
Backlight Scanning
Pulsе Wide Modulation Color Space_______________________________
DCI P3 / Rec.2020 / Delta E / Gamma / Temperature Contrast________________________
White & Black level
ANSI
With local dimming
Audio___________________________________ Oparating Sistem___________________________
Board
System on a Chip
Central Processing Unit
Graphic Processor Unit
RAM
Software
Conectors__________________________ Tuners______________ Opportunities for_________________________
(Flat)
KD-100ZD9 (3)
KD-75ZD9
KD-65ZD9
65, 75" - September 2016
100" - December 2016No Informaly No 100"- max 2000cd/m2
75"- max 2000cd/m2
65"- max 2000cd/m2
Yes
SMPTE standarts
ST2084, ST 2086
65"- AMVA3, 10-bit , 120/100Hz
Flat
Motionflow XR 1200
Glossy...
-100" - FALD, 2541 Leds (77x33) ?
75" - FALD, 1450 Leds (58x25) ?
65" - FALD, 798 Leds (38x21) ?
PWM - ?100"- 96% /
75"- 96% /
65"- 96% /
Triluminos Display
75" -
65" - 8000:1 ?
100" - °
75" - °
65" - °
100" -
75" -
65" -
ZD9
100", 75", 65"
75" - Game mode
65" - Game mode
100" - 2x10W RMS
75" - 2x10W RMS
65" - 2x10W RMS
Dolby digital,
Dolby Plus,
Dolby Pulse
DTS
Clear Phase Speaker
Compatibility
Wireless Subwoofer(SWF-BR100);3D Glasses(TDG-BT500A)
65" only - Wallmount Bracket(SU-WL450 without tilt function)Android 6.0 Marshmallow
Board: SVPDTV16
CPU: SoC Mediatek MT5596
Core architecture: 4xCortex A53
Instruction set: 64-bit ARM-A53
Operating at up to 1.1GHz
GPU: Mali-T860 MP2(graphics processor)
RAM:
HEVC/VP9 10-bit color with HDR, up to 4K UHD 60 fps. This is suitable for internet TS/IPTV streams, Netflix or YouTube. Meanwhile worldwide demodulation capabilities include ATSC / DVB / DTMB / ISDBT.
Audio post-processing is powered by a dedicated ARM11 processor with L2 cache and two ADSPs. Its dedicated processor ensures always-ready performance for the latest Dolby MultiStream Decoders MS12 DAPv2 and DTS Studio Sound II (TheaterSound 3D ver 4) that encompasses the breadth of Dolby and DTS consumer audio formats.
Connectivity includes up to four HDMI 2.0 with HDCP2.2/1.4 (including one HDMI2.0 / MHL3 combo port), Wi-Fi (with Google Cast ready receiver), Ethernet and USB 3.0 ports.Lan(100BASE-TX/10BASE-T)
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
802.11 ac
WiFi Direct
DLNA
Blietooth(NFC)Ver.4.1 HID/HOGP/3DSP/SPP2 x USB 2.0 (DC 5V MAX 500mA)
1 x Ethernet RJ45
4 x HDMI 2.0a - HDCP2.2 (ARC, CEC, MHL)
1 x SCART
1 x AV Composite In
1 x AV Component In
1 x Optical Audio Out (AAC/PCM/AC3)
1 x 3.5mm Audio Out
DVB-T/T2/C/S/S2
DiSEqC version 1.0
MPEG2, MPEG4
Gamma -
ISF -
(Flat)
KD-75XD9405
successor model X9405CNo Informaly No 75"- max 740cd/m2
