Media Player - Zinwell (всички модели)
ZINWELL ZP-500
[img width=800 height=279]http://www.zintech.com.tw/uploads/product/ZP-500(1).jpg[/img]
ZP-500 is a Networking High Definition multimedia player (up to 1080p) to enjoy the top quality home entertainment. It can playback the Multimedia in the external storage device through USB interface or through Networking. It is easy to connect to the TV and simple to use.
Key Features:
- Movie/Music/Photo multiple media formats playback on TV
- HD (1080p) output
- Photo slide show with background music
- User friendly on screen display and operation
- Easy to use File editing
- Networking supports SAMBA client, UPnP
- HDMI digital Audio/Video output, SPDIF digital Audio output
[img width=558 height=600]http://www.brite-view.com/images/bv5005_specification.png[/img]
Information on Max Bitrate
Mpeg1: Ok / Max Pixel 720x576
Mpeg2: Ok / Max Pixel 1920x1080p,Max bitrate 60m Bytes
H.264: Ok / Max Pixel 1920x1080p,Max bitrate 40m Bytes
RealVideo8/9/10: Ok / Max Pixel 1280x720p,Max bitrate 1m Bytes
Xvid: Ok / Max Pixel 1920x1080p,Max bitrate 50m Bytes
Divx3.x: Ok / Max Pixel 1920x1080p,Max bitrate 50m Bytes
Divx4.x: Ok / Max Pixel 1920x1080p,Max bitrate 50m Bytes
Divx5.x: Ok / Max Pixel 1920x1080p,Max bitrate 50m Bytes
Divx6.x: Ok / Max Pixel 1920x1080p,Max bitrate 50m Bytes
Vc-1/Wmv9: Ok / Max Pixel 1920x1080p,Max bitrate 40m Bytes
WMV: Ok / Max Pixel 1920x1080p,Max bitrate 40m Bytes
Mp3 Layer1: 8-48khz,32Kbps-448kbps
Mp3 Layer2: 8-48khz,32Kbps-384kbps
Mp3 Layer3: 8-48khz,32Kbps-320kbps
Mpeg2.5: 8-48khz,32Kbps-160kbps
Wma: 8-48khz,32Kbps-192kbps
Pcm,Lpcm: 8-96khz,8/16/24 bit
Pcm,Ima-Adpcm: 8-96khz,4 bit
Pcm,Ms-Adpcm: 8-96khz,4 bit
Pcm,A-Law: 8-96khz,8 bit
Pcm,U-Law: 8-96khz,8 bit
Ac3: 32/44.1/48khz
Jpeg/Jpg Photos with resolutions up to 8000x8000
Bmp Photos with resolutions up to 8000x8000
Tiff Photos with resolutions up to 8000x8000
Png Photos with resolutions up to 8000x8000
Gif Photos with resolutions up to 8000x8000
Notes
Those media formats not indicated as "Supported Formats" cannot be guaranteed run properly on the player. For example, under "WMV", only "WMV9" is supported but not "WMV7/8".
Media formats that can be supported but with limitation:
-- M-JPEG:support up to 640x480x30p
-- FLV(h.263): 352x288(maybe higher; no testing material to confirm)
-- RMVB:support up to 720p
-- The 7.1-channel surround sound can be decoded, but only downmixed and output to 2 channels.
Media files protected by DRM are not supported with current software version.
Only media files located on the USB storage device attached to the player can be added to the playlist. Users cannot add media files located on the remote PC or through UPnP support.
Firmwares:
Original
All firms
Cloning
Astone
Забелязах че в Метро са пуснали някакъв нов плеър Zinwell ZP-500, който поддържа май всичко необходимо.
И то на доста добра цена - 202 лв с ДДС то.
Ако някой има информация или отзиви за това нека да сподели! :)
Re:Имате ли информация за плеърите Zinwell ZP-500 ?
Как да ти кажа , като цена WD TV , но като функции много по-добро.Made in Taiwan .
http://img3.imageshack.us/img3/9678/scanz.jpg
Тъкмо щях да пускам и аз тема за тоя плеър.
Ето брошурката от Метро.
Ако и подръжката на фирмуера е добра може да стане пазарен хит.Между другото това е най-евтиния мултимедия плеър от цялата серия на Zinwell.ZP -530 е с най-много възможности.
Ходих до Метро да го видя.Симпатична малка черна пластмасова кутия с неголямо дистанционно управление.Излежда добре на външен вид с не лошо направено меню , което беше на руски в случая.
От USB ли чете? Няма хард май. Лан вход ли има?
Вчера си го купих от Метро и съм много доволен от факта,че не можах да намеря видео файл в компа си който да му се опъне ...:)
nikolai64, ако имаш възможност, дай малко повече информация и някоя снимка - колко са големи субтитрите, на колко реда, пренася ли автоматично дългите редове.
Благодаря предварително!
Като бях в Метро и видях , че субтитрите се регулират по височина и имаше избор на цвят и излизаха на 5-6 реда.
Все пак не разбрах от външен хард ли чете или има място в плеъра.
Първоначално публикувано от KumaLisko
няма място в плеъра,без проблем чете от флаш и външен хард- 2,5" и 3.5" размери
Съдейки по снимката май не поддържа ЛАН :(( Вярно ли е ? :081:
Съдейски по снимката на гърба на плеъра, а и от линковете на elcos, ясно се вижда че Лан няма, има Ethernet RJ45.
Защо не гледате преди да пълните темата с излишни въпроси? И на двете места се вижда че има лан, написано е и в спецификациите.
Първоначално публикувано от Eddie
Покорно благодаря за информацията! :god
:offtopic: Бърррррррррр, тръпки ме побиха преди да се зарадвам, че поддържа ЛАН! :016:
Има 5 размера на субовете и 6 цвята. Плейва всичко (с около 2 секундно зависване при пускане на видео с висока резолюция) ,но не насича и върви гладко . Много удобно меню и навигация.
Този плеър много прилича на един продукт на компанията Zinnet - Brite-view Cinema Tube BV-5005 HD .Няма как да бъде иначе понеже Zinnet е дъщерна компания на Zinwell - Taiwan.Двата продукта се различават по това , че usb входовете на Zinwell ZP-500 са отпред , а на другия отзад .
http://www.brite-view.com/cinematube.php
Има достатъчно данни за продукта за разлика от сайта на Zinwell .
