Резултати от 1 до 15 от общо 21
Въпрос за форматирането на хард диска?
    Jul 2003
    ZDRAVEITE MNOGO ME INTERESYVA PODROBNA INFORMACIQ ZA FORMATIRANETO 4ETA RAZLI4NI MNENIQ NQKOI KAZVAT 4E FORMAT C: NE ENIKAKVO FORMATIRANE DRYGI KAZVAT TREBVA PALEN FORMAT KAKVO E TOVA? TRETI KAZVAT TREBVA FORMAT C:/S/U/Q
    SLY6AL SAM ZA FORMAT C:/S/V KAKVI SA TEQ BYKVI I ZA KAKVO SA?
    A PAK D: TREBVALO DA SE FORMATIRA SAS FORMAT D:/X
    KAKVO E PAK TOVA X?
    MNOGO SAM OBARKAN PLS HELP!!
    <font color="orange">Malone Edit: heat_ използвай кирилица и не пиши с главни букви, моля! Прочети правилата на форума</font id="orange"> <font color="teal">тук</font id="teal">
    Apr 2003
    FormatFormats the disk in the specified volume to accept Windows files.
    Syntax
    format volume [/fs:file-system] [/v:label] [/q] [/a:UnitSize] [/c] [/x]
    format volume [/v:label] [/q] [/f:size]
    format volume [/v:label] [/q] [/t:tracks /n:sectors]
    format volume [/q]
    Parameters
    volume
    Specifies the mount point, volume name, or drive letter of the drive you want to format. If you do not specify any of the following command-line options, format uses the volume type to determine the default format for the disk.
    /fs:file-system
    Specifies the file system to use FAT, FAT32, or NTFS. Floppy disks can use only the FAT file system.
    /v:label
    Specifies the volume label. If you omit the /v command-line option or use it without specifying a volume label, format prompts you for the volume label after the formatting is completed. Use the syntax /v: to prevent the prompt for a volume label. If you format more than one disk by using one format command, all of the disks will be given the same volume label. For more information about disk volume labels, click Dir, Label, and Vol in the Related Topics list.
    /a:UnitSize
    Specifies the allocation unit size to use on FAT, FAT32, or NTFS volumes. If you do not specify UnitSize, it is chosen based on volume size. The following table lists valid values for UnitSize. Value Description
    512 Creates 512 bytes per cluster.
    1024 Creates 1024 bytes per cluster.
    2048 Creates 2048 bytes per cluster.
    4096 Creates 4096 bytes per cluster.
    8192 Creates 8192 bytes per cluster.
    16K Creates 16 kilobytes per cluster.
    32K Creates 32 kilobytes per cluster.
    64K Creates 64 kilobytes per cluster.
    /q
    Performs a quick format. Deletes the file table and the root directory of a previously formatted volume but does not perform a sector by sector scan for bad areas. You should use the /q command-line option to format only previously formatted volumes that you know are in good condition.
    /f:size
    Specifies the size of the floppy disk to format. When possible, use this command-line option instead of the /t and /n command-line options. Windows accepts the following value for size:
    1440 or 1440k or 1440kb or 1.44 or 1.44m or 1.44mb
    1.44-MB, double-sided, quadruple-density, 3.5-inch disk
    /t:tracks
    Specifies the number of tracks on the disk. When possible, use the /f command-line option instead of this command-line option. If you use the /t command-line option, you must also use the /n command-line option. These two command-line options provide an alternative method of specifying the size of the disk being formatted. You cannot use the /f command-line option with the /t command-line option.
    /n:sectors
    Specifies the number of sectors per track. When possible, use the /f command-line option instead of this command-line option. If you use the /n command-line option, you must also use the /t command-line option. These two command-line options provide an alternative method of specifying the size of the disk being formatted. You cannot use the /f command-line option with the /n command-line option.
    /c
    NTFS only. Files created on the new volume will be compressed by default.
    /x
    Causes the volume to dismount, if necessary, before it is formatted. Any open handles to the volume will no longer be valid.
    Displays help at the command prompt.
    Remarks
    Using format at the Recovery Console
    The format command, with different parameters, is available from the Recovery Console.
    Administrative privileges
    You must be a member of the Administrators group to format a hard drive.
    Using format
    The format command creates a new root directory and file system for the disk. It can also check for bad areas on the disk, and it can delete all data on the disk. To be able to use a new disk, you must first use this command to format the disk.