100% - 360cd/m2
Yes HDR10
SMPTE standarts
Flat
Motionflow XR 1200
Backlight Scanning
Triluminos Display
75" - 67°
75"
2xTweeter (12x85mm)
2xWoofer (65mm)
2 CH Down firing
Bass reflex
Dolby Digital
Dolby Plus
Dolby Pulse
DTS
Compatibility
Board: SVPDTV15
Core architecture: 2xARM Cortex 17 (ARMv7)
CPU: SoC: MediaTek MT5890
RAM: 1,5GB
Internal storage total space: 8.36GBLan(100BASE-TX/10BASE-T)
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
DLNA
Bluetooth(NFC)Ver.4.1 HID/HOGP/3DSP/SPP2 x USB 2.0 (DC 5V MAX 500mA)
1 x Ethernet RJ45
1 x SCART
1 x AV Composite In
1 x AV Component In
1 x 3.5mm Audio Out
DVB-T/T2/C/S/S2
DiSEqC version 1.0
MPEG2, MPEG4,
Gamma - 10 points
ISF - no
(Flat)
KD-65XD9305
KD-55XD9305
2% - 1045cd/m2
5% - 1153cd/m2
10% - 740cd/m2
50% - 550cd/m2
387cd/m2 (SD)
55"- 1265cd/m2
2% - 987cd/m2
50% - 650cd/m2
Yes HDR10
SMPTE standarts
ST2084, ST 2086
65" - AMVA3, 10-bit ?, 120/100Hz
55" - AMVA3, 10-bit ?, 120/100Hz
Flat
MotionFlow XR 1000
Horizontal Dimming
PWM Freq. 120/100Hz65"- 94.7% / 72% / Delta E 1.3 /Gamma 2.2 / 7270K
55"- 88.0% / 64% / Delta E
Triluminos Display
65" - 45°
55" - 32°
65" (64.6), 55"
2xTweeter (12x85mm)
2xWoofer (65mm)
2 CH Down firing
Bass reflex
Dolby Digital
Dolby Plus
Dolby Pulse
DTS
Compatibility
Board : SVPDTV15
Core: 2x ARM Cortex-A17 (ARMv7)
CPU SoC: MediaTek MT5890 dual core
RAM: 1,5GB
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
DLNA
1 x Ethernet RJ45
1 x SCART
1 x AV Composite In
1 x AV Component In
1 x 3.5mm Audio Out
1 x CI+ 1.3
Twin tuners
DVB-T/T2/C/S/S2
DiSEqC version 1.0
MPEG2, MPEG4
Gamma - 10 points
ISF - no
THX no
- + Very bright
- - Blooming
XD93 SD85
(Curved)
KD-65SD8505
KD-55SD8505
Yes HDR10
SMPTE standarts
Curvature: 55", 65" - 4200R
MotionFlow XR 1000
(Blue Led)
Frame Dimming
PWM - ?65"- / Delta E 1.8 / Gamma 2.1 / 6685K
55"- 85% / 63%
Triluminos Display
Super Bit Mapping which upsample colors in 16-bit internal processing65" - 3810:1 / 0.04cd/m2
55" -
65" - °
55" - °
65" -
55" -
(CURVED)
65", 55"
наследник на S8505C65" - Game mode - 36ms / with MotionFlow - 64ms
55" - Game mode -
65" - 2x10W
55" - 2x10W
Dolby Digital
Dolby Plus
Dolby Pulse
DTS
Compatibility
Board : SVPDTV15
RAM: 1,5GB
Internal storage total space: 8,36GBLan(100BASE-TX/10BASE-T)
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 ac
Wi-Fi Direct
DLNA
1 x Ethernet RJ45
1 x SCART
1 x AV Composite In
1 x AV Component In
1 x 3.5mm Audio Out
DVB-T/T2/C/S/S2
DiSEqC version 1.0
MPEG2, MPEG4
Gamma - 10 points
ISF - no
THX no
(Flat)
KD-85XD8505
KD-75XD8505
KD-65XD8505
KD-65XD8577
KD-65XD8599
