Моля някой да ми каже какво да направя за да мога да инсталирам този framework (при опит за инсталване ми пише:
Component .NET Framework 2.0 has failed to install with the following error message:
"The Windows Installer Service could not be accessed. This can occur if you are running Windows in safe mode, or if the Windows Installer is not correctly installed. Contact your support personnel for assistance. "
The following components failed to install:
- .NET Framework 2.0
See the setup log file located at 'C:\DOCUME~1\PC-1\LOCALS~1\Temp\VSD5A.tmp\install.log' for more information.
