Re:Toshiba LCD TV / Faq - на първа страница ,обсъждане ,мнения / част 2
Първоначално публикувано от ruzmarinx
zdraveite ot serbia...
Model: 32SL738G
Firmware Update Version
1.03
pitanje- kako da rabota divx ot usb?
The SL738 TV series features a wide range of interfaces for fast and easy connectivity. Via a HDMI (High-Definition Multimedia Interface) input, the TV sets easily receive uncompressed multimedia streams from any HDMI enabled HD source. And, from a USB port, they offer a useful interface for playback of popular file formats such as MP3 and JPEGs. SCART and PC ports, component video, inputs and outputs for headphones, digital and analog audio, and a DVB common interface (CI+) complement the broad connectivity feature set.
Само MP3 музика и Jpeg снимки.
С външен плеър,например този: http://www.technomarket.bg/products/...hiba-sd-2010ke
Първоначално публикувано от maivro
http://www.technomarket.bg/products/...shiba-32av833g Този е доста по-изгоден, а плеърът е същия...
Тoshiba REGZA 47VL863G [Preview]
http://www.fullhd.gr/2008-03-14-21-3...g-preview.html
Model: 32SL738G
1.03
Здраво ruzmarinx :Drinks:
Поздрав из Бугарске
32SL738 модела репродукује само JPEG, MP3 датотеке
WL768
(USB) - Containerformate MP4, AVI, ASF, MPEG-2-PS, MPEG2-TS, RMVB, MKV
(USB) - Dateiformate MP3, MP4, WAV, XVID, AVI, MPEG, TRP, TS, MPG, DIVX 2.2, DIVX 3.0, MKV, WMV
(USB) - Video Codecs H.264 (HD/SD), MPEG-4 SP, MPEG-4 ASP, DIVX 3.x, DIVX 4.x, DIVX 5.x, DIVX 6.0, WM9, MPEG1 (SD), MPEG2 (HD/SD), VC-1
(USB) - Audio Codecs MP3, AAC, HE-AAC, AC3, LPCM, ADPCM, WMA, MPEG1, MPEG2
WL743 JPEG, MP3, DivX-SD
YL768
YL743 JPEG, MP3, DivX-SD
VL748
VL743 JPEG, MP3, DivX-SD
SL738 JPEG, MP3
SL736 JPEG
SL733 JPEG
XL748
VL733 JPEG, MP3, DivX-SD
ZV743 JPEG, MP3, DivX-SD
XV743 JPEG, MP3, DivX-SD
XV733 JPEG
TV743 JPEG
RV743 JPEG
RV733 JPEG
BV700 JPEG. MP3
LV733 JPEG, MP3
AV734 JPEG, MP3
AV733 JPEG, MP3
Първоначално публикувано от 4o4o
Здравейте колеги, имам един въпрос. От седмица съм притежател на 42SL863G, има ли начин да се отключи възможността за запис на външен HDD?
И аз да повторя въпроса , че ме интересува активно, гледам по горния модел го има, а са идентични почти по всичко, вероятно и платките
Та как се влиза в сервизното меню на Тошиба
Първоначално публикувано от bonebiker
Влиза се много лесно, но след това не знам какво да правя.
При включен телевизор .
1. Натиснете бутона "Mute" на дистанционното веднъж.
2. След това натиснете отново и задръжте бутона "Mute" и едновременно с това натиснете и задръжте бутона "Menu" на телевизора..
3. Появява се буквата S на екрана, което означава, че телевизорът е в сервизен режим.
4. С клавишите CH + или CH - и VOL + и VOL-, можете да навигирате между настройките.
5. Натиснете бутона "Power", за да излезете от сервизното меню.
Не сем у нас сега не е при мен, :Drinks: но според теб ще стане ли????????? да де се :cheesy: озъбя и после да не мога да го върна в оригиналните настроики
Най-вероятно ще се озъбиш ,ако пипаш на посоки . Преди всяко пипане си запиши или снимай оригиналните настройки , че да ги възстановиш точно , не разчитай на паметта след две натискания ще забравиш и ще се объркаш !
Изчетох къде каквото намерих, но така и не стигнах до логичен отговор къде бъркам.
Притежавам от скоро 42SL863 , USB медия плеъра пуска 100% от видео файловете който го пробвах. Но субтитри в отделен файл НЕ , да изпълни UNICODE препоръките. Но като че ли тази тази опция въбще липсва , даже тествах с английски субтитри пак няма.
И тук идва забавната екстра субтитри от MKV файл тръгват без уговорки. Разходих се даже и до техномаркет за проба тествах SL833 със видео по избор там всичко е наред.... кеф ти отделни субтитри даже и с ASCII ...
Това доста ме дразни тъй като обезсмисля USB плеъра като цяло! Да си бях купил по-евтиния модел.
Някой намерил ли е решение на проблема?
Първоначално публикувано от mazalo
И аз се замислям,дали нещо в софтуера не са объркали,защото наистина никакви субтитри не вървят.Аз имам отделен DVD плеър а и медия сървъра му работи идеално,затова не съм се задълбочавал в ровичкане по телевизора,но няма логика да не вървят субтитри,освен ако нещо не са сбъркали японците.Не смея да ровя в сервизното меню,да видя да не са деактивирани от там.
По описания начин да се влезе в сервизното меню, не став на модел 42сл863г
Някой с други идей за влизане .
Пробва ли с ъпдейт?
http://www.dl.toshiba.com/tsb-dtv/NA.../42SL863G.html
Проверено на моят 42SL863G, влизам в сервизното меню без проблем, пробвай пак, като обърнеш внимание на точка 2.
Този фърмуеър(19.2.38.230) е по-стар от този на TV-то(19.2.49.2), купих го преди 10-тина дни от Техномаркет
Пробвай да свалиш външен файл със субтитри срт и го преименувай да е със същото име като видео файла -
като в края на името на субтитрите да добавиш SRT с големи букви. /не съм го пробвал/
Не не става и не става
звукът спира но не излиза никакво С на екрана колко и да го задържа
да не бъркаш бутоните нещо
? дистанционното ми еСТ-90369
оооооооооо стана Ама коригирай в т.2 думата ТЕЛЕВИЗОРА
Това S което се появява горе към ъгъла е доста малко и ако си встрани да държиш копчето от телевизора може и да не го видиш .
