Страница 2 от 2 ПърваПърва 12
Резултати от 16 до 24 от общо 24
GEFORCE 4 MX ChTech A-G488 проблем... HELP!!!
    Jan 2003
    #16
    <font size="5">Rivatuner</font id="size5"> - последната версия
    Low level overclock
    Core clock: 275
    Memory clock: <font color="red">266</font id="red"> [:O] - тряваше да е 512
    Dec 2003
    #17
    A-G488 сигурен ли си че това е модела на картата , щото има и G488.
    Напиши точно какви данни ма по платката.
    А модела без вентилатор може и MX440SE да е!
  4. Foxman
    Guest
    #18
    V riva tuner ima info na kraq kadeto ti e o/c otvorigo i shte vidish tam dava i realnata 4estota i ydvoenata as imax AsusV8170-mx440 i na 3dmark praveshe 6700 to4ki,za igri stava no ako ne si pretenciozen za grafikata
    Jan 2003
    #19
    <blockquote id="quote"><font size="1" id="quote"><b id="quote">quote:</b id="quote"></font id="quote"><table border="0" id="quote"><tr id="quote"><td class="quote" id="quote"><font size="1" id="quote">V riva tuner ima info na kraq kadeto ti e o/c otvorigo i shte vidish tam dava i realnata 4estota i ydvoenata as imax AsusV8170-mx440 i na 3dmark praveshe 6700 to4ki,za igri stava no ako ne si pretenciozen za grafikata
    <div align="right">Originally posted by Foxman*-*16/01/2004*:* 18:12:00</div id="right">
    Модела на картата е:
    A-G488-C64DN-D50S
    Това е инфото от Riva Tuner
    $ffffffffff ---------------------------------------------------
    $ffffffffff Northbridge information
    $0400000000 Description : VIA KT400
    $0400000001 Vendor ID : 1106 (VIA)
    $0400000002 Device ID : 3189
    $0400000003 AGP bus : revision 3.0
    $0400000004 AGP status : enabled
    $0400000005 AGP rate : 4x 8x supported, 8x selected
    $0400000006 AGP SBA : supported, enabled
    $0400000007 AGP FW : supported, enabled
    $ffffffffff Display adapter information
    $0000000000 Description : NVIDIA GeForce4 MX 440 with AGP8X
    $0000000001 Vendor ID : 10de (NVIDIA)
    $0000000002 Device ID : 0181
    $0000000003 Location : bus 1, device 0, function 0
    $0000000004 Bus type : AGP revision 3.0
    $0000000005 AGP status : enabled
    $0000000006 AGP rate : 4x 8x supported, 8x selected
    $0000000007 AGP SBA : supported, enabled
    $0000000008 AGP FW : supported, enabled
    $0000000009 Base address 0 : e0000000 (memory range)
    $000000000a Base address 1 : d8000000 (memory range)
    $000000000b Base address 2 : none
    $000000000c Base address 3 : none
    $000000000d Base address 4 : none
    $000000000e Base address 5 : none
    $ffffffffff NVIDIA specific display adapter information
    $0100000000 Graphics core : NV18 revision A2
    $0100000001 Hardwired ID : 0181
    $0100000002 Memory bus : 128-bit
    $0100000003 Memory type : DDR (RAM configuration 08)
    $0100000004 Memory amount : 65536KB
    $0100000005 Core clock : 274.500MHz
    $0100000006 Memory clock : 132.750MHz (265.500MHz effective)
    $0100000007 Reference clock : 27.000MHz
    $0100000008 Maximum Fvco : 900.000MHz
    $0100000009 Core PLL Fvco : 549.000MHz
    $010000000a Memory PLL Fvco : 531.000MHz
  6. Foxman
    Guest
    #20
    Mi zna4i e tolkova 265.500,
    poglednax kotiqta na starata mi karta i tq e 400mhz ili 2x200
    i si spomnqm 4e beshe vqrno tova koeto go pisheshe,kakvo ti
    pishe na kotiqta vidqli moge da si e taka
    pak kato gledam v saita te nqmat karta s takava 4estota ti sigoren li si za kartata 4e e ot ChTech.
  7. Foxman
    Guest
    #21
    ti ot kade si?
    Dec 2000
    #22
    Моята карта е Chainteh GF4 440MX A-G440, AGPx4
    Сложих Riva Tuner, новогодишната версия.
    Веднага след инсталирането ми показа 270/275, след рестарт
    270/400 (колкото и трябва да бъде за горепосочената карта)
    Ето и няколко резултата на 3D MARK 2001 SE, като съм включил
    и резултат с понижена честота (колкото е твоята)
    cpu AMD 1700+@2400+ (12x166 2.0 GHz)
    Windows ME, detonator 43.45
    GF4 440MX
    275/266 - 5031
    270/400 - 6291
    300/450 - 6711
    333/500 - 7103
    Jan 2003
    #23
    Абсолютно, картата си е ChTech A-G488 - от новите
    На кутията пише:
    Core Clock 275MHz
    Memory Clock 512MHz
    Възможно ли е проблема да е в дънната платка?
  11. Foxman
    Guest
    #24
    Свали картата и я пробваи на друго РС ако пак
    дава сащото не ти остава друго освен да отидеш там от кадето си я взел и да кажеш за проблема.
  1. GeForce 8600GT 256MB ili GeForce 7900GS 512MB ili GeForce 7950Gt 256MB
    От Minava6t във форум Аудио и Видеокарти
    Последно: 16-05-07, 12:16
  2. ChTech FX5200 256MB DDR ?
    От WarLord във форум Аудио и Видеокарти
    Последно: 20-11-03, 17:24
  3. MSI vs ASUS vs ChTech ???
    От Vova във форум Аудио и Видеокарти
    Последно: 06-07-03, 12:52
  4. GF3 TI200 64MB TV-out ChTech
    От toofy във форум Аудио и Видеокарти
    Отговори: 12
    Последно: 30-11-02, 09:20
  5. ChTech GF3 Ti, 64MB DDR
    От lilos във форум Аудио и Видеокарти
    Отговори: 38
    Последно: 27-06-02, 23:31
