И пак само два от четирите HDMI порта са 2.0b... Докога с тези "нискокласови" ограничения.
Така е, защото в "пролетните" модели(като XF900), Sony ползват шаситата на миналогодишните "есенни" модели.
XF90Цитат:
SONY LED
Model: KD-55XE9005
Panel: YD7S550DND01B
T-CON: 17Y_SGU13TSTLTA4V0.1
LED driver (backlight): 1-981-827-11(198182711)
Power Supply (PSU): Adapter + 1-982-183-11 (173667711)
MainBoard: 1-982-022-11 198202211
Тuner: SUT-CE551ZP 1-981-981-11
Control: WI-FI: J20H088 801926
KD-49XF9005 (49"): 1.499 Euro
KD-55XF9005 (55"): 1.799 Euro
KD-65XF9005 (65"): 2.499 Euro
KD-75XF9005 (75"): 4.499 Euro
XF85
KD-43XF8505 (43"): 1.099 Euro
KD-49XF8505 (49"): 1.299 Euro
KD-55XF8505 (55"): 1.499 Euro
KD-65XF8505 (65"): 2.299 Euro
KD-75XF8505 (75"): 3.499 Euro
KD-85XF8505 (85"):
XF80
KD-43XF8096 (43"): 999 Euro
KD-49XF8096 (49"):
KD-55XF8096 (55"):
https://www.giz.ro/wp-content/upload...ony-xf90-4.jpg
https://www.giz.ro/wp-content/upload...sony-af8-1.jpg
https://www.giz.ro/wp-content/upload...c-surfaces.jpg
https://www.giz.ro/wp-content/upload...sony-af8-2.jpg
https://www.giz.ro/wp-content/upload...ony-xe90-2.jpg
https://www.giz.ro/televizoare-lcd-t...ti-2018-53998/
TEST Sony KD-55XF9005 (2018)
https://hdtvpolska.com/sony-xf90-tes...-dolby-vision/
TEST: Sony KD-65XF9005 (2018)
XXL-TEST: Sony KD-65XF9005 – 65 Zoll Ultra HD-LCD-TV mit präzisem Local Dimming und X1 Extreme-Bildprozessor | AREA DVD
Хардуерната платформа изглежда същата като в телевизори 2017.
Produkt: BRAVIA_ATV2_4K_EU
Equipment: BRAVIA 4K GB ATV3
CPU: MediaTek 5891 (aka MediaTek 5596)
Architecture: 4 x ARM Cortex-A53
64-bit ARMv8-A (32-bit Mode)
RAM: 2GB
заета памет: 1575MB
свободна памет: 409MB
https://hdtvpolska.com/wp-content/up...20-768x429.jpg
https://hdtvpolska.com/wp-content/up...23-768x429.jpg
KD-55XF9005: a-Si TFT LCD subpixel panel vertical striped structure RGB -true 4K UHD, type MVA, 10-bit, 120Hz
(Blue Leds + PFS (potassium-fluorosilicate) phosphor featuring an extremely narrow red peak - "TRILUMINOS")
Според снимките имаме нова ревизия - промяна позициите на управляващите транзистори
(сега са в долната част на домейн А, докато в старата бяха изцяло извън домейните)
XF90
https://hdtvpolska.com/wp-content/up...ny_XF90_19.jpg
XE90
https://hdtvpolska.com/wp-content/up..._14.jpg?x17527
http://www.private-sammelbestellunge...5af8-kd-65af8/
От големите марки само Sony липсва.
https://calman.spectracal.com/panasonic-autocal.html
https://calman.spectracal.com/samsung-autocal.html
https://calman.spectracal.com/lg-autocal.html
Въпрос на време е някоя китайска марка също да го приложи.
От любопитство сравних контрста на xf90 с миналогодишния модел.Не знам на какво точно се дължи,но тук го изкарат по-нисък.Сравнете тези х-ки със същите за xe90:
https://forum.setcombg.com/attachmen...id=26454&stc=1
https://forum.setcombg.com/attachmen...id=26455&stc=1
https://hdtvpolska.com/sony-xe9005-k...v-2017-4k-hdr/
Има разлика в контраста на матрицата - може би е сменен производителят и от там типа VA.