    Typing a volume label
    After formatting a floppy disk, format displays the following message:
    Volume label (11 characters, ENTER for none)?
    The volume label can be a maximum of 11 characters (including spaces). If you do not want your disk to have a volume label, just press ENTER. For information about volume labels, click label in the Related Topics list.
    Formatting a hard disk
    When you use the format command to format a hard disk, format displays a message of the following form before attempting to format the hard disk:
    WARNING, ALL DATA ON nonremovable DISK
    DRIVE x: WILL BE LOST!
    Proceed with Format (Y/N)?_
    To format the hard disk, press Y; if you do not want to format the disk, press N. You must have Administrator rights to format a hard disk.
    Unit size
    FAT file systems restrict the number of clusters to no more than 65526. FAT32 file systems restrict the number of clusters to between 65527 and 4177917.
    NTFS compression is not supported for allocation unit sizes above 4096.
    Format messages
    When formatting is complete, format displays messages showing the total disk space, any space marked as defective, and the space available for your files.
    Quick formatting
    You can speed up the formatting process by using the /q command-line option. Use this command-line option only if there are no bad sectors on your hard disk.
    Using format with a reassigned drive or a network drive
    You should not use the format command on a drive prepared by using the subst command. You cannot format disks over a network.
    Format exit codes
    The following table lists each exit code and a brief description of its meaning.
    Exit code Description
    0 The format operation was successful.
    1 Incorrect parameters were supplied.
    4 A fatal error occurred (any error other than 0, 1, or 5).
    5 The user pressed N in response to the prompt "Proceed with Format (Y/N)?" to stop the process.
    You can check these exit codes by using the errorlevel condition with the if batch command.
    Examples
    To format a new floppy disk in drive A using the default size, type:
    format a:
    To perform a quick format operation on a previously formatted disk in drive A, type:
    format a: /q
    To format a floppy disk in drive A and assign it the volume label "DATA," type:
    format a: /v:DATA
    Formatting legend
    Format Meaning
    Italic Information that the user must supply
    Bold Elements that the user must type exactly as shown
    Ellipsis (...) Parameter that can be repeated several times in a command line
    Between brackets ([]) Optional items
    Between braces ({}); choices separated by pipe (|). Example: {even|odd} Set of choices from which the user must choose only one
    Courier font Code or program output
    Related Topics
  4. Senior Member Аватара на ru-boy
    Jan 2000
    Екстракция от други и мои мнения по въпроса:
    Напиши c:>format /? и ще прочетеш за всички тия опции....
    format c: /q - това е бързо форматиране (непълно според твоя речник), изтрива само FAT - таблицата. При нужда е възможно частично и/или напълно възстановяване на информацията.
    format c: /s - форматира диска като копира и системните файлове, за да може да заредиш ОС от него.
    format c: /s /v - същото, но и проверява за "лоши" BAD сектори.
    По въпроса за "пълно" или "непълно" форматиране:
    Това не трябва да те тревожи. Няма някаква качествена разлика от бързото и пълното форматиране. Ако не е възможно бързо "quick" форматиране, то ще ти бъде изведено съобщение, че това не е възможно и ще ти предложи да форматираш стандартно "пълно" форматиране, което отнема малко повече време, но не повече от броени минути. Докато, както казах по-горе бързото форматиране "quick" ( опция /Q) само изтрива таблицата с имената на файловете и става за секунди. В същност правилото е, че ако диска се форматира след манипулации с fdisk се прави пълно форматиране. След еднократно пълно форматиране, можеш да си форматираш с опция /Q (бързо) всеки път при нужда.
    May 2003
    <blockquote id="quote"><font size="1" id="quote"><b id="quote">цитат:</b id="quote"></font id="quote"><table border="0" id="quote"><tr id="quote"><td class="quote" id="quote"><font size="1" id="quote">format c: /s /v - същото, но и проверява за "лоши" BAD сектори.
    <div align="right">оргинално мнение на ru-boy</div id="right">
    странно... аз пък мислех, че /V служи за задаване на Label на диска
    поне така пише като му дам "format /?" а пък /U за какво беше ? ползвам го като легенда, нещо май с mbr-то правеше....?
