Пожелавам ти го и дано мине по рано.
Test: Sony KD-55XD8005 - fwd - FWD Magazine
Google превод Ni to Bg
sony-x930d е щатски аналог на европейският - XD930
Sony X930D TV Review - Reviewed.com Televisions
Здравейте.
Предстои ми покупка на телевизор.
Ще го използвам за гледане на цифрова кабелна ТВ, филми на флашка и интернет.
Харесах си следните 2 модела:
http://www.technopolis.bg/bg/TV/TV-S...HD-LED/p/13173
http://www.technopolis.bg/bg/TV/TV-SONY-UHD-KD-43XD8305-Ultra-HD-LED/p/13171
Можете ли да ми кажете кой от тях е по-добрият вариант?
Гледах таблиците тук в форума, но не мога да преценя...
Сравнение по спецификации
Comparaison des produits s
Comparison between: 42.5" Sony KD-43XD8305, 48.5" Sony KD-49XD8099
SONY UHD KD-43XD8305 - матрица S-IPS, 120/100Hz
SONY UHD KD-43XD8077 - матрица A-MVA3, 60/50Hz
Sony UHD TV 2016 - european models Series
Model
_________________ UHD_____
Premium
Dolby Vision____
Hybrid Log Gamma_____
(HLG) HDR 10
3 fundamental HDR
building blocks:
ST2084 (EOTF PQ),
ST2086 (static metadata)
ST2094 (dynamic metadata)
_________________
The measured values of the brightness in Windows
2/5/10/15/20/100% Videopanel_______________________
Type LCD matrix,
Bits of color,
(Operating frequency of T-Con board of the panel)
Curvature,
Index,
Screen Uniformity
Anti-reflective filter Supported Resolutions__________________________
Frame per seconds
24, 25, 30, 50, 60, 100, 120 p/i
Chroma subsampling
4:4:4
4:2:2
4:2:0 Backlight Unit____________________
Type backlight
(Local Dimming zone)
Type LED
MEMC
Backlight Scanning
Black Frame Insertion
Pulsе Wide Modulation Measurements_______________________________
DCI P3
Rec.2020
Delta E
Gamma
Color Temperature Measurements__________________________
ANSI Contrast
With local dimming
Without local dimming
White level
Black level Viewing angle
__________Horizontal & Vertical
(°cone) Motion resolution
_____________________Product
_____________ Input Lag______________________________
Audio___________________________________ Built in Media Player_____________________________
Supported file systems
Image file formats
Audio file formats/codecs
Video file formats
Subtitles Hardware & Software
Operating System
Board
Central Processing Unit
System on Chip
Instruction set
Graphic Processor Unit
RAM
Total memory Networks__________________
Conectors__________________________ Tuners______________ Opportunities for_________________________
calibration Note__________________________________________________________________________________
Pros & ConsProduct XD83
(Flat)
KD-49XD8305
KD-43XD8305
successor model - X830xC
No No No 49"
43" -
Compatible
HDR Processing
(missing hardware for playback HDR)49" - AS-IPS, 8-bit+FRC, 120/100Hz
43" - AS-IPS, 8-bit+FRC, 120/100Hz
Flat
MotionFlow XR 800
Semi-mate4096 x 2160/24P (HDMI 2/3)
3840 x 2160/24P
3840 x 2160/25P
3840 x 2160/30P
3840 x 2160/50P
3840 x 2160/60P
1080 / 60I
1080 / 50I
1080/30P (Only HDMI)
1080/60P (HDMI / Component)
1080/50P (HDMI / Component)
1080/24P (Only HDMI)
720/24P (Only HDMI)
720/30P (Only HDMI)
720 / 50P
720/60P
576 / 50I
576 / 50P
480 / 60I
480 / 60P49" - Edge Led (below)
43" - Edge Led (below)
Phosphorus-based diodes
Frame Dimming
Motion Clarity Frame Interpolation
PWM - ?
