| Sony Bravia OLED & LCD TV 2019 Line-up |
 | Class | MASTER Series | Mainstream | MASTER Series 8K | Mainstream | Entry |
 | Type | OLED - UltraHD | LCD - UltraHD | LCD - FullHD |
 | Series___________________ | AG9__________________
 | AG8__________________
 | ZG9__________________ | XG95__________________availability in March
 | XG90__________________availability in March
 | XG85__________________ | XG83__________________ | XG81__________________ | XG80___________________availability in April
 | XG70__________________ | WG66__________________ |
 | Models | KD-77AG9KD-65AG9
 KD-55AG9
 | KD-65AG8KD-55AG8
 | KD-98ZG9KD-85ZG9
 | KD-85XG9505KD-75XG9505
 KD-65XG9505
 KD-55XG9505
 | KD-49XG9005 | XG8599XG8596
 XG8588
 XG8577
 XG8505
 | XG8399XG8396
 XG8388
 XG8377
 | KD-65XG8196KD-55XG8196
 KD-49XG8196
 KD-43XG8196
 | KD-75XG8096KD-65XG8096
 KD-55XG8096
 KD-49XG8096
 KD-43XG8096
 | XG7096XG7077
 XG7005
 XG7004
 | 50WG66550WG660
 43WG665
 43WG660
 | Formats | 55", 65", 77" | 65", 75" | 85", 98" | 55", 65", 75", 85" | 49" | 55", 65", 75", 85" | 43", 49" | 43", 49", 55", 65" | 43", 49",55",65",75" | 43", 49", 55", 65" | 43", 50" |
 | Frame color | Black | Black | Black | Black | Black | 8599 - Black 8596 - Black
 8588 - Black
 8577 - Silver
 8505 - Black
 | 8399 - Black 8396 - Black
 8388 - Black
 8377 - Silver
 | Black | -- | 7096 - Black 7077 - Silver
 7005 - Black
 7004 - Black
 | Processor |
 | Marketing name
 CPU
 CPU Cores
 CPU Bit
 Max CPU Frequency
 GPU
 | X1 Ultimate Mediatek 5598 (5893)
 4xARM Cortex
 | X1 Extreme
 Mediatek 5597 (5892)
 4xARM Cortex-A73 @ 1500MHz
 64-bit ARMv8-A (32-bit mode)
 GPU - ARM Mali-G71 Vulkan
 4xARM Cortex
 | X1 Ultimate
 4xARM Cortex
 | X1 Extreme
 MediaTek 5598 (5893)
 | X1
 Mediatek 5596
 4xARM Cortex-A53 @ 1100MHz
 GPU - ARM Mali-T860 MP2
 | X1
 MediaTek 5596
 | X-Reality Pro
 MediaTek 5595
 | X-Reality Pro
 MediaTek 5595
 | X-Reality Pro
 MediaTek 5582 ?
 | X-Reality Pro
 MediaTek 5582 ?
 | Memory RAM | 4GB | ? |
 | Storage Flash | 16 GB internal memory (approximately 8GB available) + expandable via USB Dongle | ? |
 | Operation System | Android 8.0 OREO (update to Android 9.0 Pie) | Linux kernel |
 | Display |
 | Manifacturer Model
 Type
 Resolution
 Display aspect ratio
 Pixel Format
 Display Colors
 Luminance(cd/m²)
 Viewing Angle
 Color Gamut
 Contrast Ratio
 Response speed(ms)
 Frame Rate
 Life Time
 | LG Display LE650AQD / LE550AQD
 AM-OLED, Oxide-WOLED-Color Filter
 3840(RG/BW)x 2160, UHD
 16:9 (H:V)
 RGBW Vertical Stripe
 1.07B (8-bit + Dithering)
 500 (Typical) 900 max
 60/60/60/60 (Typ.) (Left, Right, Up, Down)
 97% DCI-P3
 150000:1 (Typ.) (Transmissive)
 1 (Typ.)(G to G); 8 (Typ.)(MPRT)
 120Hz
 30K (Typ.) (Hours). After that time, the brightness may drop about 50%.
 | 98"(Samsung, LG) 85"(AUO, Innolux)
 LCD
 7680(RGB)×4320
 16:9(H:V)
 RGB Vertical Stripe
 1.07B (8-bit + FRC)
 -- (Typical) -- max
 60/60/60/60 (Typ.)
 97% DCI-P3
 6000:1 (Typ.)