KD-55XD8505
KD-55XD8577
KD-55XD8588
KD-55XD8599
75" -
65" - 400cd/m2
55" - 2% - 369cd/m2
Compatible
HDR Processing
Flat
Frame Dimming
No PWM85"-
75"-
65"-
55"- 86% / 63%
Triluminos Display
75" -
65" -
85" - °
75" - °
65" - °
55" - °
85" -
75" -
65" -
55" -
Responce Time - 9.5msXD85
(8505, 8577, 8599)
85", 75", 65", 55"
85" - 2x10W
65" - 2x10W
55" - 2x10W
Dolby Digital
Dilby Plus
Dolby Pulse
DTS
Compatibility
55", 65" - Bracket for wall mounting (SU-WL450)Android TV : 6.0 Marshmelow
Board : SVPDTV15
RAM:1,5GB
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
DLNA
1 x Ethernet RJ45
1 x SCART
1 x AV Composite In
1 x AV Component In
1 x 3.5mm Audio Out
DVBT/T2/C/S/S2
DiSEqC version 1.0
MPEG2, MPEG4
Gamma - 10 points
ISF - no
THX - no
- + Viewing angle twice as wide a VA panel
- + Inputlag reduced (35ms) + Quick rémance time (9.6ms), excellent for play
- - Average video processing with SD sources
- - No 10 bit panel
- - Still bugs with Android TV (videos stretched in multimedia playback, reboot, frequent loss of signal with HDMI devices HDCP 1.1, remote control does not respond fairly regularly, saccades with KODI, no audio bitstream with 5.1 KODI)
XD85 XD83
(Flat)
KD-49XD8305
KD-43XD8305
No
No
49"
43" -
Compatible
HDR Processing
Flat
MotionFlow XR 800
Frame Dimming
PWM - ?
49" -
43" -
43" -
49" - °
43" - °
49" -
43" -
XD83
(flat)
49" - Game mode
43" - Game mode
49" - 2x10W
43" - 2x10W
Dolby Digital
Dolby Plus
Dolby Pulse
DTS
Compatibility
Board : SVPDTV15
RAM:1,5GB
Internal storage total space:8,36GBLan(100BASE-TX/10BASE-T)
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
DLNA
1 x Ethernet RJ45
1 x SCART
1 x AV Composite In
1 x AV Component In
1 x Optical Audio Out(AAC/PCM/AC3)
1 x 3.5mm Audio Out
DVB-T/T2/C/S/S2
DiSEqC version 1.0
MPEG2, MPEG4
Gamma - 10 points
(Flat)
KD-49XD8099
KD-49XD8005
KD-43XD8077
KD-43XD8005
No No 49" - max -
43" - max -
Compatible
HDR Processing
(missing hardware for playback HDR)49" - AMVA3, 8-bit+FRC, 60/50Hz
43" - AMVA3, 8-bit+FRC, 60/50Hz
Flat
8099 - Motionflow XR 400
8005 - 49 & 43" - Motionflow XR 20049" - Edge Led (below)
PWM - ?49" -
43" -
43" -
49" - °
43" - °
49" -
43" -
XD80
55", 49", 43"49" - Game mode
43" - Game mode
49" -
43" -
Dolby Digital
Dolby Plus
Dolby Pulse
DTS
CPU: Mediatek MT5890
2xARM Cortex-A17
GPU: ARM Mali-624
Storage - 16GB
Android 5.1.1 LolipopLan(100BASE-TX/10BASE-T)
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
DLNA
Bluetooth(NFC)Ver.4.1 HID/HOGP/3DSP/SPP2 x USB 2.0 (DС 5V MAX 500mА)
1 х Еthеrnеt RJ45
4 х НDМІ 2.0 - HDCP2.2 (АRС,СЕС,MHL)
1 х ЅСАRТ
1 х Орtісаl Аudіо Оut(AAC/PCM/AC3)
