Re: Basic или Dynamic disk?
Разгледай в хелпа командата
>diskpart с параметър extent
Може и да не ти се наложи да се правиш на дайнамик.
Код:
DiskPart
DiskPart.exe is a text-mode command interpreter that enables you to manage objects (disks, partitions, or volumes)
by using scripts or direct input from a command prompt.
extend
Extends the volume with focus into next contiguous unallocated space. For basic volumes, the unallocated space
must be on the same disk as, and must follow (be of higher sector offset than) the partition with focus.
A dynamic simple or spanned volume can be extended to any empty space on any dynamic disk. Using this command,
you can extend an existing volume into newly created space.
If the partition was previously formatted with the NTFS file system, the file system is automatically extended to
occupy the larger partition. No data loss occurs. If the partition was previously formatted with any file system format
other than NTFS, the command fails with no change to the partition.
You cannot extend the current system or boot partitions.
Syntax
extend [size=n] [disk=n] [noerr]
Parameters
size=n
The amount of space, in megabytes (MB), to add to the current partition. If you do not specify a size, the disk
is extended to take up all of the next contiguous unallocated space.
disk=n
The dynamic disk on which to extend the volume. An amount of space equal to size=n is allocated on the disk.
If no disk is specified, the volume is extended on the current disk.
noerr
For scripting only. When an error is encountered, specifies that DiskPart continue to process commands as if the
error did not occur. Without the noerr parameter, an error causes DiskPart to exit with an error code.
а защо чисто и просто не зарежеш windows tool-овете и не работиш като бял човек с partition magic, acronis и т.н. специализиран софтуер?
Първоначално публикувано от FearMe
бих опитал веднага, но имам малко притеснения за системния дял, т.като никак не е желателна евентуална преинсталация в момента
не се притеснявай. аз лично ползвам partition magic от маса време и единственият проблем, който ми се случи един път беше по време на токов удар, така че... ;)
Един предварителен бекъп с Ghost никога не пречи ;-)
Не вярвам да ти казвам нещо ново, но то си е правило. Нов диек си го цепиш поне на 2 дяла. Аз съм го разделил на 4-един за ХР, един за Виста, един за данни и един за Linux. Така че дори и след време да ти потрябва нещо винаги можеш да жертваш някой от тях-най често тоя за данни. Ако те е страх с тоя да експериментираш, направи си първо експеримента с някой който можеш да прежалиш. Скоро не ми се е налагало да правя такива акробатики поради наличието на големи дискове. Преди съм го правил с Partition Manager-a. А и технически погледнато процеса на преоразмеряване е елементарен и не вярвам да имаш проблеми. Все пак архивирай!!! Далеч по безболезнено ще е да добавиш един нов диск, те и без това не са скъпи вече. така ще имаш и по голяма сигурност :) Ако нямаш с какво да експериментираш пиши ми аз имам налични системи за тестване и ще го направя за теб.
Всичко мина нормално!
не направих имидж на С:, стиснах очи и ...... :god но partition magic свърши отново работа... :ole
Първоначално публикувано от Minava6t
Диска е сцепен на 4 -ХР, Vista, data и fun. Tочно дяла отделен за виста беше обект на цялата манипулация. Просто тя (Вистата) загуби шансове скоро да ми радва окото. Нейния дял го добавих към С, тъй като заради нея С беше прекалено малък и ми спъваше работата.
Що се отнася до нов диск... е как пък няма да купувам и да слагам нов хард диск на служебен компютър... :)
Minava6t Благодаря за желанието да помогнеш!
Както и на всички, споделили мнение по-горе! :Drinks:
Да добавя, че снощи забелязах, че при Vista SP1, може да се прави Shrink и Extent на основния дял на основния диск директно (с мишката) през Disk Management. Няма значение дали е basic или dynamic.
