Re:Пълен хард диск и парола на БИОС-а
Първоначално публикувано от myrshavija
Здравей,
Не точно по темата, искам да ти дам един съвет:
Да проучиш какво се случва, когато администраторът/работодателят научи, че заобикаляш ограниченията наложени от него.
нищо чудно да дойде и той тук да пита как да махне паролата на BIOS-а, която е сложил NeRoX :))
Първоначално публикувано от NeRoX
Май ви се изчерпаха идеите...
Първоначално публикувано от FearMe
намерих това за ресетване на паролата на дъното.
пробвалите го твърдят, че работело:
To resolve the administrator password reset on a machine the user must first reset the RTC by removing the AC power supply, then the laptop battery, finally remove the hard-drive and the watch type battery under the hard-drive. Second: wait for about 6 minutes. Next install the watch type battery and the hard-drive(screw the cover for the hard-drive back in place afterwards). Next do not put the laptop battery on, just plug in the AC adapter and power the machine on for a minute or so. You should see an error message advising the bios has recovered. Now you can put the battery back on.
This is not all.
Next power the machine to boot into windows. If your drivers are in for the wireless or Lan card open internet explorer and navigate to HP.com and select suppport, select downloads and enter 6530b. it will take to to page to select the Operating system your using. Select your Operating system and on the driver page you need download the fingerprint reader driver, HP ProtectTools Security Manager 4.10 and HP ProtectTools BIOS Configuration. Install the fingerprint driver (if needed) HP Protect Tools software and HP ProtectTools BIOS Configuration . After reboot run HP ProtectTools Security Manager For Administrators and choose Bios configuration. You will see at the top a place for you to enter a password for the BIOS however BIOS will not give you this option alone so set your new BIOS Password and when you restart the machine press F10 to get bios setup, enter your password and choose "User Management" delete the user under Protect tools User. select reset fingerprint reader and under TPM select "reset to factory defaults".
Тази идея пробва ли я?
Здравей,
Това не е проблем. Тях ги интересува хората да си вършат работата, а не как си я вършат. Мисля, че няма смисъл да се впускаме в детайли.
Не ти разбрах шегата. Надявам се да е добра...
Първоначално публикувано от Usera
Това е чисто и просто сваляне на батерията на дъното, което както казах съм го правил отдавна. Единствената разлика, която виждам е че автора казва да се включи лаптопа със извадена батерия. Това само не съм го пробвал. Бях го включил след като сложих батерията (на дъното). Продължението на гайда се свързано с влизане в Windows, което няма как да стане, защото нямам работещ такъв на хард диска както вече споменах няколко пъти.
имах предвид, че ако ти решим проблема и замениш паролата на BIOS-a с твоя, а админът научи, той на свой ред ще иска да махне твоята и да върне своята, и за да разбере как да го направи, ще дойде във форума да пита :)
Почнах да мъча XP вече. Пробвах и двете предложения, но пак без резултат. Инсталирах ХР-то на другия лаптоп (моя хард, разбира се) точно до първия рестарт. На първия рестарт точно още на първия екран извадих диска и харда. Сложих ги на моя. Зарежда пак до Windows екрана и отново син екран. По точно -
ТОЗИ. И от там съответно рестарт нали. Пробвах и другия вариант. Изтрих C-то като партитишън изцяло без формат и извадих диска и харда от другия лаптоп. Отново на моя... Все, че ми каза "Any key to boot from CD". Тръгна инсталацията на XP. Напрао се зарадвах, че съм го излъгал. Да, ама не... Още в началото на инсталацията на XP докато екрана и син и долу си зарежда някакви файлове (не в проценти) ми показа синия екран на който качих снимката горе, отново. Пробвах с няколко рестарта разбира се, но все до там стига. Буутва си от CD-то и си почва инсталацията нормално и стига до синия екран всеки път.
Може и да съм пропуснал нещо от писаното по темата, но я четох отгоре-отгоре. Извинявам се ако предложа нещо което вече е предлагано.
Според мен щом си успял да стартираш boot-тващ диск, тествай първо памет и хард за грешки - в hiren's boot cd ще намериш програми за това.
