Zdraveite molq da mi obqsnite kakvo zna4i ben4mark??? Blagodarq vi predvaritelno.... P.S. Ama da mi obqsnite podrobno i kato xorata nali...[:D]
<blockquote id="quote"><font size="1" id="quote"><b id="quote">quote:</b id="quote"></font id="quote"><table border="0" id="quote"><tr id="quote"><td class="quote" id="quote"><font size="1" id="quote">Zdraveite molq da mi obqsnite kakvo zna4i ben4mark??? Blagodarq vi predvaritelno.... P.S. Ama da mi obqsnite podrobno i kato xorata nali...[:D]
<div align="right">Originally posted by deveca*-*13/03/2004*:* 23:12:29</div id="right">
Чак пък "подробно"... Ама поне "като хората", а?
С две думи - benchmark е "еталонен тест", тоест, сравнение на даден продукт (хардуерен или софтуерен) спрямо определен "стандартен" ("еталонен", "типов") продукт.
//edit
Пиши на кирилица, pls.
Ne moga da pi6a na bg izvinqvam se za koeto ama da ti kaja 4estno ni6to ne razbrax ot tova koeto mi obqsni... Moje li na malko po oprosten ezik??? Vse pak ne sam se specializiral do tolkova vav pc-tata... Blagodarq ti... Sigyren sam 4e mnogo xora 6te iskat da znaqt za tova...
Ами на по-опростен език няма как да стане, защото ти трябва все пак някаква подготовка, за да го разбереш. Или поне аз така си мисля...
Ето дефиницията от FOLDOC (Free On-line Dictionary of Computing): <blockquote id="quote"><font size="1" id="quote"><b id="quote">quote:</b id="quote"></font id="quote"><table border="0" id="quote"><tr id="quote"><td class="quote" id="quote"><font size="1" id="quote">A standard program or set of programs which can be run on different computers to give an inaccurate measure of their performance.
"In the computer industry, there are three kinds of lies: lies, damn lies, and benchmarks."
A benchmark may attempt to indicate the overall power of a system by including a "typical" mixture of programs or it may attempt to measure more specific aspects of performance, like graphics, I/O or computation (integer or floating-point). Others measure specific tasks like rendering polygons, reading and writing files or performing operations on matrices. The most useful kind of benchmark is one which is tailored to a user's own typical tasks. While no one benchmark can fully characterise overall system performance, the results of a variety of realistic benchmarks can give valuable insight into expected real performance.
Benchmarks should be carefully interpreted, you should know exactly which benchmark was run (name, version); exactly what configuration was it run on (CPU, memory, compiler options, single user/multi-user, peripherals, network); how does the benchmark relate to your workload?</td id="quote"></tr id="quote"></table id="quote"></blockquote id="quote"><font size="2" id="quote"></font id="quote">
Ето и свободен превод от Raid[]
Стандартна програма (или набор от програми), които могат да бъдат изпълнявани на различни компютри, за да дадат приблизителна представа за тяхната (на компютрите) производителност.
"В компютърната индустрия съществуват три типа лъжи: лъжи, долни лъжи и бенчмаркове"
Един бенчмарк може да прави опит за оценка на общата "мощност" на дадена система, симулирайки изпълнението на "типичен" набор от програми, или може да прави опит за измерване на по-специфични аспекти на производителността - напр. графични обработки, входно-изходни операции, изчислителни операции. Друг тип бенчмаркове измерват специфични обработки, като рендъриране на полигони (ама ако питаш това какво е няма да ти отговарям сега), четене и запис на файлове или изпълнение на операции с матрици. Най-полезен би бил бенчмарк, който е съобразен с типичните дейности на конкретния потребител. Въпреки, че няма бенчмарк, който изчерпателно да характеризира общата производителност на системата, резултатите от реалистични бенчмаркове може да даде ценна представа за очакваната реална производителност.
Бенчмарковете би трябвало да бъдат интерпретирани внимателно, потребителят би трябвало да знае точно кой бенчмарк е бил използван (наименование, версия); на каква точно конфигурация е бил изпълнен (процесор, памет, параметри на компилатора (и това няма да ти го обяснявам), еднопотребителска/многопотребителска среда, периферни устройства, мрежа).
Пример: Тук из форума има доста хора, които са си публикували в сигнатурите резултатите от един популярен 3dmark - benchmark, който дава интегрална оценка на производителността на графичната подсистема на компютъра.
benchmark = тест, който ти показва скоростта или големината или каквото и да било друго нещо по универсален начин, така че резултатите да са сравними винаги, независимо дали си в бг или usa, и независимо дали си с intel или amd процесор
Бенчмаркинг като понятие представлява сравняване с опита на най - добрите на пазара в бранша; ако не се лъжа като такова понятието изхожда от маркетинга; в софтуера се касае за тестове на производителността на отделните компоненти и системата като цяло; след това получените резултати се точкуват по определени показатели с някакъв коефициент, който коефициент се сравнява с аналогичен на доказани компютърни системи - примерно най - новата конфигурация на Компак.
Опитай, побъзикай се по тея програмки, които си намерил, не е сложно, нито страшно, едва ли си набарал тест, който е опасен за системата ти, а може и да ти стане интересно[:D]
Успех.
Благодаря Ви за изчерпателната информация.... Ето това се казва отговор... Благодаря Ви....
