Резултати от 1 до 9 от общо 9
Детско колело 16 цола
    Nov 2002
    Безжична Wifi IP камера FullHD 2.0Mpx
    Model YKDM-A111N3
    Camera
    Main CPU High Performance Ti Davinci Series DSP
    Image Sensor 1/2.8 inch Progressive Scan SONY Exmor CMOS Sensor,Low-light Colorful Image quality
    Effective Pixels 1920(H)x1080(V)
    Shutter Speed 1/25 Seconds~1/10000 Seconds
    Min.illumination Color:0.3Lux, B/W:0.01Lux/0Lux(IR On)
    Optical Lens 3.6mm(6mm Optional)
    Angle of View 51°(6mm lens)/90°(3.6mm lens)
    Nightvision Up To 98ft
    Day/Night IR Cut(ICR) Auto-switch
    Video
    System Embedded Linux,Built-in Web Server,Remote Setup Enable
    Compression H.264 Encoding,Pure Hardware Compression,3D Image Noise Reduction Technology
    Frame Rate 2.0MP(1920*1080),1.3MP(1280*960),1.0MP(1280*720)adjustable,1~30FPS Adjustable; 0.1M~6Mpbs Adjustable
    Main Stream 1920*1080,1280*720
    Sub Stream 640*360,480*360,480*270,CIF,QVGA,352*192,320*192 etc.
    Image Function Auto BLC/WB/GC
    Application Function Motion detection,Privacy Masking,Email Alarm,Title OSD,Image flip,Auto relink etc.
    Remote Function Setup Menu,Snapshots,Supervisory control etc.
    Network
    Ethemet RJ45 10M/100M Ethernet interface
    Application P2P Cloud Service,ADSL,DDNS,UPMP,FTP,SMTP,Email etc.
    Onvif 2.0 Version ; Upgrade In Time
    Remote View IE Browser,Cloud Service Platform,Smart Phone Apps.
    Smart Phone Support iPhone,iPad,Android,Remote monitoring via Apps
    Protocol TCP/IP,RTSP/FTP/PPPOE/DHCP/DDNS/NTP/UPNP
    General Parameters
    Power Supply DC 12V/2A
    PoE Cable Optional(Without Built-in POE module)
    Power Consumption 5~12W(IR on/off)
    Operating Protection -10℃~60℃,Humidity 90% or Less(Non-condnsing)
    Ingress Protection IP66
    Package Dimension 220*125*115(mm)
    Package Weight 700g
    Камерата има един проблем. Или поне аз имам един проблем с нея - Не работи стабилно безжичната връзка, което се изразява в загуба и с рутера ми след 8-12ч. След рестарт на захранването на камерата всичко е ок в следващите 8-12ч. Когато камерата е закачена през RJ45 порта няма никакви проблеми.
    Камерата я бях приготвил за наблюдение на задния двор, където извеждаме децата. Но седи от 1-2 месеца на балкона за тестове, а така и не успях да се организирам и да стигна до нея.
    Цена 120лв.
    София. Може и с Еконт.
    скайп: imarh7805
    o 888 ЧlЧЧЗЧ но рядко вдигам на непознати номера, така че най-добре тук.
    Този пост е редактиран от imarh; 01-04-15 в 23:09.
  3. Junior Member
    Nov 2002
    Отговор: Безжична Wifi IP камера FullHD 2.0Mpx
    Камерата си струва и цената става 110лв.
    Камерата няма да се продава на всяка цена и във всички случаи, ще изчезне в един момент.
    Nov 2002
    Всичко по колелото е изправно и работи. Предна спирачка + контра. Седалката е скъсана, както се вижда на снимката, но е абсолютно използваема.
    IMG_20150331_183620257_HDR.jpgIMG_20150331_183605703_HDR.jpgIMG_20150331_183633621.jpgIMG_20150331_183654440.jpgIMG_20150331_183707999.jpg
    Цена 50лв.
    скайп: imarh7805
    Следващата тема,която пуснеш,ще се трие без предупреждение!!!
    Този пост е редактиран от avenger; 08-04-15 в 20:51.
  5. Junior Member
    Nov 2002
    Отговор: Детско колело 16 цола
    Проблема с камерата е решен(твърдо IP вместо dhcp), така че я свалям от продажба. Остава колелото.
  6. Senior Member Аватара на ivodivo
    Цената е добра на камерата но не поддържа ONVIF само по RTSP може да е разпознае софтуер а това е проблем за NVR-ите...
  7. Junior Member
    Nov 2002
    Цитат Първоначално публикувано от ivodivo Виж публикацията
    A цената беше повече от добра, но народа по форуми, базари и продавалници се присети като я свалих от продажба
    Да не стане пак така и с колелото, макар че там съм по-разговорчив щом става дума за дете.
  9. Senior Member Аватара на ivodivo
    за това давай UP пред ден два да се види и от тези които влизат малко по рядко...
  10. Junior Member
    Nov 2002
    В колелцето има хляб и даже е оборудвано със светодиоден фар и стоп! А на детето може да му вземето друго със спестените 100лв. за ново колело!
    /Възможно ли е темата да се зачисти от модератор, така че да останат само постове свързани с колелото/
  11. Junior Member
    Nov 2002
    Продадено. Да се ползва със здраве.
  1. Продавам Водна помпа Вида 2,5/2 цола
    От kristov във форум Приключили продажби
    Последно: 02-09-14, 18:13
  2. Детско парти
    Последно: 03-07-14, 10:18
  3. Детско колело 20"
    От ivanxxx във форум Приключили продажби
    Последно: 20-05-12, 16:47
  4. Отговори: 4
    Последно: 20-04-12, 13:41
  5. Заключване на колело
    От eror във форум Дъра-Бъра
    Отговори: 14
    Последно: 04-11-08, 08:45