Казваш при инсталация на XP, инсталацията спира със син екран. Пробва ли да пуснеш инсталация на в WIN7?
Възможно е ако до сега лаптопа е бил с WIN7 в биоса да има настройка за AHCI режим и от там и синият екран при опит за инсталиране на WIN XP.
ама то туй е ясно, че е така и какво?
Първоначално публикувано от fXOrange
Не разбрах това "туй" какво е и на кой му е ясно, че е "туй". Ако имаш предвид, че има зададена настройка в биоса за AHCI mod и това е ясно (тук не разбирам от къде идва тази яснота при положение, че не може да се влезе в настройките на биоса), тогава защо въобще се опитва да се инсталира WIN Xp?
Питаш "и какво"?
Ми по-горе предложих да опита с инсталация на Win 7
Ако наистина е така, то сисадминът ви няма да има нищо против да ти отключи биоса и да те добави в групата на локалните администратори. Нали?
Първоначално публикувано от loafer
Буутвам само, ако на лаптопа няма закачен хард, демек няма как да ги направя тези тестове за грешки. Инсталирането на Windows-и ставаше на моя хард, но на друг лаптоп. При Windows XP и при пълна инсталация на ОС-а и при първия рестарт да сложа харда пак на моя лаптоп си дава син екран. При Windows7 пак стига до някакъв син екран. Не знам за какви налични файлове от стара инсталация имаш предвид. C-то го форматирам преди всяка нова инсталация.
Както казах - коментарите по тази тема за безсмислено. Лаптопа е пуснат служебен по дълга верига. Ние имаме връзка с най-ниските нива, които си нямат хал хабер за какво става на въпрос. Да приемем, че съм я забравил паролата просто. На този етап нямам възможност да я разбера. Трябва да е по трудния начин.
Буутвам само, ако на лаптопа няма закачен хард, демек няма как да ги направя тези тестове за грешки. Инсталирането на Windows-и ставаше на моя хард, но на друг лаптоп. .......
Останах с впечатлението, че си успял да пуснеш инсталация на Win XP на проблемният лаптоп. Явно не съм разбрал правилно.
............ Пробвах и другия вариант. Изтрих C-то като партитишън изцяло без формат и извадих диска и харда от другия лаптоп. Отново на моя... Все, че ми каза "Any key to boot from CD". Тръгна инсталацията на XP. Напрао се зарадвах, че съм го излъгал. Да, ама не... Още в началото на инсталацията на XP докато екрана и син и долу си зарежда някакви файлове (не в проценти) ми показа синия екран на който качих снимката горе, отново. Пробвах с няколко рестарта разбира се, но все до там стига. Буутва си от CD-то и си почва инсталацията нормално и стига до синия екран всеки път.
Извинявам се! Тук грешката е моя. От толкова много преинсталации вече забравих кога какво е ставало. :D И да... В конкректния случай и изтрит партитишън (не само форматнат) и диск с Win XP тръгва да прави инстал и стига до син екран и се ресва. Това е още далеч преди да ме пита къде искам да инсталирам ОС-а. И да прав си... В това въпросно състояние на хард диска наистина пробвах само с Windows XP. С Hiren's не съм пробвал, защото прецених, че няма да има какво по-различно да направя, а с Win7 изобщо забравих да пробвам. Това ще е следващото, което ще опитам.
Има ХП компилации с вградена и активирана SATA поддръжка. Потърси в замундата. Това вероятно ще ти реши проблема със синия екран.
Пусни тест само на РАМ-а.
Колега , виж какво пише по-нагоре. Грешката е заради сата харда - 0х00000007b
Тамън изтрих пак Partition C през другия лаптоп и да запиша Win7 на DVDRW и то (DVD-то) все че се омаза. Пуснах му един Erase, изтри го с малко странни шумове от записвачката и сега май се омаза. Като го сложа в записвачката не иска да го зареди и като му цъкна с десен бутон на мишката (на дисково устройство в My Computer) и забива. Стига до "Don't Send"... Демек не мога да изпразня диска. Не мога да запиша и нищо ново на него. По това време абсурд да намеря. Само проблеми, заеби...