49" -
43" - DCI P3 - 93% / rec2020 - 72%
Delta E - 1.62 - 0.32
Gamma - 2.24 - 2.18
Triluminos Display phosphorus-based diodes for a wide gamut close to the DCI 4K49" -
43" - 3877:1 / 100.8cd/m2 / 0.026cd/m2
49" - °
43" - °
49" -
43" -
XD83
(flat)
49" - Game mode
43" - Game mode
49" - 2x10W
43" - 2x10W
Dolby Digital
Dolby Plus
Dolby Pulse
DTS
Magnetic Fluid Speaker & Clear Phase
Compatibility
Wireless subwoofer (SWF-BR100)
55", 65" - Bracket for wall mounting (SU-WL450)FAT16, FAT32, NTFS and exFAT
JPEG, GIF, PNG, MPO
FLAC , M4A, MIDI, MP3, WMA, WAV, LPCM
AVI, DivX, H.263
H.264 / MPEG4 Part 10 / AVC Video
H.265 / MPEG-H Part 2 / HEVC
MKV, Quick Time, M2TS, MP4, WebM, WMV, XviDOS: Android TV : 6.0.1 Marshmellow
Board : SVP4KDTV15
SoC model: MediaTek MT5891
Core architecture: 4x ARM Cortex-A53(32-bit)
Instruction Set : 32-bit ARMv7
GPU: ARM Mali T860 triple core
RAM: 2GB
Total memory: 16GB
Available memory: 1576MB
Internal storage total space:1983MB
Internal storage space: 8258MBLan(100BASE-TX/10BASE-T)
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
DLNA
Bluetooth(NFC)Ver.4.1 HID/HOGP/3DSP/SPP
(for keyboard and mouse, no Bluetooth audio)2 x USB 2.0 (DC 5V MAX 500mA)
1 x USB 3.0 (DC 5V MAX 900mA)
1 x Ethernet RJ45
4 x HDMI 2.0a - HDCP2.2 (ARC, CEC, MHL)
1 x Satelite In (Main: F-type female)-
1 x Satelite In (Sub: F-type female)
1 x SCART
1 x AV Composite In
1 x AV Component In
1 x Optical Audio Out(AAC/PCM/AC3)
1 x 3.5mm Audio Out
1 x Antena (RF) (female)
1 x CI+ 1.3Twin tuners
DVB-T/T2/C/S/S2
DiSEqC version 1.0
PIP, Timeshift & PVR
MPEG2, MPEG4
HEVC H.265White balance- 2/10 points
Gamma - 10 points
ISF - noTV can not solve the very first step also correctly (17/255) XD83 XD80
(Flat)
KD-55XD8005 BAEP
KD-49XD8099 BAEP
KD-49XD8088 BAEP
KD-49XD8077 SAEP
KD-49XD8005 BAEP
KD-43XD8099 BAEP
KD-43XD8088 BAEP
KD-43XD8077 SAEP
KD-43XD8005 BAEP
No No No 49" - max -
43" - max -
Compatible
HDR Processing
(missing hardware for playback HDR)49" - AMVA3, 8-bit+FRC, 60/50Hz
43" - AMVA3, 8-bit+FRC, 60/50Hz
Flat
8099/8088/8077 - Motionflow XR 400
8005 - 49 & 43" - Motionflow XR 200
Black uniformity is relatively good. There is a bit of clouding on the test picture, but it should not be too noticeable during normal viewing.1080p / 60Hz / 4:4:4: Yes
1080p / 120Hz: No
3840 x 2160 / 30Hz / 4:4:4: Yes
3840 x 2160 / 60Hz: Yes
3840 x 2160 / 60Hz / 4:4:4: Yes
The XD800 accepts a 120Hz signal, but has a 60Hz panel so it can only display half of the frames. It supports chroma 4:4:4 at up to 4k / 60Hz. To display 4:4:4, set the scene to 'Graphics' or 'Game'. This results in an input lag of 33.3ms. It accepts a 4k / 60Hz / 4:4:4 signal only HDMI 2 and 3, and requires 'Enhanced HDMI' to be enabled in the input settings.49" - Edge Led (below)
Quantum Dots (+ Blue Led)
PWM - ?49" -
43" -
43" -
49" - °
43" - 21°
49" -
43" -
XD80
55", 49", 43"49" - Game mode
43" - Game mode 33.3ms / with MotionFlow 49.1ms
49" -
43" -
Dolby Digital
Dolby Plus
Dolby Pulse
DTS
Magnetic Fluid Speaker & Clear PhaseFAT16, FAT32, NTFS and exFAT
JPEG, GIF, PNG, MPO
AVI, DivX, H.263
MKV, Quick Time, M2TS, MP4, WebM, WMV, XviDOS: Android TV 6.0 Marshmellow
Board:
Corе Аrсhitecturе: 4 x АRM Cortех-A53
Instruсtion Set: 32-bit АRMv7
GPU: АRM Маli-T860 two core