ANSI контраст без гасене (повече - по-добре) 4 700:1 (XE90)
ANSI контраст без гасене (повече - по-добре) 3,500:1 (XF90)
https://www.displayspecifications.co...ison/895f177d1
Има и козметична промяна в новото дистанционно RMF-TX310E - бутоните в пръстена около JOG бутона.
ANSI контраст без гасене (повече - по-добре) 4 700:1 (XF90)...това за XE 90 ,мисля.
Очевидно става,че при led тв-те всички търсят само поевтиняване.При това положение като че ли ....като ще се пести,поне да е икономия...но в Бг ги няма добрите китайски производители TCL и Hisence.Skyworth присъства,но без OLED моделите.Пък и не знам дали в някоя тема има таблица с х-ки на неговите тв-ри-матрица,подсветка и hz...поне.
За OLED моделите даже не намирам никъде цени,може би са нови....
TV/Accessories / TV / OLED - OLED - Skyworth Group.
https://4pda.ru/forum/index.php?showtopic=731708&st=460
XF9005 - MVA
XF8505 / XF8577 / XF8588 / XF8596 / XF8599 - IPS
XF8096 - IPS
Nuova gamma TV Sony OLED + LCD 2018 | Pag 2: OLED AF8, LCD XF90 e X-Motion Clarity | AV Magazine
http://www.avmagazine.it/articoli/4K/1193/16.jpg
source photo:[avmagazine.it]
https://play.google.com/store/apps/d....etvs.gp&hl=bgЦитат:
ESET Smart TV Security is a fast and powerful antivirus and antimalware application protecting your smart television and other devices running on Android TV Operation System.
В безплатната версия програмата предлага активна защита срещу различни вредители (от троянци до ransomware), текущи актуализации и сканиране на USB носители. Дали има и платена версия? Да - за няколко лева месечно абонатите ще получат допълнително достъп до анти-фишинг защита (в уеб браузър) и възможност за задаване на график за сканиране.
Това е безумие, SOC-a в телевизорите и без това е отчайващо бавен та и антивирусна да го "души".
Търся да закупя дистанционно RM-ED019 за телевизор Sony KDL-40Z5500 (прикачен print screen).
Моля ако някой знае от къде да ми подскаже.
Благодаря предварително
https://forum.setcombg.com/attachmen...id=26588&stc=1
https://www.lesnumeriques.com/tv-tel...2769/test.html
Sony KD-65XF9005: MVA, 10-bit, 120/100Hz, UHD(3840x2160), FALD, (BFI)
Response time 12 ms (BtoW), пълен цикъл 25 ms (BtoWtoB)
Загуба на яркост от 61% при 45°
Екранното покритие е полу-гланц
Black: 0.03cd/m²
White: 155cd/m²
Contrast: 4456:1 - по-нисък от миналогодишният Sony XE9005(7700: 1)
Пикова яркост: 849 cd/m²
Input Lag: Game 40ms; това е повече от Sony 65XE9005, 31 ms.
Средната разлика в хомогенността на бялото все още е - подобно на миналогодишния модел - 12%, което е сравнително висока стойност за модел Full Led.
Режимът "Cinema Pro" предлага колориметрично изображение, близко до съвършенството. Средната измерена делта E е 2,0, по-малка от стойност 3, под която окото вече не различава цветовите изкривявания. Само яркозелените тонове имат делта E малко над 3.
Както при всички модели 2017, стандартната настройка на гама от -2, осигурява средна крива при 2.4, което е стандарт за Ultra HD съдържание. За други източници настройката на 0, довежда гамата до перфектната средна стойност от 2,2. Кривата е стабилна на всички сиви нива. Забележете, че телевизорът не разпознава автоматично типа на източника (Full HD или Ultra HD) и следователно не коригира гама автоматично, за разлика от това, което LG прави на своите телевизори.
Температурната крива е доста стабилна и средната стойност (измерена 6,960 Келвина) е доста близка до референтната стойност от 6,500 Келвина. Тази температура се получава при настройката "Експерт 2". Другите настройки осигуряват много по-студено изобразяване.
Процесорът е използваният миналата година MediaTek 5596 (с маркетингово название Extreme X1), в Андроид излиза като 5891. Поради слабостите му не може да обработи динамични данни при HDR сигнал. Затова Sony, поискаха от Dolby чрез ъпдейт тази дейност да се прехвърли на източника на сигнал - плейъра....