    Aug 2002
    за проверка на бед секторите се използва опция / c , а за "пълен формаt " има два начина ( според мен, най-елементарните )
    Първия : Ф-диск, послe триеш партишъна , и след това го създаваш отново и после формат ( от това по -пълен здраве му кажи )
    Втория : Format c :/ u
    ПП
    има и трети
    от http://www.qdigrp.com/qdisite/eng/support/Utility.htm програмата "LF.EXE" и я пускаш
    Това е Low level Format- малко са се изхвърлили според мен с името , но си върши работата много добре - тя прави абсолютен пълен формат.
    Там има и много други интересни нещица де []
    BLADE - кефиш ме колко си изчерпателен ( ама да го бе превел , че ме мързи , не само мен а и всички останали ) [:D]
  7. Senior Member Аватара на ru-boy
    Jan 2000
    Извинявам се, обърках опциите в бързината /с е за лоши сектори ...
  9. Senior Member Аватара на Lupus
    Aug 2003
    Има ли начин за форматиране на хард диска, без да се разрушава информацията, а само да се оправи boot и партитишаните? С каква програма става (ако е възможно)? Имам проблем с преинсталирането на Windows 98SE поради повреди там. Ако някой може да помага. Благодаря предварително.
  10. Senior Member Аватара на ru-boy
    Jan 2000
    <blockquote id="quote"><font size="1" id="quote"><b id="quote">цитат:</b id="quote"></font id="quote"><table border="0" id="quote"><tr id="quote"><td class="quote" id="quote"><font size="1" id="quote">Има ли начин за форматиране на хард диска, без да се разрушава информацията, а само да се оправи boot и партитишаните? С каква програма става (ако е възможно)? Имам проблем с преинсталирането на Windows 98SE поради повреди там. Ако някой може да помага. Благодаря предварително.
    <div align="right">оргинално мнение на Lupus</div id="right">
    Не ми стана ясно какво точно питаш, но ще ти е полезно да знаеш следното:
    <font color="orange">fdisk c: /MBR </font id="orange">- възстановява мастер боот-а. Ако имащ lilo с тази команда го премахваш и т.н.
    <font color="orange">sys c:</font id="orange"> - с тази команда възстановяваш и/или правиш (диск "С" в случая) да може да е системен (зареждащ ОС). Примерно, ако ти се е прецакало зареждането на ОС от твърдия диск, чрез една системна дискета и настоящата команда ще го оправиш. (от <font color="yellow">А:\sys c:</font id="yellow"> )
    <font color="orange">SpinRite.exe </font id="orange"> - това е програма за "форматиране" на твърдия диск без да се загубва информация, като има различни свойства. Препоръчвам следния вариант за използване <font color="yellow">SpinRite с: /auto</font id="yellow">
    Не бива да се забравя и за програми от рода на PM (партейшън меджик) и други от рода на NDD (Нортън Диск Доктор) for DOS and for Widows.
    http://www.powerquest.com/partitionmagicpro/
  11. Senior Member Аватара на Lupus
    Aug 2003
    [?][?][?] Багодаря ти Ru-boy за съветите. Възползувах се от тях в пълен обем, но явно "не там е зарито кучето". Всъщност проблема е следния: Операционната ми система е Windows 98SE. Имам от известно време проблеми с нея: спиране на програми и игри, блокиране работата на Explorera и други подобни. Искам да я преинсталирам за да се "самоподреди", но тя не ще. При пускане на Setup минават успешно тестовете и след това "fatal error" на SUWIN.exe файла (проблема не е от скапан инсталационен диск - пробвах с три различни диска). Опитах и от DOS - същия ефект.
    Има ли някой да се е сблъсквал с подобен проблем? Приемам всякакви идеи освен "format c:" на ниско ново.
  12. Senior Member Аватара на ru-boy
    Jan 2000
    <blockquote id="quote"><font size="1" id="quote"><b id="quote">цитат:</b id="quote"></font id="quote"><table border="0" id="quote"><tr id="quote"><td class="quote" id="quote"><font size="1" id="quote">[?][?][?] Багодаря ти Ru-boy за съветите. Възползувах се от тях в пълен обем, но явно "не там е зарито кучето". Всъщност проблема е следния: Операционната ми система е Windows 98SE. Имам от известно време проблеми с нея: спиране на програми и игри, блокиране работата на Explorera и други подобни. Искам да я преинсталирам за да се "самоподреди", но тя не ще. При пускане на Setup минават успешно тестовете и след това "fatal error" на SUWIN.exe файла (проблема не е от скапан инсталационен диск - пробвах с три различни диска). Опитах и от DOS - същия ефект.