RAM: 2GB
Total memory: 16GB
Internal storage tоtаl mеmоrу: 1983 MB
Іntеrnаl stоrаgе space: 8358 MBLan(100BASE-TX/10BASE-T)
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
802.11 ac
Wi-Fi Direct
DLNA
(for keyboard and mouse, no Bluetooth audio)2 x USB 2.0 (DС 5V MAX 500mА)
1 x USB 3.0 (max 0.9A)
1 x Еthеrnеt RJ45
4 x HDMI 2.0 - HDCP2.2 (АRС,CEC,MHL)
1 x Sаtеlіtе in(Main:F-tуpe fеmаlе)->
1 x SCART
1 x Compositе іn (Video+L/R)
1 x Cоmponеnt in (YPbPr+L/R)
1 x Optical Аudio Оut(AAC/PCM/AC3)
1 x 3.5mm Аudio Оut
1 x Аntеnа (RF) (Fеmаlе)
1 x CI+1.3DVB-T/T2/C/S/S2
DiSEqC version 1.0
MPEG2, MPEG4
HEVC H.265TV can not solve the very first step also correctly (17/255)
- - Still too many bugs with Android TV (videos stretched in multimedia playback, frequent reboot, frequent losses HDMI signal with devices HDCP 1.1, remote control does not respond fairly regularly, concern for synchronizing 3D glasses, saccades with KODI, no bitstream audio with 5.1 KODI, bad die-stamping with videos played via USB / DLNA, HDR mode losses in multimedia playback, etc.
- - Too many applications not optimized for Android TV
- - Lacks a little power for a better experience with Android TV
- - Loss of saturation at an angle
- - Media player ignores aspect ratio
XD80
Sony ZD9 (KD-65ZD9) Test – flagowy telewizor Ultra HD z Direct LED i 4K HDR
Google превод Pl to Bg
KD-65ZD9: MVA panel, RGB subpixel panel structure
https://hdtvpolska.com/wp-content/up...ony_ZD9_26.jpg
source photo:[hdtvpolska.com]
KD-55XD8005:IPS panel,50/60Hz,RGB subpixel panel structure
Някой знае ли как може да се проверят работните часове на телевизор SONY 55XD8577. Понеже е на промоция в технополис съм малко резервиран...
Според мен няма причина да си резервиран, защото модела е нов. А и като го купуваш винаги можеш да огледаш дали е бил мостра. Следите за които трябва да внимаваш са: Първо и най-важно дали тиксото отгоре на кашона е рязано и залепено на ново, второ ако се отваря отдолу както повечето големи тв на Сони дали всички пакети и опаковки не са скъсани или лепени, виж и батериите дали са отворени. Ако има нещо нередно вярвай ми ще го видиш!
Батериите вече не са критерии...в магазините са се изхитрили и ползват едно дистанционно за всички телевизори от дадена марка...много сигурен знак дали телевизора е бил мостра е прахта по задния панел..понеже са супер мързеливи ,никой не си прави труда да я избърсва,дори и някой по отворен да я позачисти...винаги си личи по фугите и най-вече по вентилационните отвори..гледай най-вече там..:)
Някой има ли информация дали в SONY SD85 има HDR хардуер. На таблицата на моделите 2016 пише, че SD85 има HDR хардуер, a XD85 няма, но във чужди форуми показват друга таблици където само 9-та серия има такъв хардуер и това го коментират в ревютата. ???
svetlio1
TV Sony KD 49X8308C анти-обзор :)
https://www.youtube.com/watch?v=v62erjpktQo
Sony 65XD7505 обзор |
Браво Христославе.Това е самата истина.Моето говедо и то има това затъмнение в долния край.43W805C.За тези които са се насочили към марката първо да купуват смело а след това да намерят сили и да изгледат това видео което е препоръчал Христослав.
Още от мен.Който няма огледало в хола си вече ще има.На тъмни сцени виждам всичко какво има в стаята.На тъмно е свикнало животното.
