VPN Server - Windows
  1. lil
    lil е офлайн
    Junior Member
    Nov 2003
    Привет на всички!
    Имам пуснат VPN Server на Windows Vista и работи ОК. Проблема е, че искам повече от един user да се свързва към VPN-а едновремено но не не намирам от къде става, а и google не ми помогна. Ако някои знае допълнителен VPN Server които да подържа повече от 1 user ще съм му благодарен ако сподели опит!
    Apr 2002
    Re: VPN Server - Windows
    Choose:
    Hi all,
    I've put together a list of VPN Servers and VPN clients, and wonder if you
    could help me identify the ones I missed?
    VPN Servers include:
    Juniper Networks Netscreen Platforms
    Juniper Networks Secure Access Platform
    Securepoint Security Suite 2006nx
    Windows 2000, Windows XP, ISA Server, and Windows Server 2003
    Poptop - The PPTP Server for Linux
    Openswan
    OpenVPN - An Open Source SSL VPN
    StrongSwan - IPsec for Linux
    Aventail Smart SSL VPN
    NetMAX VPN Server Suite 5
    Kerio WinRoute Firewall
    Cisco IOS Easy VPN
    Secure VPN Server Suite
    Wolverine Firewall and VPN Server
    OvisGate SSL VPN
    LinkSys 10/100 4-port VPN Router
    InJoy Firewall
    Mac OS X Server
    Nortel VPN Gateway and Routers
    iPig Server Express and Server Pro
    SonicWALL Firewall/VPN Appliances and SSL-VPN Appliances
    Novell BorderManager
    Fortinet FortiGate Systems
    RedHat8 PptpServer
    intY ExoServer
    Firebox SSL VPN and X Series
    Astaro All-in-One Security: VPN Gateway
    Netopia 4500 and 4600 Series Routers
    SnapGear Appliances
    ProSafe VPN Firewall
    TrendNet Cable/DSL VPN Firewall Router
    ArubaOS VPN Server
    Borderware Firewall Server
    Safe@Office Appliances
    Check Point VPN-1 Pro and Edge Appliances
    AEP Net and NSP Appliances
    Symantec Security Gateway Appliance
    Nokia Firewall/VPN Appliance
    Enterasys XSR Security Router
    Avaya SG Security Gateway
    Q-Series Routers
    SafeEnterprise SSL iGate
    PowerWallz ProShield v1000 and x200
    Trustway VPN
    F5 FirePass SSL VPN
    g::Scarlet
    Prodigy Range
    Hot Brick Firewall SOHO and Firewall VPN
    iForce VPN/Firewall
    Innominate mGuard products
    VPN Firewall Brick
    LiSS Security Gateway products
    RouteFinder Appliances
    NETASQ Appliances
    NetMIND
    NetSentron 200
    AstroFlowGuard
    NetStealth Firewall
    Network Box
    iQ Series
    Resilience Firewalls/VPNs
    ServGate EdgeForce
    Stratum 9100
    GTA GB series Firewall/VPN Appliances
    GateProtect Firewall
    Gatecraft Shield
    Eland Systems Sys-2 Series Appliance
    Array Networks SSL VPN Access Gateway
    ANXTunnelz
    BorderGuard 6000
    AF2100 and AF7500
    NCP Secure Enterprise Server
    Nucleonet Security Appliances
    PortWise 4.5
    Privador VPN System
    Sequi VPN Gateway Series
    Shiva VPN Gateways
    IP-Granite
    VPN Solution for Mac
    ZyWall Firewall/VPN Gateway
    Celestix MSA Security Appliance
    VPN Clients include:
    Windows 2000, XP, and Server 2003
    PPTP Client
    Kerio VPN Client
    Cisco Easy VPN Remote
    Mergic VPN for Palm OS
    LinkSys USB VPN & Firewall Adapter
    InJoy Firewall
    Nortel VPN Client
    iPIG - iOpus Private Internet Gateway
    FortiClient
    Watchguard Mobile User VPN
    Astaro Secure Client for VPN Networks
    SoftRemote VPN Client
    NetGear ProSafe VPN Client
    DigiTunnel
    Aruba Mobile Edge Client
    Borderware Sentinel VPN Client
    Checkpoint VPN-1 SecureClient
    Symantec Enterprise Firewall
    anthaVPN
    Trustway VPN Client
    Hot Brick VPN Client
    Lucent IPSec Client
    LiSS VPN Client
    iQSecure Client
    GTA Mobile VPN Client
    BorderGuard Client
    AF Secure Client
    NCP Secure Client
    Privador SSA
    IP-Granite Workstation Software
    VPN Tracker
    SonicWALL Global VPN Client
    TheGreenBow IPSec VPN Client
    D-Link VPN Client Software
    vpnc - client for Cisco EasyVPN
    Netscreen-Remote
    SSH Tectia Connector and Client
    SafeNet VPN Client Software
    StoneGate VPN Client
    Mac OS X VPN Client
    You can see the lists in context at
    http://www.securitywizardry.com/vpnservers.htm and
    http://www.securitywizardry.com/vpnclients.htm
    Thanks!
    -Michele
    NEW! LEARNING CENTER (sponsor)
    Special educational offers, white papers, webcasts, podcasts
    WEBCAST: Offshore software development: Making it a success with agile practices. Register Now:
    WEBCAST: IBM WebSphere Portal V6.1 Web 2.0 Capabilities. Register Now:
    WHITE PAPER: Best practices for software analysis (Best Practices)
    DOWNLOAD NEW E-KIT: Download the IBM pureXML Developers Kit:
    DOWNLOAD: Rational Trial Software – Rational Team Concert Free Information:
    TUTORIAL: Debug iPhone Web applications with Eclipse
    <Prev in Thread]
  4. Moderator
    Mar 2005
    Цитат Първоначално публикувано от lil
    Привет на всички!
