Резултати от 1 до 15 от общо 22
Undelete - Recovery 3.0
    Jun 2002
    S win2k server sym i tyrsq programa za recovery /undelete/ na files. Namerih tazi koqto sym posochil recovery 3.0, koqto raboti perfektno i ima 18 nachina za undelete. Loshoto e che ne moga da si namerq crack i mi undelete-va samo 10 kb. Ako nqkoj ima ideq i moje da help-ne shte sym blagodaren. Cheers
  3. Cko
    Cko е офлайн
    Senior Member
    Aug 2001
    Програмката да не се казва EasyRecovery, аз я имам кракната, мога да ти я пратя ако искаш
    May 2002
    Easy Recovery - na www.free.evro.net ia ima
    (craknata si e )
    SUPER e - minalata sedmica si zatrih 27GB dial - i si varnah informaciata, no zabravih nai-vajnata papka
    Jun 2002
    ne mi gi vyzstanovqtat kakto trqbva. tazi programa predlaga nqkolko metoda na undelete i kato gi probvam vse edin ot tqh stava. a pri tezi ne moga da si izbera metoda na undelete i v krajna smetka gi vyzstanovqva greshno
    Jun 2001
    http://free.techno-link.com/Flex-2/O...fessional%206/
    S tova neshto sa spaseni suma ti diskove, vkliu4aq v4era sriva na hdd-to pro koeto zagubih vsi4kite si source-ta. V momenta imam 96-7% ot tqh - vsi4ki drugi programi za recovery mi izvlqkoha 1-2 fail4eta pri tova napulno omazani. Nqmam dumi, nqkoi den shte si q kupq taq programa
    Dec 2000
    Ne moga da razbera koja versija e ot linka, koito Flex dava, no v momenta imam cracknata versija EasyRecovery 6.xx, ako vse oste ja njamate, pi6ete da ja ka4a njakyde
    Jun 2002
    polzvam win2k i qvno neshto promenq, zashtoto ne moga da go undelete-na kato horata.vyv filerecovery 3.0 probvat nqkolko varianta i stava vyzstanovqvaneto. vijte kakvo pishe
    In Windows® 2000/XP (all versions), whenever an entry (file or folder) is deleted the higher order word of the 32-bit starting cluster is erased by the operating system. Hence the correct value of the starting cluster at the time of recovering the entry is not known. Without the exact knowledge of the starting cluster no recovery tool can find out and successfully undelete a deleted entry. To overcome this problem FILERECOVERY for Windows® has devised a solution. Depending on the size of the disk, it generates probable starting cluster values of the file selected for undelete or the folder. In the case of a folder the program will automatically try all multiple combinations which may result in a delay during reading process - in the case of a file it will ask the user to test each of the multiple combinations. To decide if the file has been recovered you should open the file with the software program applicable to the type of the file recovered - if the application cannot open the file you should let FILERECOVERY continue with the next combination until the test succeeds.
    If the drive's cluster size exceeds a certain cluster count (depending of the size of the disk), there are too many possible combinations (> 256) and this feature will be limited to this certain cluster count.
    V EasyRecovery 6 Professional vlizam v advance settings no imam chustovo, che kato mu zadam pravilnite parametri i neshto se obyrkva. EasyRecovery 6 Pro. tyrsi za cluster size=16 kb i za BytesPerSector = 256 b, a moite sa cluster size=32 kb i BytesPerSector = 512 b. obshto vzeto sa go napravili dosta prostashko. eto q i informaciqta mi za HDD-to. Ako nqkoj ima ideq ......
    Cylinders HeadsPerCylinder SectorsPerHead BytesPerSector MediaType
    7943 240 63 512 12
    TrackSize = 32256, CylinderSize = 7741440, DiskSize = 61490257920 (58641MB)
    Signature = 0xa227a227
    StartingOffset PartitionLength StartingSector PartitionNumber
    * 32256 20299958784 63 1
    20300023296 20974431744 63 2
    41274487296 17824149504 63 3
    MBR:
    Starting Ending System Relative Total
    Cylinder Head Sector Cylinder Head Sector ID Sector Sectors
    * 0 1 1 1023 254 63 0x0c 63 39648357
    1023 0 1 1023 254 63 0x0f 39648420 75778605
    0 0 0 0 0 0 0x00 0 0
    Jun 2001
    Trastikata - 6-cata mi e - tova %20 e reprezentaciqta na interval, also ka4il sum posledniq update.
    DHCP mdam... sushtoto s failovete pravi i easyrecovery, samo deto ti gi dava nakup posle vsi4kite kombinacii kato nai-4itavite sa nai-otdolu (to zavisi kak si gi podredish de). Smeshnoto e 4e mi izkara vsi4kite promeni na nqkoi fail koito sum pravil za meseci nazad - ebasi
    Hmm... a v advanced ako zadadesh to4nite parametri? I shto ne probvash updateto da ne go opravq?
    Jun 2002
    Flex instalirah si update-a no pak ne stava. Neshto se byrka . A naj-interesnoto e che goleminata na clustera kojto mi pokazva Easyrecovery 6.0 e 16384 i 32768, koeto sprored men ne sa mnogo tochni danni .
    Kato si pusna edna programa na microsoft ot Resource kit-a mi dava che goleminata na cluster-a na HDD-to mi e TrackSize = 32256
    Na koj da vqrva chovek .
    Nqma li koj da crack-ne filerecovery-to
    Jun 2001
    Hmm... az po mi se 4ini da vqrvam na Ontrack
    a s partition magic mojesh sushto da si vidish dannite, partinfo mai imashe tam koeto vurshi rabota. No shte se opitam da ti namerq cracknata filerecovery 4e 4esno mnogo rabota imam i ne moga da otdelq i za tova
    Stand by...
    Jun 2002
    Flex, shte ti byda bezkrajno blagodaren .
    Sep 2002
    geniusloki
    kaza 4e q ima v evro neta cracknata ste ti bada blagodaren ako mi dades to4en link za download
    Mar 2002
    Dec 2000
    NIama li nachin s Easy Recovery da se kopira na sushtata particiq ? Ne mi se delka harda tochno v momenta
    Jun 2002
    Aquadark kakvo imash predvid syshtata particiq? Mojesh da q bootnesh ot disketa ili ot CD.
    Tazi versiq koqto e ot http://free.techno-link.com/animania...LERECOVERY.exe e super stara i ne vyrshi rabota, syshto taka ne raboti i pod winNT i win2k. Izteglete si novata 3.0 kakto e napravil Flex i q vijte. Programata si stryva da se crack-ne.
    Cheers
  1. ASUS EEE PC Recovery DVD
    От ru-boy във форум Общ - софтуер
    Последно: 12-12-12, 20:07
  2. Multiboot Recovery CD
    Последно: 20-09-06, 10:01
  3. Recovery на CD-RW?-как
    От fiorino във форум Общ - софтуер
    Последно: 13-10-05, 13:06
  4. Как се Undelete-ва?
    От dimoh_H във форум Общ - софтуер
    Последно: 07-06-05, 11:57
  5. UNDELETE
    От MANIAK във форум Общ - софтуер
    Отговори: 18
    Последно: 24-04-02, 19:16
