Component .NET Framework 2.0 has failed to install with the following error mess
  Моля някой да ми каже какво да направя за да мога да инсталирам този framework (при опит за инсталване ми пише:
Component .NET Framework 2.0 has failed to install with the following error message:
"The Windows Installer Service could not be accessed. This can occur if you are running Windows in safe mode, or if the Windows Installer is not correctly installed. Contact your support personnel for assistance. "
The following components failed to install:
- .NET Framework 2.0
See the setup log file located at 'C:\DOCUME~1\PC-1\LOCALS~1\Temp\VSD5A.tmp\install.log' for more information.
     Re: Component .NET Framework 2.0 has failed to install with the following error mess
  и когато отворя 'C:\DOCUME~1\PC-1\LOCALS~1\Temp\VSD5A.tmp\install.log' ми пише
The following properties have been set:
Property: [AdminUser] = true {boolean}
Property: [ProcessorArchitecture] = Intel {string}
Property: [VersionNT] = 5.1.2 {version}
Running checks for package '.NET Framework 2.0', phase BuildList
Running external check with command line "C:\DOCUME~1\PC-1\LOCALS~1\Temp\VSD5A.tmp\dotnetfx\dotnetchk.exe"
Process exited with code 0
Setting value '0 {int}' for property 'DotNetInstalled'
Reading value 'Version' of registry key 'HKLM\Software\Microsoft\Internet Explorer'
Read string value '6.0.2900.2180'
Setting value '6.0.2900.2180 {string}' for property 'IEVersion'
The following properties have been set for package '.NET Framework 2.0':
Property: [DotNetInstalled] = 0 {int}
Property: [IEVersion] = 6.0.2900.2180 {string}
Running checks for command 'dotnetfx\instmsia.exe'
Result of running operator 'ValueExists' on property 'VersionNT': true
Result of checks for command 'dotnetfx\instmsia.exe' is 'Bypass'
Running checks for command 'dotnetfx\WindowsInstaller-KB893803-v2-x86.exe'
Result of running operator 'ValueExists' on property 'Version9x': false
Result of running operator 'VersionLessThan' on property 'VersionNT' and value '5.0.3': false
Result of running operator 'VersionGreaterThanOrEqualTo' on property 'VersionMsi' and value '3.0': true
Result of checks for command 'dotnetfx\WindowsInstaller-KB893803-v2-x86.exe' is 'Bypass'
Running checks for command 'dotnetfx\dotnetfx.exe'
Result of running operator 'ValueNotEqualTo' on property 'DotNetInstalled' and value '0': false
Result of running operator 'ValueEqualTo' on property 'AdminUser' and value 'false': false
Skipping FailIf because Property 'Version9X' was not defined
Result of running operator 'ValueNotExists' on property 'IEVersion': false
Result of running operator 'VersionLessThan' on property 'IEVersion' and value '5.01': false
Result of running operator 'ValueNotEqualTo' on property 'ProcessorArchitecture' and value 'Intel': false
Result of checks for command 'dotnetfx\dotnetfx.exe' is 'Install'
'.NET Framework 2.0' RunCheck result: Install Needed
Running checks for package 'Windows Installer 3.1', phase BuildList
The following properties have been set for package 'Windows Installer 3.1':
Running checks for command 'WindowsInstaller3_1\WindowsInstaller-KB893803-v2-x86.exe'
Result of running operator 'VersionGreaterThanOrEqualTo' on property 'VersionMsi' and value '3.1': true
Result of checks for command 'WindowsInstaller3_1\WindowsInstaller-KB893803-v2-x86.exe' is 'Bypass'
'Windows Installer 3.1' RunCheck result: No Install Needed
EULA for components '.NET Framework 2.0' was accepted.
Copying files to temporary directory "C:\DOCUME~1\PC-1\LOCALS~1\Temp\VSD5A.tmp\"
Downloading files to "C:\DOCUME~1\PC-1\LOCALS~1\Temp\VSD5A.tmp\"
(23.11.2000 г. 00:33:28) Downloading 'dotnetfx\dotnetfx.exe' from 'http://go.microsoft.com/fwlink/?LinkId=37283' to 'C:\DOCUME~1\PC-1\LOCALS~1\Temp\VSD5A.tmp\'
Download completed at 23.11.2000 г. 00:46:12
Verifying file integrity of C:\DOCUME~1\PC-1\LOCALS~1\Temp\VSD5A.tmp\dotnetfx\dotnetfx.exe
WinVerifyTrust returned 0
File trusted
Running checks for package '.NET Framework 2.0', phase BeforePackage
File trusted
Installing using command line '"C:\DOCUME~1\PC-1\LOCALS~1\Temp\VSD5A.tmp\dotnetfx\dotnetfx.exe" /q:a /c:"install /q /l"'
Process exited with code 1601
Status of package '.NET Framework 2.0' after install is 'InstallFailed'
  пардон, не дочетох докрая
трябва ти Windows Installer v.3.1
тука е : http://www.microsoft.com/downloads/d...displaylang=en
и освен това Администратор права и нормален режим (не Safe Mode)
п.с., може да се пробва още:
[Start Menu] -> Run
пише се msiexec /unreg
изчаква се да спре процеса (не знам колко - 2-3 сек.)
след това пак [Start Menu] -> Run
пише се msiexec /regserver
пак се изчаква, след това пробвай инсталацията на .NET v2.0
  Еми нищо не става, благодаря ти все пак иначе си имам тази версия на инсталатора.
Когато пробвам тези команди msiexec ми излиза полу прозорец но в него не мога да правя нищо пише нещо свързано с инсталатора (не ми дава да копирам)
