PC-to NE IZKLJUCHVA
PORADI NEPONJATNI PRICHINI PC-TO UVISNA I SLED VSICHKI OTITI SE NALOJI DA IZTRIJA CJALATA PATRICIA I DA ZAREDJA WIN ME OTNOVO.
IMAM NA DRUGA PARTICIA WIN 2000, I NEGO IZTRIH I ZAREDIH OTNOVO. IZPOLZUVAH SLUCHAJA
I PROMENIH GOLEMINATA NA POVECHETO PARTIZII
( IMAM 3 HDD S OBSHTO 13 PARTICII), OSVEN TOVA NKAJOI BJAHA NA FAT, A GI KONVERTIRAH NA FAT32. ZAREDIH I BOOT MAGIC I PC-TO TRAGNA.
DOTUK DOBRE, OBACHE NE ISKA DA IZKLJUCHVA NORMALNO. PROSTO UVISVA CHEREN EKRAN, I NE SE POJAVJAVA SAOBSHTENIE, CHE MOGA DA GO
IZKLJUCHA. ZASEGA GO IZKLJUCHVAM, KATO NATISNA RESET, I KOGATO BIOSA ZAPOCHNE DA SE ZAREZHDA, GO IZKLJUCHVAM S BUTOVA, NO VSEKI
SLEDVASHT PAT PC-TO PROVERJAVA HDD ZASHTOTO
SA GO IZKLJUCHIL NEPRAVILNO.
PC-TO MI E S:
P III 800(133)SOCKET 370
256 SDRAM(133)
MOTHERBOARD VIA 694X/596B
3 HDD(OBSHO 46 GBT)
AKO NJAKOI IMA IDEJA, MOLJA SPESHNO DA KAJE.
BLAGODARJA.
CECO
PC-to NE IZKLJUCHVA
Az imam sushtia problem - samo che vmesto
shut down mi restarira.
Ako ne te trevoji chak tolkova tova che triabva da go izkliuchvash ot kopcheto:
START > RUN > msconfig > Advanced > Disable
Scan Disk after bad Shut Down
PC-to NE IZKLJUCHVA
problema e w nqkoj driver na device w pc-to ti.
eto edin primer ot moq opit:
1. permedia2 - np sys shutdown
2. slagam banshee sys nekwi symnitelni driveri - ne gasi i sedi na cheren ekran ili na shutting down
3. slagam nVIDIA i driveri ot saita im i pak nqma problem.
windowsa ne e preinstaliran
PC-to NE IZKLJUCHVA
Scandisk по лесно се изключва в config.sys
Където пише AutoScan=1 се променя на 0 и е ОК. Просто е по-кратко (май)...
__________________
A Steve Morse Fan!!!
PC-to NE IZKLJUCHVA
Ivory беше пуснал този линк:
www.aumha.org/a/shutdown.htm
pjMarvin
pjMarvin@abv.bg
ICQ:44404963
Променено от pjMarvin на 19/02/2001 10:01:34
PC-to NE IZKLJUCHVA
Az imam syshtiq problem. Pri men se poluchi sled kato updatevah driverite na dynoto - slozhih poslednite za momenta "VIA all in one" ili neshto podobno.
Rezultata e, che sega ne se zagasq a si stoi na Shutdown do bezkraj :)))
PC-to NE IZKLJUCHVA
skapi prijateli,
oshte ne sam mnogo siguren, no mislja, che namerih "VINOVNIKA". blagodarja za vashite
mnenija. sega konretno, zashtoto moje da e ot polza za vseki:
reshih, che edinstvenata nova programa, koiato zaredih e"Boot Magic".
deinstalirah ja, i instalirah otnovo win 2000, koito ima sobstveno bootmeniu.
"Boot magic" e edna sapatstvashta programa ma "Partition Magic", kojato e mnogo dobra, no izglejda, che bootmagic ne se ponasja s 2 Windowsa(win 2000 i win me), i ne iska da iskljuchva pc-to.
sega pri start poluchavam bootmeniu ot win2000 i moga pez problemi da izbiram win 2000 ili win me(i pc-to izkliuchva normalno).
radvam se, ako tazi info pomogne i na njakogo v badeshte.
za sega chao i do novi sreshti.
ceco
PC-to NE IZKLJUCHVA
izglezhda malko sam izbarzal, problemat ne e reshen, sega win 2000 izkljuchva normalno, no win me pak ne iska(v nachaloto dva-tri pati izkljuchiha i dvata).
kato posleden variant mislja da zaredja win me otnovo, no tova znachi da zaredja otnovo i win 2000, zashtoto toi trjabva da bade zareden vtori, za da se javi bootmenjuto na win 2000 i da moga da polsuvam i dvata win.
tai kato posledvashtata konfiguracia na win sas vsichki driveri, programi i t.n. e mnogo dalga i obremenitelna, osobeno za dva win,
ako njakoi ima oshte idei, kak da izkljucha win me normalno, molja da gi spodeli.
ceco
PC-to NE IZKLJUCHVA
1. Baby Thomas e dopusnal gre6ka (spored men)
kato e napisal "config.sys",wmesto "msdos.sys".
2. ceco, probwaj:
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Shutdown\FastReboot=0
(Ima6e i po-lesen na4in, no ne sam siguren,
moze bi be6e:
START > RUN > msconfig > Advanced > Disable Fast ShutDown)
Nadjawam se towa da ti pomogne...
Променено от Ghost на 22/02/2001 01:28:11
PC-to NE IZKLJUCHVA
i moito ne izkluchwa pod 2000
nqma ACPI na starite BX chipseti mai
PC-to NE IZKLJUCHVA
Да, бе. То е ясно. Ама като пиша на 18 места...
__________________
PC-to NE IZKLJUCHVA
opravih probema. chrez posledovatelno izkljuchvane na programi i driveri
lokalizirah prichinata- drivera na mishkata
genius net scroll optical(driverat beshe ot
originalnata disketa). svalih ot interneta po-now drivaer(za winME) i vsichko e ok.
blagodarja na vsichki, koito mi dadoha saveti.
