А можеш ли да погледнеш датата и размера на файла rundll32.exe ?
При мен
rundll32.exe е с размер 33К (33 280)
и с някаква стара дата 04.08.2004
А като цъкна Properties/Version, виждам
File Version: 5.1.2600.2180
При мен
Julian, я виж при теб как са.
Код:Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\*]
"QuickTip"="prop:Type;Size;Write"
"InfoTip"="prop:Type;DocAuthor;DocTitle;DocSubject;DocComments;Write;Size"
"AlwaysShowExt"=""
"TileInfo"="prop:Type;Size"
[HKEY_CLASSES_ROOT\*\OpenWithList]
[HKEY_CLASSES_ROOT\*\OpenWithList\Excel.exe]
[HKEY_CLASSES_ROOT\*\OpenWithList\IExplore.exe]
[HKEY_CLASSES_ROOT\*\OpenWithList\MSPaint.exe]
[HKEY_CLASSES_ROOT\*\OpenWithList\Notepad.exe]
[HKEY_CLASSES_ROOT\*\OpenWithList\Winword.exe]
[HKEY_CLASSES_ROOT\*\OpenWithList\WordPad.exe]
[HKEY_CLASSES_ROOT\*\shellex]
[HKEY_CLASSES_ROOT\*\shellex\ContextMenuHandlers]
[HKEY_CLASSES_ROOT\*\shellex\ContextMenuHandlers\Offline Files]
@="{750fdf0e-2a26-11d1-a3ea-080036587f03}"
[HKEY_CLASSES_ROOT\*\shellex\ContextMenuHandlers\Open With]
@="{09799AFB-AD67-11d1-ABCD-00C04FC30936}"
[HKEY_CLASSES_ROOT\*\shellex\ContextMenuHandlers\Open With EncryptionMenu]
@="{A470F8CF-A1E8-4f65-8335-227475AA5C46}"
[HKEY_CLASSES_ROOT\*\shellex\ContextMenuHandlers\WinRAR]
@="{B41DB860-8EE4-11D2-9906-E49FADC173CA}"
[HKEY_CLASSES_ROOT\*\shellex\ContextMenuHandlers\{a2a9545d-a0c2-42b4-9708-a0b2badd77c8}]
@="Start Menu Pin"
[HKEY_CLASSES_ROOT\*\shellex\PropertySheetHandlers]
[HKEY_CLASSES_ROOT\*\shellex\PropertySheetHandlers\CryptoSignMenu]
@="{7444C719-39BF-11D1-8CD9-00C04FC29D45}"
[HKEY_CLASSES_ROOT\*\shellex\PropertySheetHandlers\{1F2E5C40-9550-11CE-99D2-00AA006E086C}]
[HKEY_CLASSES_ROOT\*\shellex\PropertySheetHandlers\{3EA48300-8CF6-101B-84FB-666CCB9BCD32}]
[HKEY_CLASSES_ROOT\*\shellex\PropertySheetHandlers\{883373C3-BF89-11D1-BE35-080036B11A03}]
@="Summary Properties Page"
Има един сигурен начин да изловиш какво се случва:
Sysinternals =>Filemonitor, Process Monitor, Reg Monitor както и TCP view
Пробвай с всяка една поотделно и виж какво причинява забявянето
Това и направих в крайна сметка, след като така и не успях да намеря причината за забавянето, а и нямах наистина много време да губя.Цитат:
Първоначално публикувано от Riki888
Благодаря на всички, взели отношение по темата.
защо не видиш макрос настройките - намират се в туулс -> секюрити
смъкни на лоу и кажи как е
от личен опит!
