Резултати от 1 до 9 от общо 9
ECS K7S5A overclocking BIOS-NEW
    Jul 2001
    Izlqzal e nov BIOS za ECS K7S5A (neoficialen)kojto dobavq malko overclock vazmojnosti.
    BIOSa e BETA i e na PCCHIPS(dokolkoto razbrah te imali analog na ECS K7S5A),BIOSa e modificiran kato samo e dobaveno novo logo, i ima poddrajka na FASTWRITES
    eto podrobnosti:
    CheepoBios 1.02 Beta for K7S5A
    Based on PcChips 020626
    chb0626.rom non-lan Version
    chb0626l.rom lan version
    chb0626f.rom lan version with fastwrites enabled (disable lan in bios Setup to use it on a non-lan board)
    Release notes:
    - Adjust timing for stability and compatibility
    - FSB modes reprogrammed:
    "100/100 MHz" changed from 99.6 to 100.9 MHz
    "133/133 MHz" changed from 132.77 to 133.9 MHz
    No more underclocking by default!
    - Several FSB modes added. New list of available modes:
    100/100 MHz
    100/133 MHz
    133/133 MHz -> Default modes
    66/66 MHz (H/W Trap)
    112/112 MHz
    124/124 MHz
    138/138 MHz (reprogrammed from 137.3 to 138.0)
    150/150 MHz
    166/166 MHz -> Already present in the "OC" bios
    110/110 MHz
    133/100 MHz
    143/143 MHz
    147/147 MHz
    133/166 MHz
    160/120 MHz
    200/200 MHz
    Please note that the "166 MHz no-boot issue" hasn't been dealt with
    in this bios modification. It seems that bios timings need to be adjusted to allow
    booting at such speed. This issue could also affect 160/120 and 200/200
    settings.
    - Extra memory settings:
    - RAS Precharge Time=2T
    - RAS Active Time=4T, 5T
    - Full screen logo can be enabled/disabled via bios menu
    - A few hidden bios options have been enabled with amibcp. Please notice that none of these settings have been fixed or reprogrammed at all.
    - PCI Latency Timer
    - PCI IDE busmaster
    - PCI slot #1 to #4 IRQ priority
    - IO APIC
    The default values for these settings, as well as all other settings, remain the same as in the original bios.
    I wish to thank Jinxter, tw.p, Bench400 and Beheerder: deblokker mij, fellow bios modders
    at www.ocworkbench.com/ecs for their useful ideas, discussion and testing
    Cheepoman 07 July 2002
    eto i linkovete
    http://www.ocworkbench.com/bios/ecs/k7s5a/Chb0626.zip za versiq BEZ LAN
    http://www.ocworkbench.com/bios/ecs/k7s5a/Chb0626l.zip za versiq s LAN
    http://www.ocworkbench.com/bios/ecs/k7s5a/Chb0626f.zip za versiq s LAN i FASTWRITES poddrajka (izklu4ete LAN v BIOS i moje da go polzvate na versiqta be z LAN
    have no fear lightmaster is here
    Jul 2001
    zabravih naj vajnoto
    AMI Flash utility - http://205.158.63.158/bios/aminf332.exe
    az si go ka4ih o6te ne sam po4nal s overclock testovete no ina4e e stabilen, dobavq dosta opcii za koito teparva 6te tarsq obqsneniq.
    Ne6to koeto vednaga mi se nabi na oko e 4e CPUto mi AMD XP 1700+
    sega e 1800+.
    Pusnah SPEEDFAN i mi pokaza FSB 133.9 MHZ predpolagam 4e zatova go razpoznava kato XP 1800+ (to maj go pi6e6e v READMEto !!!)
    Sep 2001
    Колко са PCI/AGP при 124/124?
    А и това 66/66 работи ли?
    BEWARE! INTEL INSIDE!
    Edited by - exabyte на 15/07/2002 20:49:55
    Jul 2001
    kakvo ima6 napredvid ???
    4akam da svalq edni driveri ot inet i togaz 6e probvam da vdigna malko FSB.
    p.s. taq tema maj ne be6e za tazi 4ast ot foruma ama ...
    Sep 2001
    Интересува ме дали PCI при 124/124 е 31 MHz или 40 MHz?
    Jul 2001
    huh az kak da razbera ???
    CPUto mi e 133Mhzovo
    Feb 2002
    ot 2 dni sam s tozi BIOS. Polzvam 110/110 na Duron 650 i edin na 750. za momenta raboti perfektno. Ne sam gi puskal na pove4e 6tot vse pak mi trqbva stabilnost na rabota.
    "Shadows And Dust"
    Jul 2001
    147/147 Mhz tva e pove4e ne moga na 150 vaob6te ne pali
    XP 1700+@2000+
    abe ima edna funkciq APIO suport ili ne6to takova ama ne znam za kakvo e
    RAMa mi ne tragva na CAS2 <img src=icon_smile_sad.gif border=0 align=middle> PQI DDR
    Kolkoto do pritejatelit na duron v foruma OCworkbench vidqh 4e I/O compensation moje da pomogne malko za vdiga nne na po-golqm FSB
    Jan 2002
    Ami bih kazal pove4e e xp 1900 otkolkoto 2000 ama aide..
    imam edna lo6a novina predi malko mi zafna zapisva4kata
    da ti ... i D&G to bahti i mesec nqma6e ot kato q vzeh
    sq samo i sveti lampi4kata i vaob6te ne q zasi4a
    ama az sam si vinoven bahti 6a zimam sony zapisva4ka i to ot promoziq
    sq kato q zanesa 6e vidim kolko 6e si spazqt garanciqta
  1. ECS K7S5A help
    От kvant във форум Процесори и Дънни платки
    Последно: 19-10-05, 09:55
  2. K7S5A
    От PacoRabanne във форум Процесори и Дънни платки
    Отговори: 17
    Последно: 29-11-03, 10:28
  3. Flash на bios за дъно ECS k7s5a v1.0 sys v3.0
    От g_velev във форум Общ - хардуер
    Последно: 12-09-03, 22:01
  4. DDR 333 rabote li na k7s5a
    От haa във форум Общ - хардуер
    Последно: 14-02-03, 22:25
  5. GF2Ti overclocking
    От THE_RAVEN във форум Аудио и Видеокарти
    Отговори: 10
    Последно: 25-06-02, 10:47