 14 (Typ.)(G to G)
 100/120Hz
 30K (Typ.) (Hours).
 | LCD, Super-MVA Innolux
 LCD
 3840(RGB)×2160
 16:9(H:V)
 RGB Vertical Stripe
 1.07B (8-bit + FRC)
 500 (Typical) -- max
 60/60/60/60 (Typ.)
 97% DCI-P3
 6000:1 (Typ.)
 14 (Typ.)(G to G);
 100/120Hz
 30K (Typ.) (Hours).
 | MVA -
 LCD
 3840(RGB)×2160,
 16:9(H:V)
 RGB Vertical Stripe
 1.07B (8-bit + FRC)
 -- (Typical) -- max
 60/60/60/60 (Typ.)
 97% DCI-P3
 1200:1 (Typ.)
 14 (Typ.)(G to G)
 100/120Hz
 30K (Typ.) (Hours).
 | S-IPS IV LG Display
 LCD
 3840(RGB)×2160
 16:9 (H:V)
 RGB Vertical Stripe
 1.7B (8-bit + FRC)
 LCD
 3840(RGB)×2160
 16:9 (H:V)
 RGB Vertical Stripe
 1.07B (8-bit + FRC)
 -- (Typical)
 60/60/60/60
 97% DCI-P3
 1200:1 (Typ.)
 14 (Typ.)(G to G)
 100/120Hz
 30K (Typ.) (Hours).
 LCD
 1920(RGB)×1080
 16:9 (H:V)
 RGB Vertical Stripe
 1.07B (8-bit + FRC)
 -- (Typical)
 60/60/60/60 (Typ.)
 97% DCI-P3
 ?:1 (Typ.)
 14 (Typ.)(G to G)
 50/60Hz
 30K (Typ.) (Hours).
 LCD
 3840(RGB)x2160
 16:9 (H:V)
 RGB Vertical Stripe
 1,07B (8-bit + FRC)
 50/60Hz
 30K (Typ.) (Hours)
 LCD
 1920(RGB)×1080
 16:9 (H:V)
 RGB Vertical Stripe
 1.07B (8-bit + FRC)
 -- (Typical)
 60/60/60/60 (Typ.)
 97% DCI-P3
 ?:1 (Typ.)
 14 (Typ.)(G to G)
 50/60Hz
 30K (Typ.) (Hours).
 LCD
 1920(RGB)×1080
 16:9 (H:V)
 RGB Vertical Stripe
 1.07B (8-bit + FRC)
 -- (Typical)
 60/60/60/60 (Typ.)
 97% DCI-P3
 ?:1 (Typ.)
 14 (Typ.)(G to G)
 50/60Hz
 30K (Typ.) (Hours).
 | Backlight Type | OLED is a self-emitting pixels display technology meaning that it controls luminance on the pixel level | FALD Backlight Master Drive
 | FALD 85" - ? zones
 75" - ? zones
 65" - ? zones
 55" - ? zones
 | FALD 49" - ? zones
 | Edge LED Local Dimming
 | 55, 65" - Direct Led Global Dimming
 43",49" - Edge Led
 Local Dimming
 | 55, 65, 75" Direct Led Global Dimming
 43",49" - Edge Led
 43",49" - Edge Led
 Local Dimming
 | Edge LED No Local Dimming
 | Panel Refresh Rate (Native Hertz)
 | 48/50/60/100/120Hz (100Hz - PAL / 120Hz - NTSC)
 | 48/50/60 Hz (50Hz - PAL / 60Hz - NTSC)
 | Viewing Angle | - | - | X-Wide Angle Filter | X-Wide Angle Filter (only in 75" & 85")
 | No |
 | Triluminos Display | No | Yes (Blue Leds - PFS (potassium-fluorosilicate) phosphor featuring an extremely narrow red peak - "TRILUMINOS")
 | No |
 | Motion Enhancer | X-Motion Clarity | ? | X-Reality Pro | - | - | - |
 | CalMan Calibration Function | Yes | No | Yes | No | No |
 | Object-based Super Resolution | Yes | - | - | - | - | - |
 | Video Features |
 | CineMotion/Film Mode/Cinema Drive
 | -- | Yes | -- |
 | 24p True Cinema | Yes | -- | -- | -- |
 | 4:3 Default | Yes |
 | Auto Wide | Yes | -- | -- | -- |
 | Blinking Type | Frame Blinking | -- | Line Blinking | -- | -- | -- | -- | -- | -- | -- |
 | Dual database processing
 | Yes One database is used to clean the picture, reducing on-screen noise. The other is used to upscale the resolution, improving clarity. These two powerful image improvement databases work together, dynamically improving pixels in real time. Each database has tens of thousands of references, amassed from our experience creating content for TV and movies over the years.
