Принципно и аз нямам, ама скуката води до всякакви. идеи
Изпратено от моят LG-K350 с помощта на Tapatalk
Който иска може да си направи регистрация на телевизора или друга техника на www.sony.eu/mysony
Адреса ръчно си го напишете.
https://forum.setcombg.com/attachmen...id=26768&stc=1
Аз на моя си направих още щом го взех
Линка не работи ....
И не можа ли ръчно да го въведеш?...
Register your Sony Product: Official Sony product registration
https://www.homecinemamagazine.nl/20...hd-hdr-lcd-tv/
KD-55XF8505:IPS panel ,true 4K UHD (RGB),Edge LED (bottom) backlight with global dimmingЦитат:
IPS panels have a relatively moderate black value and this Sony also confirms that. With a native contrast value of barely 775: 1 it is difficult to make images with a lot of impact.
Yet this Sony can, how?
In the Cinema Pro mode 'Contrast optimization' is activated (in the lowest setting). Sony then uses a smart full-screen dimming and delivers an enormous improvement of the contrast to 2962: 1, a value that allows it to stand next to a lot of VA panels. The dimming effects are rarely visible, unless in extreme cases such as subtitles on an almost black scene.
Той заменя миналогодишният XE85, който беше с VA панел.
https://cdn.homecinemamagazine.nl/wp...600x351@2x.jpg
source:[homecinemamagazine.nl]
[tvtest.pl]Sony KD-55XF8505 - first impressions.
Sony 55XF8505 – pierwsze wrażenia – TV TEST
http://www.tvtest.pl/wp-content/uplo...nozki-wer2.jpg
source photo:[tvtest.pl]
XF90:
KD-75XF9005 : 4.649 €
KD-65XF9005 : 2.599 €
KD-55XF9005 : 1.849 €
KD-49XF9005 : 1.549 €
XF85:
KD-75XF8596 : 3.599 €
KD-65XF8577 : 2.449 €
KD-65XF8505 : 2.349 €
KD-55XF8577 : 1.649 €
KD-55XF8505 : 1.549 €
KD-49XF8577 : 1.399 €
KD-49XF8505 : 1.349 €
XF80:
KD-43XF8096 : 1.049 €
http://forum.ixbt.com/topic.cgi?id=62:22492:2131#2131
http://helpguide.sony.net/tv/eaep1/v...-01-03_03.html
https://www.youtube.com/watch?v=iLDxEE9WwngЦитат:
We review the Sony XF90 LED LCD TV (also marketed as the Bravia XF9005 in Europe or X900F in North America) with full-array local dimming (FALD) direct-lit LED backlighting, X1 Extreme processor with future Dolby Vision support, X-Motion Clarity black "zonal" insertion technology, as well as Android 7 Smart TV platform.
повече памет ли заема новия андроид 7 спрямо стария версия 6 ?
Струва ли си според Вас ъпгрейда на Sony kd-55xe9305 /2017/ с kd-55xf9005 /2018/?
Според мен това е напълно излишно. С какво kd-55xf9005 е по-добър от kd-55xe9305? То дори смяната на ХЕ9005 с XF9005 е напълно излишна и неоправдана.
Благодаря,
Аз самия съм с 55ХЕ9005 ,но тъй като цената на ХЕ9305 е много добра в момента и се чудя да го заменя ли,да изчакам ХF9005...или накрая да си остана с ХЕ9005 ?.../но разликата в подсветката м/у ХЕ9305 и ХЕ9005 ,според мен е осезаема , а и DOLBY VISION ??!!.
Споделете Вашите мнения!
Един може би малко глупав въпрос ... ама като не знам ... та къде се намират батерията/те на дистанционното на телевизора - Sony kd-43xe8005.
Приплъзваш целия заден капак на дистанц. посоката е указана.