    За да възвърнеш здравето на зле работещ уиндоус 98 са нужни само две неща, а именно:
    <font color="yellow">1.</font id="yellow"> В "System Information" има падащо меню една от възможностите е "File Checker". Стартираш програмата, като не забравяш, че ще ти е нужно инсталационното си-ди с уиндоуса или директорията, където си записал копие с инсталационен уиндоус. Програмата проверява за липстващи, изтрити и/или заменени файлове и библиотеки, които са жизнено необходими за уиндоуса. Много често е разумно да се оставят само тези с по-нова версия. Като начало провери само за липстващи файлове. После почни с тежката артилерия, която програмата позволява. Разгледай и пусни това, което ти е нужно по твоя преценка. Почти винаги има добър ефект.
    <font color="yellow">2. </font id="yellow">Чистене на регистри с добра програма. Има само една добра програма за чистене на регистри и другите програми и дишат пепеляка. Става въпрос за <font color="yellow">*</font id="yellow"><font color="orange">System Mechanic </font id="orange">( www.iolo.com ).
    Мисля, че след тези процедури нещата ще се оправят (и без да преинсталираш). Разбира се, може да се наложи да си инсталираш Direkt X и някой други програмки наново и за по сигурно, но в общи рамки това е.
    <font color="yellow">*</font id="yellow">- става въпрос за версия <font color="yellow">3.6х </font id="yellow">( <font color="yellow">1,5 Мб </font id="yellow">!), защото на сайта гледам има само <font color="yellow">4.х</font id="yellow"> ( <font color="yellow">33 Мб </font id="yellow">?!? брех!)
    Aug 2003
    _heat, само да ти кажа, че това SUWIN означава само хардуена грешка в някой компонент. Съветвам се да провериш паметта. Значи, 90% гаранция ти давам, че е от това.
    Dec 2000
    Може инсталационните файлове да не се четат добре от цд-то и да ги записва прецакани на хард диска (визирам евентуален проблем с четящото цд-ром устройство). Ако можеш, копирай иснталационната директория на виндоуса в хард диска и с някоя програмка, например Total Commander, провери .cab файловете дали са се записали без грешки. Ако е така, пусни инсталацията от хард диска.
  16. Senior Member Аватара на Malone
    Jul 2003
    Ru-boy и Lupus
    Имам тук при мен System Mechanic ver. 3.2, обаче с още един файл [сещайте се [] ].
    Аз съм доволен от нея.
    Ru-boy, ако смяташ, че ще му свърши работа ще я кача веднага някъде. 1.39 Mb
  17. Senior Member Аватара на Lupus
    Aug 2003
    Благодаря на всички, които проявиха желание да помогнат. Ще проверя внимателно всяка идея и дано нещо помогне. Ще Ви пиша за резултатите. Malone, ако качиш програмата пиши от къде да си я дръпна. Тя ще е полезна и за останалите.
  18. Senior Member Аватара на ru-boy
    Jan 2000
    <blockquote id="quote"><font size="1" id="quote"><b id="quote">цитат:</b id="quote"></font id="quote"><table border="0" id="quote"><tr id="quote"><td class="quote" id="quote"><font size="1" id="quote">Ru-boy и Lupus
    <div align="right">оргинално мнение на Malone</div id="right">
    Малко ти е старичка версията Малоне [], а иначе другия файл, няма да му е нжен, защото тя работи 30 дена и без него, а до тогава ще е оправил нещата човека [].
  1. Купувам хард диска за лаптоп
    От dra6ko във форум Купува
    Последно: 01-09-11, 16:57
  2. Проблем с хард диска
    От hihklm във форум Общ - хардуер
    Последно: 25-01-09, 09:44
  3. Продавам три хард диска
    От hybaveca във форум Продава
    Последно: 22-07-06, 16:37
  4. Огледални копия на хард диска
    От Djniki във форум Общ - софтуер
    Отговори: 12
    Последно: 20-08-04, 21:20
  5. Проблем с два хард диска
    От FIFA във форум Общ - хардуер
    Последно: 30-11-03, 01:29