 | Dynamic Contrast Enhancer
 | Yes | -- | -- | -- | -- |
 | Face Area Detection | Yes | -- | -- | -- | -- | -- | -- | -- |
 | HDR (High Dynamic Range) compatiblity
 | HDR10, Hybrid Log-Gamma, Dolby Vision | HDR10, HLG |
 | Live Color™ Technology
 | Yes | -- | -- | -- | -- | -- | - |
 | MEMC | MotionFlow XR | - | - |
 | Object-based HDR remaster
 | Yes With Object-based HDR remaster, the color in individual objects on screen is analyzed and the contrast adjusted, unlike most TVs where contrast is only adjusted along one black-to-white contrast curve. Because objects are remastered individually, this TV can reproduce greater depth, textures, and more realistic pictures.
 | Picture Modes | Vivid, Standard, Custom, Cinema Pro, Cinema Home,
 Sports, Animation,
 Photo-Vivid ,PhotoStandard, Photo-Custom,
 Game, Graphics, Dolby Vision
 | Vivid, Standard, Cinema, Game, Graphics, Photo, Custom,  Dolby Vision Bright, Dolby Vision Dark, Netfix calibrated | -- | -- | -- | -- | -- | -- |
 | Precision Color Mapping
 | Super Bit Mapping™ 4K HDR
 | Yes There are thousands of tones, shades and gradations of light in a sunset. Super Bit Mapping 4K HDR works wonders to reveal them. It creates smooth, natural 4K TV picture quality as you watch, without the "banding" that can occur on other TVs.
 | Video Upscaling | 4K X-Reality PRO | -- | -- | -- | -- | -- | -- |
 | Wide Mode | Wide Zoom / Normal / Full / Zoom Normal / Full1 / Full2 for PC | -- | -- | X-Reality PRO | -- | -- |
 | Netflix Calibrated Mode | Netflix streaming membership required. 4K Ultra HD availability is subject to your Netflix subscription plan, internet service, device capabilities, and content availability. https://help.netflix.com/legal/termsofuse | -- | -- | -- | -- | -- |
 | Audio |
 | Audio Power Output | -- | 4 x 10W | -- | 10W + 10W | -- | - | 2 x 10W | -- | -- |  |  |
 | Bass/Treble/Balance | -- | Balance | -- | Balance | -- | -- | -- | -- | -- |  |  |
 | DSEE/DSEE-HX | -- | DSEE | -- | -- | -- | -- | -- | -- | -- |  |  |
 | Speaker Confguration | -- | 2.2ch/ Actuator(29x42mm)x2,
 Woofer(38x85mm)x2
 | -- | 2ch/Full Range (Bass Refex)(25x90mm)x2,
 Tweeterx2
 | Speaker Position |  | Front + Down Firing |  |  |  |  |  |  |  |  |  |
 | Speaker Type | Acoustic Surface Audio + | Acoustic Surface Audio | -- | -- | -- | -- | -- | -- | -- |  |  |
 | Other | Support for Dolby Atmos will be provided through a future software update | - | Support for Dolby Atmos will be provided through a future software update | - | - | 2 + 2 speakers | - | - | - | - | Dolby Digital, Dolby Digital Plus, Dolby Digital Pulse,
 DTS
 | Audio Features |
 | Advanced Auto Volume | Yes | -- | -- | -- | -- | -- |
 | Alternate Audio (Digital) | Yes | -- | -- | -- | -- | -- |
 | ARC Output Format : | Two channel linear PCM: 48 kHz 16 bits, Dolby Digital, Dolby Digital Plus, DTS | -- | -- | -- | -- | -- | -- | -- |
 | Audio out : | Fixed / Variable | -- | -- | -- | -- | -- | -- | -- |
 | Auto Surround | Yes | -- | -- | -- | -- | -- | -- | -- |
 | Clear Audio + | Yes | -- | -- | -- | -- | -- | -- | -- |
 | Clear Phase | Yes | -- | -- | -- | -- | -- |
 | Digital audio out (Optical) format
 | Two channel linear PCM:  48 kHz 16 bits, Dolby Digital, DTS (AAC / PCM / AC3)
 | Dolby audio format support:
 | -- | Dolby Audio(Dolby Digital, Dolby Digital Plus)
 | -- | Dolby Audio (Dolby Digital, Dolby Digital Plus, Dolby AC-4) | -- | -- | -- | -- | -- |
 | DTS audio format support:
 | DTS Digital Surround | -- | -- | -- | -- | -- |
 | HDMI Audio Return Channel(ARC):
 | Yes (eARC) | Yes (ARC) | Yes (eARC)return audio to an audio device via HDMI in high resolution (support Lip Sync Correction, Uncompressed 7.1 & 5.1, Dolby TrueHD, Dolby Atmos, DTS: X)
 | Yes | Yes | Yes | -- | -- |
 | HDMI input Audio format:
 | -- | 5.1 channel linear PCM | 5.1 channel linear PCM: 32 / 44.1/ 48/ 88.2/96/ 176.4/ 192kHz 16/20/24bits, Dolby Digital, Dolby Digital Plus, DTS
 | Simulated Surround Sound:
 | -- | S-Force Front Surround Enjoy an immersive soundstage that pulls you into the heart of the action. S-Force Front Surround mimics the way the brain correlates sound sources to create proper volume, time lag, and sound wave spectrum — using only left and right speaker channels. By naturally emulating three-dimensional sound fields, you’ll enjoy rich, high-fidelity audio across a wider listening area.