Всички по-долу изписани функции са всъщност софтуер, който с цел "подобряване на картината", изкривява оригиналният видеосигнал.
Тези настройки могат също така да подобрят контурите (рязкост), да намалят шума, да наподобяват цветовете или да укрепват текстурата (разделителна способност).
Super Bit Mapping 4K HDR (14-битова обработка на цветовете, за да избегне бандинга),
Object-Based HDR Remaster (подобрение на цветовете и контраста) ,
Dual Database Processing (по-добро управление на шума и подобрени детайли).
MotionFlow Clarity. Тази система компенсира спада в яркостта, причинена от вкарването на черни изображения чрез увеличаване на яркостта на движещите се области; като напомняне, вмъкването на черни изображения прави възможно изкривяването на устойчивостта на ретината и подобрява остротата на движещите се изображения, но често води до спад в яркостта.
X-Motion Clarity - гасене на сектор от подсветката в чиято територия се намира подвижният елемент от кадъра. Така се преодолява зрителната памет и постига яснота на образа на обекта. Като страничен ефект, получаваме спад в яркостта на обекта спрямо яркостта в останалата част на кадъра..
http://p0.ifengimg.com/pmop/2018/020...1000_h563.jpeg
https://www.tek.no/artikler/test-son...5xf9005/431420
Все още информацията е малко и част от таблицата е предположения...
Still the information is small and part of the table is a guess...
Type panels Series / diagonal
___________________________ 85"_________________
75"______________
65"_______________
55"_______________
50"______________
49"______________
43"______________
AF9
AM-OLED WRGB
120/100Hz
(LGDisplay)AM-OLED WRGB
120/100Hz
(LGDisplay)AF8
AM-OLED WRGB
(LGDisplay)ZF9
? MVA, 10-bit
120/100Hz
3840x2160MVA, 10-bit
120/100Hz
3840 x 2160XF90 MVA
(Samsung. AUO ??)
120/100HzMVA, 10-bit
120/100Hz
3840x2160Samsung MVA, 10-bit
120/100Hz
3840 x 2160Samsung MVA, 10-bit,
120/100Hz,
3840 x 2160,Samsung MVA
120/100Hz
3840 x 2160XF87/85
(XF8505/8577/8588/8596/8599/8796)MVA, 10-bit
(Samsung, AUO ??)
120/100Hz
3840x2160IPS, 10-bit
60/50Hz
60/50Hz
3840 x 2160IPS, 10-bit
60/50Hz
3840 x 2160IPS
60/50Hz
3840x2160IPS
60/50Hz
3840x2160XF80
(XF8096)
IPS, 8-bit
60/50Hz
3840 x 2160IPS, 8-bit
60/50Hz
3840x2160IPS, 8-bit
60/50Hz
3840x2160XF75
(XF7596)
-, 8-bit
60/50Hz
3840x2160-, 8-bit
60/50Hz
3840 x 2160-, 8-bit
60/50Hz
3840 x 2160-, 8-bit
60/50Hz
3840 x 2160XF70
(XF7000/7005/7096)
-, 8-bit
60/50Hz
3840 x 2160-, 8-bit
60/50Hz
3840 x 2160-, 8-bit
60/50Hz
3840 x 2160-, 8-bit
60/50Hz
3840 x 2160-, 8-bit
60/50Hz
3840/2160WF80
(WF8)
-, 8-bit
60/50Hz
1920x1080WF60
(WF660/663/665)
-, 8-bit
60/50Hz
1920x1080-, 8-bit
60/50Hz
1920x1080RF40
(RF450/453/455)
-, 8-bit
60/50Hz
1920x1080
Днес забелязах на хоум скреена известие да очакваме андроид 7 тв то е W805C
Разгеле , дано да е скоро , че моя нещо много почна да ме дразни - всеки ден се рестартира , обикновено веднага след включване, но преди малко пак го видях да върти кръговете ;)... сигурно щото вчера и тая сутрин не беше ги въртял ;)
И при мен го има съобщението....за вече близо 3 години,не съм имал никакви проблеми с телевизора...след поне 10 ъпдейта от 2015г. до сега,мога да кажа че само са се подобрявали нещата....дано го пуснат скоро,тогава обещавам след инсталация и аз да го върна към фабричните настройки,понеже до сега не съм го правил никога:)
