Windows XP ServicePack1 Build 1063... ЧЕТЕТЕ ВАЖНО
    Jan 2002
    Внимавайте с SP1!
    Инфото е по-долу! но не го инсталирайте докато го проверя...
    В противен случай ако сте с Corparate, ще се активирате набързо...
    §§§§§§ [cOMMENTS] §§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§
    § Yay! Its Windows XP Service Pack 1 §
    § Works on both Professional and Home Edition §
    § THE DEVILS0WN CD KEY AND/OR THIS KEY: §
    § FCKGW-RHQQ2-YXRKT-8TG6W-2B7Q8 WILL NOT WORK! READ BELOW §
    § ON HOW TO CHANGE YOUR CD KEY! §
    § See http://www.microsoft.com for more details! §
    § Thanks to #betas on irc.betas-online.com for the §
    § original file... §
    § 1 more thing. PRINT this nfo out. You'll need it! §
    §§§§§§ [iNSTALL nOTES] §§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§§
    § Read READMESP.HTM for more info... §
    § Run update.exe from the Update dir to INSTALL! §
    § Do NOT run deactivate.reg unless I told you to do so. §
    § DO THIS ONLY IF U ARE USING DEVILS0WN WIN XP PRO!!!!! §
    § DO THIS IF U ARE USING FCKGW-RHQQ2-YXRKT-8TG6W-2B7Q8 §
    § DO NOT DO THIS IF U ARE NOT USING WINDOWS XP PRO!! §
    § Er, its a bit hard... But... Oh well... Here goes! §
    § 0. Run a system resore to create a new checkpoint in §
    § case you need it. §
    § 1. Run deactivate.reg to deactivate the current §
    § activation... §
    § 2. Choose run from start menu and type in this command: §
    § %systemroot%\system32\oobe\msoobe.exe /a to get the §
    § activation screen and go to the second option which is §
    § activate by phone. §
    § 3. In the new screen choose the option to change product §
    § key, and type in the new product key (your Corporate one §
    § only). K2KB2-BDBGV-KP686-D8T7X-HDMQ8 §
    § 3a. If it brings you back to the prior screen after §
    § entering the new key click remind me later and then §
    § reboot. §
    § 4. Close that window, reboot your system and enter the §
    § command in step 2 for the second time to verify your §
    § activation , you should see "windows is already §
    § activated". §
    § 4a. Now install SP1 §
    § 5. If you have done this wrong or without a valid key §
    § you will not be able to boot. hit F8 and select last §
    § known good configuration §
    § Thanks to whoever you are for the key and BigFoot for §
    § the tutorial and hot_wired13 for the regfile... §
    Jan 2002
    Инсталацията мина безупречно по горната схема...
    ето го REG file-a:
    Windows Registry Editor Version 5.00
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\WPAEvents]
    "OOBETimer"=hex:ca,00,00,00,00,00,00,00,00,00,00,00
    Mar 2002
    Аз вчера си го инсталнах по описания начин и си тръгна.
    Нали имаше някаква тема преди как да се смени номера-това е явно начина.
    Mar 2002
    A има ли въобще смисъл да се качва SP1?!?
    <-- AMD Inside -->
    EPoX 8K3A, AXP 1920MHz 10x192MHz + Watercooling, 128MB DDR333 KingMAX333, ATi RADEON8500 128MB DVI 300@255, 40GB Seagate BIV + 40GB Maxtor D540X, ASUS 16x DVD, Enlight EN-7237 Case + 400W Enlight PSU, 17" ReliSYS FLAT
    Mar 2002
    Ми питай microsoft
  7. kod
    kod е офлайн
    Administrator Аватара на kod
    Jul 2000
    Ако това, което се разпространява като SP1 има достатъчна прилика с това, което ще бъде официалния SP1 няма начин да няма смисъл...
    Егати изречението спретнах
    Mar 2002
    Ми питай microsoft
    Щото се излъгах да кача Hot Fixes и ми скапа Media Player-a за назидание......
    <-- AMD Inside -->
  10. Senior Member Аватара на Kayso
    Apr 2002
    <BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> Щото се излъгах да кача Hot Fixes и ми скапа Media Player-a за назидание......<hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote>
    i na tebe li <img src=icon_smile_big.gif border=0 align=middle>
  11. Moderator
    Nov 2001
    E това е Service Pack. Оправя някои грешки ама и добавя нови. Това го меже само MS.
    http://julmin.hit.bg
    pod koshcheto mi se poiavi edin nadpis
    kak da go mahna
    pishe che windows-a mi e za testvane..........
  13. DJ
    DJ е офлайн
    Member
    Jun 2001
    I kakvo pishe po tochno...
    Znaq pove4e otkolkoto si misli6
    Jan 2002
    vzel si versija 2600 beta..zatova ti go pishe... ->>[1068_xpsp1.exe]
    Ako beshe s 1050 njamashe da go pishe... (ima go v warezbg)
    no veche moje bi e kusno... (shte chakash release)
    Pokazva:
    Windows XP Professional
    For testing purposes only.Build 2600.xpsp1.020628-1905()
    Edited by - DeathKnight на 09/07/2002 16:50:29
    koe mi e beta :
    windowsa ili SP1 ?
    Dec 2000
    Za SP sys sigurnost, a i nai-verojatno XP-to systo
    mislia si che ne e beta winXP-to
    kazete mi kak da razbera
  1. Windows 7 build 7600
    От periel във форум Windows
    Отговори: 11
    Последно: 07-08-09, 20:01
  2. Отговори: 8
    Последно: 02-09-07, 12:49
  3. Какви книги четете ?
    От obshtinska_mishka във форум Анкети
    Отговори: 38
    Последно: 14-02-07, 00:15
  4. Отговори: 21
    Последно: 01-12-06, 16:20
  5. Четете ли компютърни списания?
    От nniki във форум Анкети
    Отговори: 17
    Последно: 23-02-04, 18:10
