MAG 796PF2, 17”, 0.21(H), 96Khz, Flat, TCO99
и
Hansol 720D 17” Flat, 0.20, TCO99, 1280x1024@85Hz
и
Poneje te murzi - da te svetna 4e kato pita6 koe e po dobro pone postni specifikaciite i na dvata puk togava PItai:
ОПИСАНИЕ
131.00 EUR
Picture Tube 17” (16” viewable) Pure FLAT picture tube, 90є deflection, Anti-glare, Anti-static, Anti-reflection
Medium short persistence
Horizontal Dot pitch 0.21mm
Diagonal Dot pitch 0.25mm
Synchronization Horizontal: 30 to 96kHz
Vertical: 50 to 160 Hz
Maximum Resolution 1600 x 1200 @ 76Hz
Compatibility IBM® XT, AT, 386, 486, Pentium®, MMX, II, PS/2 and compatibles, PnP, Windows 9x/2k/Me/NT
Macintosh®/Power Mac® G3, G4 (with adapter)
Plug & Play DDC1 & DDC2B
Input Signal Video: RGB Analog (0.7 Vp-p, 75ohms)
Sync: H/V Separate, H/V Composite (TTL)
Input Connector Signal: 15pin mini D-sub
Power: 3-pin plug (CEE22)
User Interface Power ON/OFF Switch, Power LED Indicator, One- key Controller (JAG), e-Video Controller, On- Screen Display
OSD Controls Contrast, Brightness, H/V Size, H/VPosition, Pincushion, Trapezoid, Degaussing, Reset, Advanced options (Rotation, Parallelogram, BOW, Top/Bottom Corner, H/V Moirй, Focus), Color Manager, Language Manager, User mode, OSD Manager
DVD e-Video Normal, Zoom, Vivid, Warm, Gold
Display Area Factory Setting: 310mm x 230mm (W x H)
Maximum Scan: Full screen display compatible
Video Bandwidth 175MHz Typical
Power Supply 100-240 VAC, 50-60Hz (Auto switch)
Power Consumption Normal operation: < 130W
Suspend mode: < 10W
Active Off: < 5W
Operating conditions Temperature: 0 to 40єC
Humidity: 10 to 90%
Dimensions Physical: 410 (W) x 424 (H) x 415 (D) mm
Box: 544 (L) x 513 (W) x 470 (H) mm
Weight Net: 16.9 kg (37.2 lbs.)
Regulations UL/ CUL, TUV/GS, DHHS, CE, FCC-B, CNS/BSMI, CCEE, MPRII
Power Management EPA Energy Star™, VESA® DPMS™, NUTEK
още картинки
Производител:
MAG
Web Site
СПЕЦИФИКАЦИИ
Display
* Display Technology : Pure FLAT
* Display Type : Flat CRT
* Dot pitch : 0.25mm,0.21(Horizontal),
* Screen size (in) : 17
* Viewable image size : 16
Resolution
* Maximum resolution : 1600 x 1200
* Refresh at maximum : 76
Scanning frequency
* Horizontal : 30-96KHz
* Vertical : 50 - 160 Hz
________________________________________________________________________________
Prijsvergelijk Hansol 720D
Techniek
Flat screen
Formaat
17 inch
Zichtbaar formaat
16 inch
Dot pitch
0.25 mm
Pixel frequentie
157 MHz
Resolutie (max.)
1600 x 1200
Refresh rate
1024 x 768
85 Hz
1600 x 1200
75 Hz
Frequentiebereik
Horizontaal
30-96 kHz
Verticaal
47-160 Hz
Overig
USB-hub
Keurmerk
MPR-II, TCO 99
Aansluiting
D-sub
Speakers ingebouwd
Gewicht
17 kg
Afmetingen (H x B x D)
417 x 418 x 419 mm
Introductie model
2003
Website
http://www.hansol-us.com/..
E sega ---> koi e po dobur a?
мерси за язвителния отговор [B)]
не ме мързи а можеби нямам много време да ги търса тез спесификации
DASH - обади отговор обаче :)
според мен Hansol 720D е по-добър
обоснови се моляте защо мислиш че е по-добър Hanslola и с какво
ами обосновката ми е от гледна точка на следното
1. Продавам Хансол от както излязоха на булгарския пазар ( първия модел е 401 А Мазелан )
2. 17 " 97 KHz, 1600 х1200 85 HZ ( a ako имаш и добро видео - 100 Hz )
3. Real FLAT и кинескопа е макар и да е на Самсунг е с идеална електроника - много добра картина ( малко по-тъмен е от другите , но много хора казват че не ги боли очите от продължителна работа с тоя монитор
4. Цената му е супер за тия характеристики
5. Гаранцията му е пълна 36 м ( за разлика Самсунг е 24 )
6. Питаш въпрос - отговарям - ти преценяваш ( не налагам мнение - изказвам наблюдения и предпочитания )
7. сигурен съм че ще ми изкараш ужасно много опровержения на по-горе казаните неща - но искам да помислиш над едно :
МАГ излизат и си отиват от пазара - нямат постоянно място от последните 7 г. ( а доколкото знам Proview ги бяха купили - може и клюка да е ) а Хансол са си на пазара на лидерски позиции вече мин. 6 г
<blockquote id="quote"><font size="1" id="quote"><b id="quote">цитат:</b id="quote"></font id="quote"><table border="0" id="quote"><tr id="quote"><td class="quote" id="quote"><font size="1" id="quote"> не ме мързи а можеби нямам много време да ги търса тез спесификации[B)]
<div align="right">оргинално мнение на Светъл</div id="right">
Ne mi se opravdavai s vreme - 6toto cyalata operaciya otnema dve minuti
A 6to se otnasya do tova koi e po dobyr - MAG e s malko po dobri pokazateli ot HAnsola - no ob6to vzeto i dvata sa dobur izbor, no li4no moeto mnenie natejava pove4e za MAG ;)
Хенсол-а е по добър !!! обосновка : виждал съм как работят и двата монитора и останах неприятно изненадан от МАГ-а нито контраста е контраст нито яркоста е такава .... а 4естотата която е дадена в спецификация .....няма нищо общо с реалноста !
Тоя Hansol с тия 1024 x 768 - 85 Hz го отписвам веднага...
А MAG-а, от своя страна(не видях да пише за refresh-rate на 1024 x 768 ) но няма TCO'99...
На твое място щях да търся друг... CTX например
нммм оставам с впечатлението че Hansol ше се зима
мерси много
Metal Militia - CTX - ne me karaj da se smeq molq te
<blockquote id="quote"><font size="1" id="quote"><b id="quote">цитат:</b id="quote"></font id="quote"><table border="0" id="quote"><tr id="quote"><td class="quote" id="quote"><font size="1" id="quote">Тоя Hansol с тия 1024 x 768 - 85 Hz го отписвам веднага...
<div align="right">оргинално мнение на MetalMilitia</div id="right">
Hansol на 1024 x 768 е 100Hz, а на 1280х1024 е 85Hz
Да бъдем честни - 1600 х 1200 също на 85 КХз
за Hansol 720 D
амиго колко пари ти искат за него ? ( крайна цена )[?]
135 $
И кво 4акаш - чисто нов монитор , 36 месеца гаранция , 100 khz, Плосък екран , нисък курс на долара -ВЗИМАЙ ГООО
