Znach iskam da si napravq DivX na VCD. Vaprosami e zashto na nqkoi filmi kato gi zaredq v“VirtualDub” mi zliza syobshtenieto [!]”The requested audio compression is not compatible with the input format. Check that the sampling rate and channel count of the input match those of the requested format” [
!]I kato go convertira v VCD go pravi bez zvuk.
Kak da opravq tazi gadost. Syshtoto mi izliza I ako trygna da sapisvam samo zvuka v WAV format. A na drugi filmi kato zapisvam zvuka v WAV ima nqkakvo prashtene samiqt zvuk se sakapva.