 | S-Master: | S-Master Digital Amplifer | -- | -- | -- | -- | - |
 | Sound Modes: | -- | Standard, Dialog, Cinema ,Music, Sports
 | -- | Standard, Dialog, Cinema, Music, Sports,
 Dolby Audio
 | Convenience Features |
 | Application Store: | Yes (Google Play Store) | -- | - |
 | Chromecast built-in: | Yes | -- | -- |
 | Google Assistant Voice Search
 | Yes - Internet environment is necessary to use voice search function Hands Free feature(Builtin Mic) availability depends on language and may need sofware update.
 Please check Sony support page for further information;  https://www.sony.net/tv-hf-ww/
 Austria, Belgium, Czech Republic, Denmark, France, Germany, Ireland, Italy, Netherlands, Norway, Poland, Russia, Spain,
 Sweden, Switzerland, Turkey, United Kingdom
 | ? | -- | -- | No | No |
 | Auto Picture Mode: | Yes | -- | -- | -- |
 | Auto Shut-of: | Yes | -- | -- | -- |
 | Channel Block (with password):
 | Analog & Digital | -- | -- | -- |
 | HDMI-CEC (Consumer Electronics Control)
 | Automatic Input Switching Power on link
 Power off link
 Speaker control
 BRAVIA Link control only with the TV’s remote control
 Unselected device auto off (for available equipment only)
 Automatic lip-sync function
 Energy saving mode (with Quick Start mode)
 Audio Return Channel Audio Return Channel (ARC) is a function that enables digital sound signals to be sent via an HDMI cable back from the TV to a connected audio device.
 | i-Manual | Yes | -- | -- |
 | On/Of Timer | Yes | -- | -- | -- | -- |
 | On-Screen Clock | Yes | -- | -- | -- | -- |
 | Parental Control | Yes | -- | -- | -- | -- |
 | Show/Hide Channels: | Yes (Digital & Analog) | -- | -- | -- | -- |
 | Sleep Timer: | Yes | -- | -- | -- | -- |
 | Text Input Language | -- | -- | -- | -- | -- |
 | USB drive format support
 | Yes (Supported File System: FAT16/FAT32/exFAT/NTFS) |
 | USB playback codecs | MPEG1: MPEG1/ MPEG2PS: MPEG2/
 MPEG2TS (HDV,AVCHD): MPEG2,AVC /
 MP4 (XAVC S): AVC ,MPEG4,HEVC /
 AVI: Xvid, MotinJpeg/
 ASF(WMV): VC1/
 MOV:AVC, MPEG4, MotionJpeg/
 MKV: Xvid, AVC,MPEG4, VP8.HEVC /
 WEBM: VP8/
 3GPP: MPEG4, AVC /MP3 /ASF (WMA) /WAV/ MP4AAC / FLAC /
 JPEG WEBM: VP9/ AC4/ogg/AAC/ ARW(Screen nail only)
 | Inputs and Outputs |
 | 4K 60P High-Quality formats
 | - | - | HDMI IN1, IN2, IN3, IN4 ports for 4K (up to 6Gbps) signal
 | Analog Audio Input(s) (Total)
 | - | - | 1 (1Side Analog Conversion)
 | Bluetooth profle support
 | Version 4.2 - compatible HID/HOGP/SPP/A2DP/AVRCP profiles HIDP (Human Interface Device Profile) - Mouse / Keyboard Connectivity
 HOGP (Low Energy Consumption)
 SPP (Serial Port Profile)
 AVRCP (A/V Remote Control Profile) - AV remote control
 A2DP (Advanced Audio Distribution Profile) - stereo audio
 Please confirm from the support page of https://faq.support.sony.jp/qa/artic...ge/SH000158091 the headphones with confirmed operation. Depending on the Bluetooth device to be connected to this unit, the communication environment, and surrounding circumstances, noise may get in and sound may be interrupted
 | - | - | Version 4.1 HOGP,SPP
 | Composite Video Input(s)
 | 1 (Side) |
 | Digital Audio Output(s) | 1 (Bottom) |
 | Ethernet Connection(s) | 1(Bottom) 10BASE-T / 100BASE-TX Connector (The connection speed of the network may vary depending on the operating environment.)
