Как мога да върна лаптоп Sony-PCG-6121m към първоначалната фабрична инсталация.
    Aug 2005
    Philippines
    Дайте съвет как мога да върна лаптоп Sony-PCG-6121m с Windows 7 към първоначалната фабрична инсталация.
    Инсталационно DVD няма. Вероятно има системен дял от който се преинсталира. Не знам и как да изпиша в търсачката на Google та да намеря някаква помощ.
  3. Super Moderator
    Dec 2000
    Sofia
    Отговор: Как мога да върна лаптоп Sony-PCG-6121m към първоначалната фабрична инсталация.
    Click start, all programs, system recovery
    1. Connect the PC to the AC power adapter. (Make sure you on AC Power when doing this and not battery)
    2. Close all programs.
    3. Click Start , click All Programs , select System Recovery , and click PC Recovery .
    4. When the recovery options are presented, select the option to perform the PC Recovery and click Next .
    5. The PC will restart.
    6. When the Welcome to PC Recovery message displays, click OK to continue.
    7. On the System Recovery panel, select System Recovery . By default, the system will perform a complete reformat and will destroy all user data.
    8. Restart the PC when prompted.
    As an alternate method to the steps above, click Advanced Options , and select the Destructive Recovery option, and click Next to begin the reformatting process.
    The PC is in the original factory condition and all system data, such as location and date must be reconfigured.
    Note: This shouldn't take long, when I did it for my sister it was not more then an hour.
    Now after you have restore the laptop back to factory defaults, you should still be able to create the recovery cd/dvd if you so wish. If you do here are the steps to do that.
    1. Again make sure the laptop is plugged into the AC
    2. Click Start , click All Programs , select System Recovery , and click Create Recovery Disks .
    The PC Recovery Disk Creator utility displays a message indicating the type and number of media disks required.
    3. Verify the required number of media disks are available.
    4. Click Next to begin the actual copying process.
    Remove written disk and insert additional disks when prompted.
    5. Label each disk, in sequence it was created, as prompted.
    6. Store the newly created set of recovery disks in a safe place.
    This process should only take 1hr-2 1/2 hrs
    Note: This process can only be done once. If the cds are ever lost or damaged. The manufacture would have to be called for recovery disc replacements.
  4. Super Moderator Аватара на FearMe
    Jan 2001
  5. Super Moderator
    Dec 2000
    Sofia
    Да не подтискам хората, че знам как да питам гуугъл
    Aug 2005
    Philippines
    Това
    System Recovery го няма
    Nov 2009
    Попово
    Виж пак във всички програми,трябва да имаш подменю ПОДДРЪЖКА,там има рекавъри,поне при мен е така.
    Aug 2005
    Philippines
    Windows e на италиански и System Recovery е ----> ripristino di sistema
    Пуснахме го и тръгна но след 85% някъде екрана става черен и така стои
  10. Moderator Аватара на justify
    Jun 2009
    Би трябвало да има vaio recovery center.Аз винаги оттам го правя и не съм имал проблеми.И вие какво направихте след като стои на 85%?
    Aug 2005
    Philippines
    Стои дълго време с черен екран и го изключиха бутона за пускане
    - - - Обновено - - -
    Готово успяхме да оправим проблема. Всичко мина ОК.
    Благодаря на отзовалите се
  12. Senior Member Аватара на ru-boy
    Jan 2000
    Забелязал съм, че Sony правят всичко сложно без никаква причина. Например, ако решиш да влезнеш в bios-а и си изпочупиш пръстите от почукване на Del, рестарт F-хх плюс комбинация от клавиши изведнъж поглеждаш бутона Аsist. Да имаш пряк бутон за достъп до bios-а над клавиатурата е тъпо. Обикновено след настройката на bios-a работа с него нямаш с месеци.
  1. не мога да изкарам 5.1 звук - лаптоп+ресивър
    От AccurseD във форум Аудиотехника
    Последно: 12-01-14, 09:31
  2. Инсталация на XP на лаптоп с инсталирана VISTA
    От stenly във форум Мобилни устройства
    Отговори: 19
    Последно: 16-07-10, 10:05
  3. Отговори: 6
    Последно: 19-08-09, 10:16
  4. Отговори: 6
    Последно: 02-11-06, 13:12
  5. Проблем с инсталация на лаптоп!
    От bucho във форум Общ - софтуер
    Последно: 10-04-05, 19:18
