Резултати от 1 до 15 от общо 28
Кой може да помогне за WINDOWS/SYSTEM32/AUTOEXEC.NT.
    Aug 2005
    Izhvarlil sam si programkata AUTOEXEC.NT. ot Windows-a .
    Kak i ot kade moga da q vzema i da q varna ili kakav e nachina da opravq greshkata ?
    Na vsichki otzovali se - predvaritelno blagodarq !!!
    Oct 2002
    Re: Кой може да помогне за WINDOWS/SYSTEM32/AUTOEXEC.NT.
    Naj lesno maj ste e da zaredish Recovery Console-to, i ot drug computar da si izkopirash tozi fajl s disketa.
  4. Moderator
    Mar 2005
    Вземи си го от c:\windows\repair, но преди това си пусни "Show hidden files and folders"
    Aug 2005
    MitkoS-- Blagodarq ti za saveta !Otvorih skritite papki. Show hidden files and folders-no kato otidoh na c:\windows\repair , tam imashe samo edna papka ,koqto ne beshe AUTOEXEC.NT. .Tarsih q i v system32 , no pak q nqmashe .Kade moje da e otishla i kak moga da q namerq ?
    Jun 2001
    по принцип ей това долу е съдържанието на autoexec.nt
    стандартен текстов фаил,копирай го от тук пастни го в текстов фаил и го ренеимни на autoexec.nt
    @echo off
    REM AUTOEXEC.BAT is not used to initialize the MS-DOS environment.
    REM AUTOEXEC.NT is used to initialize the MS-DOS environment unless a
    REM different startup file is specified in an application's PIF.
    REM Install CD ROM extensions
    lh %SystemRoot%\system32\mscdexnt.exe
    REM Install network redirector (load before dosx.exe)
    lh %SystemRoot%\system32\redir
    REM Install DPMI support
    lh %SystemRoot%\system32\dosx
    REM The following line enables Sound Blaster 2.0 support on NTVDM.
    REM The command for setting the BLASTER environment is as follows:
    REM SET BLASTER=A220 I5 D1 P330
    REM where:
    REM A specifies the sound blaster's base I/O port
    REM I specifies the interrupt request line
    REM D specifies the 8-bit DMA channel
    REM P specifies the MPU-401 base I/O port
    REM T specifies the type of sound blaster card
    REM 1 - Sound Blaster 1.5
    REM 2 - Sound Blaster Pro I
    REM 3 - Sound Blaster 2.0
    REM 4 - Sound Blaster Pro II
    REM 6 - SOund Blaster 16/AWE 32/32/64
    REM
    REM The default value is A220 I5 D1 T3 and P330. If any of the switches is
    REM left unspecified, the default value will be used. (NOTE, since all the
    REM ports are virtualized, the information provided here does not have to
    REM match the real hardware setting.) NTVDM supports Sound Blaster 2.0 only.
    REM The T switch must be set to 3, if specified.
    SET BLASTER=A220 I5 D1 P330 T3
    REM To disable the sound blaster 2.0 support on NTVDM, specify an invalid
    REM SB base I/O port address. For example:
    REM SET BLASTER=A0
  7. Senior Member Аватара на ru-boy
    Jan 2000
    @echo off
    Може и само това като пълнеж, другото е ремарки.
    Apr 2003
    Провери се за вируси, защото AUTOEXEC.NT се триеше от някакъв вирус, така че и пак да си го възстановиш той пак изчезва.
    За по сигурно след възстановяването му някъде в нета се препоръчваше да се направи read only.
    За спорта още един начин за възстановяването му е:
    1. Поставя се диска на Windows в CD устройството
    2. Отива се на CD устройството и се пише- > expand e:\i386\autoexec.nt_ c:\windows\system32\autoexec.nt
    При мен е устройство е:, при друг може да е с друга буква.
    Aug 2005
    Prijatel4eta nesam mnogo na ti s compovete no 6te vikaga dokade stignah i posle zapecnah.Kopirah tecsta"@echo off
    " i sled tova go pasnah v tecstov fail no sled tova nesam na jasno sas terminologijata "reneimni"na autoexec.nt.Napravih i drugo -kopirah faila* AUTOEXEC.NT ot drug komp na disketa i go slojih v system32 samo kato ikona i sega neznam kak daja aktiviram. :a nemoga i da si zaredja* "Recovery Console" predpolagam 4ese zarejda ot disk na* WINDOWS no nerazpolagam sas takav v momenta ---ta misaltamie ako njakoi ima tarpenie i nervi da mi objasni po prosti4ko kakvo trjabva da napravja 6te sam mu mnogo blagodaren* ----nesam ot tapi4kite no ot skoro se zanimavam s kompiotri no pak barzo shva6tam .
    Jun 2001
    кажи защо си се заял с тоя фаил?
    ако си го копирал от друг комп и сложил на правилното място не би трябвало да го пипаш повече
  12. Senior Member Аватара на ru-boy
    Jan 2000
    С AUTOEXEC.NT и без AUTOEXEC.NT na uindousa mu e wse taq i bez drugo ne polzwa tozi fajl. Toj e tam samo za sywmestimost.
    Aug 2005
    Vij sega ru-boy : po princip nee bolka za umirane i moga i bez AUTOEXEC.NT - no si kupih i printer sas skener i kogato mu instalirvah diska nemoja da instalira programkata "Status Monitor 3 [W]" tja mi trjabva v momenta v koito kopira6 ne6to otstrani se pogazva malka diagramka za sastojanieto na boite -eto za tova mi trjabva tozi fail
    Aug 2005
    [quote=Ivo Wolfen ]
    [/quot
    izkopirahsi faila na disketi no tova Recovery Console-to,--bilimi objasnil kak dago zareda ot diska na WINDOWS ili ot drugo mjasto
  16. Senior Member Аватара на ru-boy
    Jan 2000
    AUTOEXEC.NT няма нищо общо с проблема който описваш. Нещо се бъркаш.
    Jun 2001
    възможное заради съвместимоста с досовски програми,както клипърските програми искат баране на config.nt
    Apr 2002
    Dai e-mail da ti pratya fixa za XP...
  1. Може ли някой да помогне
    От TonyB във форум Телевизори
    Последно: 19-12-11, 21:29
  2. Който може да помогне !
    От Fr3sH във форум Мрежи
    Последно: 10-05-11, 21:25
  3. Error loading c:\windows\system32\rvinhvvh.dll
    От Popkaro във форум Windows
    Последно: 23-11-10, 23:52
  4. въпрос за c:\windows\system32\dllcache
    От presents във форум Windows
    Последно: 02-12-06, 13:18