1 х 3.5mm Аudіо Оut
DiSEqC version 1.0
MPEG2, MPEG4
- -- Media player ignores aspect ratio
XD80 SD80
(Curved)
KD-50SD8005
successor model
Compatible
HDR Processing
(Firmware Update Later)50" - AMVA3, 8-bit+FRC, 60/50Hz
Curvature: 50" - 4200R
MotionFlow XR 400
PWM - ?50" - 64% /
50"-
50" - °
50" -
SD80
(curved)
50"
50" - 2x10W
Clear Phase
Dolby Digital
Dolby Plus
Dolby Puls
DTS
Compatibility
ARM Mali-624
Storage -
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
DLNA
Bluetooth(NFC)Ver.4.1 HID/HOGP/3DSP/SPP2 х UЅВ 2.0 (DС5 V МАХ500mА)
1 х Еthеrnеt RЈ45
1 х ЅСАRТ
1 х 3.5mm Аudіо Оut
DVB - T/T2/C/S/S2
DiSEqC Version 1.0
MPEG2, MPEG4
SD80 XD75
(Flat)
KD-65XD7505
Compatible
HDR Processing
PWM - ?65" -
65" -
65" - °
65" -
XD75
7505
65"65" - Game mode
65" - 2x10W RMS
Dolby Digital
Dolby Plus
Dolby Puls
DTS
Compatibility
Wireless subwoofer (SWF-BR100); bracket for wall mounting (SU-WL450: 60,20 mm)Аndrоіd ТV : 5.1.1 Lоlірор
Воаrd : ЅVРDТV15
2х АRМ Соrtех-А17 (АRМv7)
Іnѕtruсtіоn Ѕеt : 32-bіt АRМv7
СРU ЅоС:МеdіаТеk МТ5890 duаl соrе
GРU:АRМ Маlі Т624 trірlе соrе
RАМ:1,5GВ
Іntеrnаl ѕtоrаgе tоtаl ѕрасе:8,36GВLan
802.11 a
802.11 b
802.11 g
802.11 n
Wi-Fi Direct
1 x Ethernet RJ45
1 x SCART
1 x AV Composite In
1 x AV Component In
MPEG2, MPEG4
HEVC H.265TV can not solve the very first step also correctly (17/255) XD75 XD70
(Flat)
KD-55XD7005
KD-49XD7005
No No 55" -
49" -
Compatible
HDR Processing
49" - Edge Led
PWM - ?55"-
49"-
55"-
49"-
55" - °
49" - °
55" -
49" -
XD70
49" - Game mode
55" - 2x10W RMS
49" - 2x10W RMS
Clear Phase
Dolby Digital
Dolby Plus
Dolby Puls
Compatibility
Lan
Wi-Fi
802.11 b
802.11 g
802.11 n
Wi-Fi Direct
1 x Ethernet RJ45
1 x SCART
1 x AV Composite In
1 x AV Component In
1 x 3.5mm Audio Out
1 x Antena (RF)(female)
1 x CI+ 1.3DVB-T/T2/C/S/S2 TV can not solve the very first step also correctly (17/255) XD70 Series
Model
Premium
In Windows
Type LCD matrix,
Bits of color,
Curvature,
Index,
Screen Uniformity
Type backlight
Type LED
MEMC
Backlight Scanning
White & Black level
ANSI
With local dimming
CPU
GPU
Software
Pros & ContProduct
65" 8x4
2-Led ------1----- ------2----- ------3----- ------4----- 2-Led 2-Led ------3----- 2-Led 2-Led ------4----- 2-Led 2-Led ------5----- 2-Led 2-Led ------6----- 2-Led 2-Led ------7----- 2-Led 2-Led ------8----- 2-Led
:Drinks:
Не съм в час с правенето на таблици, така обаче става по-прегледно . А защо някои полета се получават толкава големи ? Недостатък на софтуера?Цитат:
Адмирации за полагания труд все пак - не всеки би се наел! :god
:029:Въх - не , скролнал съм бил до предпоследната :o - яко :Drinks:
