Резултати от 1 до 15 от общо 19
Сравнение кой монитор е по-добър???
    Nov 2003
    MAG 796PF2, 17”, 0.21(H), 96Khz, Flat, TCO99
    и
    Hansol 720D 17” Flat, 0.20, TCO99, 1280x1024@85Hz
    Apr 2002
    Poneje te murzi - da te svetna 4e kato pita6 koe e po dobro pone postni specifikaciite i na dvata puk togava PItai:
    ОПИСАНИЕ
    131.00 EUR
    Picture Tube 17” (16” viewable) Pure FLAT picture tube, 90є deflection, Anti-glare, Anti-static, Anti-reflection
    Medium short persistence
    Horizontal Dot pitch 0.21mm
    Diagonal Dot pitch 0.25mm
    Synchronization Horizontal: 30 to 96kHz
    Vertical: 50 to 160 Hz
    Maximum Resolution 1600 x 1200 @ 76Hz
    Compatibility IBM® XT, AT, 386, 486, Pentium®, MMX, II, PS/2 and compatibles, PnP, Windows 9x/2k/Me/NT
    Macintosh®/Power Mac® G3, G4 (with adapter)
    Plug & Play DDC1 & DDC2B
    Input Signal Video: RGB Analog (0.7 Vp-p, 75ohms)
    Sync: H/V Separate, H/V Composite (TTL)
    Input Connector Signal: 15pin mini D-sub
    Power: 3-pin plug (CEE22)
    User Interface Power ON/OFF Switch, Power LED Indicator, One- key Controller (JAG), e-Video Controller, On- Screen Display
    OSD Controls Contrast, Brightness, H/V Size, H/VPosition, Pincushion, Trapezoid, Degaussing, Reset, Advanced options (Rotation, Parallelogram, BOW, Top/Bottom Corner, H/V Moirй, Focus), Color Manager, Language Manager, User mode, OSD Manager
    DVD e-Video Normal, Zoom, Vivid, Warm, Gold
    Display Area Factory Setting: 310mm x 230mm (W x H)
    Maximum Scan: Full screen display compatible
    Video Bandwidth 175MHz Typical
    Power Supply 100-240 VAC, 50-60Hz (Auto switch)
    Power Consumption Normal operation: < 130W
    Suspend mode: < 10W
    Active Off: < 5W
    Operating conditions Temperature: 0 to 40єC
    Humidity: 10 to 90%
    Dimensions Physical: 410 (W) x 424 (H) x 415 (D) mm
    Box: 544 (L) x 513 (W) x 470 (H) mm
    Weight Net: 16.9 kg (37.2 lbs.)
    Regulations UL/ CUL, TUV/GS, DHHS, CE, FCC-B, CNS/BSMI, CCEE, MPRII
    Power Management EPA Energy Star™, VESA® DPMS™, NUTEK
    още картинки
    Производител:
    MAG
    Web Site
    СПЕЦИФИКАЦИИ
    Display
    * Display Technology : Pure FLAT
    * Display Type : Flat CRT
    * Dot pitch : 0.25mm,0.21(Horizontal),
    * Screen size (in) : 17
    * Viewable image size : 16
    Resolution
    * Maximum resolution : 1600 x 1200
    * Refresh at maximum : 76
    Scanning frequency
    * Horizontal : 30-96KHz
    * Vertical : 50 - 160 Hz
    ________________________________________________________________________________
    Prijsvergelijk Hansol 720D
    Techniek
    Flat screen
    Formaat
    17 inch
    Zichtbaar formaat
    16 inch
    Dot pitch
    0.25 mm
    Pixel frequentie
    157 MHz
    Resolutie (max.)
    1600 x 1200
    Refresh rate
    1024 x 768
    85 Hz
    1600 x 1200
    75 Hz
    Frequentiebereik
    Horizontaal
    30-96 kHz
    Verticaal
    47-160 Hz
    Overig
    USB-hub
    Keurmerk
    MPR-II, TCO 99
    Aansluiting
    D-sub
    Speakers ingebouwd
    Gewicht
    17 kg
    Afmetingen (H x B x D)
    417 x 418 x 419 mm
    Introductie model
    2003
    Website
    http://www.hansol-us.com/..
    E sega ---> koi e po dobur a?