 10BASE-T / 100BASE-TX communication speed and quality are not guaranteed for this TV. )
 | HDCP | HDCP2.3(for HDMI1/2/3/4)
 | HDMI inputs total | 4 x v.2.0b (1 Side,3 Bottom)- no VRR, QMR | - | 4 x v.2.0b (1 Side, 3 Bottom)- no VRR, QMR | - | 4 x v.2.0b () | 3 x v.2.0b () | 2 x 1.4 |
 | HDMI Signal | 4096x2160p (24,60Hz), 3840x2160p (24,30,60Hz),
 1080p (30,60,120Hz),
 1080/24p, 1080i (60Hz),
 720p (30,60Hz), 720/24p,
 480p
 | HDMI™ PC Input | 640 x 480 (31.5kHz,60Hz), 800 x 600 (37.9kHz,60Hz),
 1024x768 (48.4kHz,60Hz),
 1280x1024 (64.0kHz,60Hz),
 1152x864 (67.5kHz,75Hz),
 1600x900 (55.9kHz,60Hz),
 1680x1050 (65.3kHz,60Hz),
 1920x1080 (67.5kHz,60Hz)
 | Headphone Output(s) | 1 (Side) | - |
 | RF Connection Input(s) | 1 (Bottom) |
 | RS-232C Input(s) | 1 | - | - | - |
 | USB Port(s) | 2 (Side) / 1 (Bottom) USB 2.0 (Type A)(x2) [speed up to 480Mbps]
 USB 3.1 Gen 1 (Type A) [speed up to 5Gbps]
 | - | - | 2 x  USB 2.0 |
 | Network Features |
 | Codec for Home Network
 | MPEG1: MPEG1/ MPEG2PS :MPEG2 /
 MPEG2, AVC/ MP4(XAVC
 S): AVC, MPEG4, HEVC/
 ASF (WMV): VC1/
 MOV: AVC, MPEG4,
 MotionJpeg/ MKV: Xvid,
 AVC, MPEG4, VP8.HEVC/
 WEBM: VP8/ 3GPP:
 MPEG4, AVC /MP3/ ASF
 (WMA) /LPCM /WAV /
 MP4AAC /FLAC/ JPEG
 | DLNA (Home network)
 | HOME NETWORK CLIENT, HOME NETWORK RENDERER (Digital Media Player / Digital Media Renderer) (Digital Living Network Alliance) Founded in 2003 as the Digital Home Working Group, the DLNA (www.dlna.org) sets guidelines for using the Universal Plug and Play (UPnP) protocol to transfer and stream media between computers, mobile devices and home theater equipment.
 | Internet Browser: | Vewd (Not Pre-Installed) Opera TV is now Vewd. | - | - |
 | Screen mirroring Miracast
 | YES (only for B2B purpose) MHL 3.0 | - | Miracast |
 | Wi-Fi | IEEE 802.11 compatible a / b / g / n / ac , Wi-Fi Frequency 2.4GHz / 5GHz, Compatible network: Wi-Fi Direct ™ (without router) Wireless LAN router is required separately when using
 | a/b/g/n/ac |
 | Smartfone Connectivity:
 | Chromecast built-in Video & TV SideView (iOS/Android)
 Airplay 2 enables you to push video, music, and other media from an iPhone or iPad wirelessly onto the TV screen, while HomeKit is Apple’s platform for the connected home.
 | - | Video & TV SideView(IOS/Android) |
 | Features |
 | USB - HDD Rec | Some HDDs may not be available | - | - |
 | Tuners |
 | Tuner
 | DVB-T/T2/C/S2 | Dual DVB-T/T2/C/S2
 | DVB-T/T2/C/S2 | DVB-T/T2/C/S/S2 |
 | Remote control(s): | new remote | RMF-TX310E | new remote | RMF- | RMF- | RMF- | RMF- | RMF- | RMF- | RMF-3--- |