    Имам пуснат VPN Server на Windows Vista и работи ОК. ...
    А какво имаш предвид под "Имам пуснат VPN Server на Windows Vista" ?
    Някакъв допълнителен софтуер за VPN-сървър, вграденото Incomming connection, или нещо друго ?
  5. lil
    lil е офлайн
    Junior Member
    Nov 2003
    MitkoS - за вграденото Incomming connection става на въпрос
    dash - това което предлагаш определено е много интересно и ще изпробвам някой неща
  6. Moderator
    Mar 2005
    Не знам дали това което ще напиша ще ти помогне или само ще те обърка.
    Не съм се занимавал с Incomming connections под Vista - пускал съм един-два пъти за да видя как работи, но никога не съм ползвал в реална експлоатация. За сметка на това пък доста съм работил с вградения VPN-сървър в RRAS под Win2000/2003/2008
    Първоначално възнамерявах да ти напиша да се ориентираш към допълнителен софтуер за VPN-сървър под Vista (нещо от списъка на Dash по-горе), тъй като си мислех (не знам защо), че броя на връзките при Incoming Connections при Vista е ограничен на една, както е и с терминалния сървър. Тъкмо да го напиша и се усъмних, че това всъщност може и да не е вярно. Порових се доста по сайтовете на Майкрософт, но никъде не видях явно да е написано за такова ограничение (може и да не съм търсил както трябва). Порових се и в registry при мен (Vista Bussiness) за да видя дали няма някакъв ключ който да определя броя на връзките. И попаднах на следното:
    H_C_L_M\SYSTEM\CurrentControlSet\Services\RasMan\Parameters
    и там има следния ключ
    LimitSimultaneousIncomingCalls със стойност 3
    Което ме навежда на мисълта, че по премълчаване, броя на връзките е 3. Все пак, това е само предположение, но пък си заслужава да се провери добре.
    Така че, бих ти предложил следното:
    - да дефинираш три отделни потребителя,
    - да разрешиш права и на тримата да правят Incomming connections
    - да провериш първо за всеки самостоятелно дали може коректно да се свързва
    - накрая да пробваш и с тримата едновременно
    ПП. С каква версия на Vista работиш ?
    Home, Business, Ultimate ... ?
  7. lil
    lil е офлайн
    Junior Member
    Nov 2003
    MitkoS - Вистата е Ultimate, и при мен LimitSimultaneousIncomingCalls е със стойност 3 и го промених на 10 но пак показва Error 937: Because another connection of your type is in use.
    Между другуто опитах да пусна OpenVPN но явно съм много тъп защото там ми изкарва: Cannot load certificate file server.crt: error:0906D06C
    изпълних:
    init-config
    vars
    clean-all
    build-ca
    build-key-server server
    build-key client
    build-dh
    Feb 2007
    w2k/xp/vista - 1 vpn connection at a time (както се казва "by design")
    за повече има "сървър" ...
    бтв за openvpn най-вероятно нещо си се "оплескал" с паролите, т.е. пробвай пак, трябва да стане ...
    Apr 2002
    изпълних:
    init-config
    vars
    clean-all
    build-ca
    build-key client
    build-dh
    Трябва да си регенерираш ключовете на сертификатите by Default, прочети повече как се генерират нови ключове/сертификати
  11. Moderator
    Mar 2005
    Цитат Първоначално публикувано от recycled_bin
    Това къде го прочете ?
    Не го оспорвам, ама ме яд, че толкова го търсих и не го намерих.
  12. lil
    lil е офлайн
    Junior Member
    Nov 2003
    OpenVPN-a тръгна така, че проблема ми се реши и на практика сега имам VPN връзка
    Благодаря на всички които се включиха в темата!
    Feb 2007
    Цитат Първоначално публикувано от MitkoS
    едва ли ще си спомня точно откъде, но предполагам те интересува "официален" източник ... та намерих следният:
    http://www.microsoft.com/technet/net...pn/vpnfaq.mspx
    Q. For which operating systems and with which protocols does Microsoft provide remote access VPN servers?
    A. Microsoft supports a fully-featured PPTP-based remote access server in Windows NT Server 4.0, Windows 2000 Server, and Windows Server 2003. Microsoft supports a fully-featured L2TP/IPSec-based remote access server in Windows 2000 Server and Windows Server 2003.
    Microsoft also supports a single-connection PPTP and L2TP/IPsec-based remote access server in Windows 2000 Professional, Windows 2000 Server (standalone), Windows XP Professional, and Windows Vista (all versions) through the Incoming Connections feature of the Network Connections folder. For information about Incoming Connections for Windows XP, see Incoming connections. For information about Incoming Connections for Windows Vista, see Set up an incoming VPN or dial-up connection.
    Microsoft supports a Secure Socket Tunneling Protocol (SSTP) remote access server in Windows Server 2008. For more information about SSTP, see The Secure Socket Tunneling Protocol and the Routing and Remote Access Blog.
  1. SP1 за Windows 7 и Windows Server 2008 след броени дни
    От kod във форум Новини от SetCombG.com
    Последно: 10-02-11, 18:11
  2. Windows XP Server
    От TORO във форум Windows
    Последно: 22-09-05, 00:17
  3. Windows Server 2003 YES or NO
    От Ebus във форум Windows
    Отговори: 29
    Последно: 16-03-04, 13:44
  4. ftp server za windows.
    От xas във форум Windows
    Последно: 01-07-03, 16:54
  5. Server pod Windows
    От wireman във форум Windows
    Последно: 02-01-03, 12:42