    Nov 2003
    мерси за язвителния отговор [B)]
    не ме мързи а можеби нямам много време да ги търса тез спесификации
    Aug 2002
    DASH - обади отговор обаче
    според мен Hansol 720D е по-добър
    Nov 2003
    обоснови се моляте защо мислиш че е по-добър Hanslola и с какво
    Aug 2002
    ами обосновката ми е от гледна точка на следното
    1. Продавам Хансол от както излязоха на булгарския пазар ( първия модел е 401 А Мазелан )
    2. 17 " 97 KHz, 1600 х1200 85 HZ ( a ako имаш и добро видео - 100 Hz )
    3. Real FLAT и кинескопа е макар и да е на Самсунг е с идеална електроника - много добра картина ( малко по-тъмен е от другите , но много хора казват че не ги боли очите от продължителна работа с тоя монитор
    4. Цената му е супер за тия характеристики
    5. Гаранцията му е пълна 36 м ( за разлика Самсунг е 24 )
    6. Питаш въпрос - отговарям - ти преценяваш ( не налагам мнение - изказвам наблюдения и предпочитания )
    7. сигурен съм че ще ми изкараш ужасно много опровержения на по-горе казаните неща - но искам да помислиш над едно :
    МАГ излизат и си отиват от пазара - нямат постоянно място от последните 7 г. ( а доколкото знам Proview ги бяха купили - може и клюка да е ) а Хансол са си на пазара на лидерски позиции вече мин. 6 г
    Apr 2002
    <blockquote id="quote"><font size="1" id="quote"><b id="quote">цитат:</b id="quote"></font id="quote"><table border="0" id="quote"><tr id="quote"><td class="quote" id="quote"><font size="1" id="quote"> не ме мързи а можеби нямам много време да ги търса тез спесификации[B)]
    <div align="right">оргинално мнение на Светъл</div id="right">
    Ne mi se opravdavai s vreme - 6toto cyalata operaciya otnema dve minuti
    A 6to se otnasya do tova koi e po dobyr - MAG e s malko po dobri pokazateli ot HAnsola - no ob6to vzeto i dvata sa dobur izbor, no li4no moeto mnenie natejava pove4e za MAG
    Apr 2003
    Хенсол-а е по добър !!! обосновка : виждал съм как работят и двата монитора и останах неприятно изненадан от МАГ-а нито контраста е контраст нито яркоста е такава .... а 4естотата която е дадена в спецификация .....няма нищо общо с реалноста !
    Sep 2003
    Тоя Hansol с тия 1024 x 768 - 85 Hz го отписвам веднага...
    А MAG-а, от своя страна(не видях да пише за refresh-rate на 1024 x 768 ) но няма TCO'99...
    На твое място щях да търся друг... CTX например
    Nov 2003
    нммм оставам с впечатлението че Hansol ше се зима
    мерси много
    Aug 2002
    Metal Militia - CTX - ne me karaj da se smeq molq te
    Jun 2002
    <blockquote id="quote"><font size="1" id="quote"><b id="quote">цитат:</b id="quote"></font id="quote"><table border="0" id="quote"><tr id="quote"><td class="quote" id="quote"><font size="1" id="quote">Тоя Hansol с тия 1024 x 768 - 85 Hz го отписвам веднага...
    <div align="right">оргинално мнение на MetalMilitia</div id="right">
    Hansol на 1024 x 768 е 100Hz, а на 1280х1024 е 85Hz
    Aug 2002
    Да бъдем честни - 1600 х 1200 също на 85 КХз
    за Hansol 720 D
    амиго колко пари ти искат за него ? ( крайна цена )[?]
  17. Тук е от
    Nov 2003
    135 $
    Aug 2002
    И кво 4акаш - чисто нов монитор , 36 месеца гаранция , 100 khz, Плосък екран , нисък курс на долара -ВЗИМАЙ ГООО
  1. Отговори: 0
    Последно: 17-11-13, 15:55
  2. Сравнение и избор на TV
    От false_rate във форум Телевизори
    Последно: 21-02-13, 14:36
  3. Добър 24" монитор?
    От jovanoty във форум Общ - хардуер
    Последно: 14-01-10, 06:35
  4. продавам добър компютър и монитор
    От labios във форум Продава
    Последно: 04-11-08, 16:12
  5. Сравнение на VGA Radeon
    От Novia във форум Аудио и Видеокарти
    Последно: 04-11-04, 23:23
