Продавам :
802.11b 4-Port 11 Mbps Cable/DSL Wireless Router
http://www.cameo.com.tw/products/html/wireless/wlb-2203_2204.htm
Features/Specifications:
· 4-Port Broadband Wireless Router
· General Features:
· IEEE 802.11b compliant
· 11 Mbps data rate
· 64/128-bit WEP encryption
· Four (4) 10/100 Mbps auto-MDIX Ethernet ports
· One (1) 10/100 Mbps auto-MDIX Ethernet port
· Web-based management
· Natural firewall
· 2 dbi external antenna
· 2.412 - 2.484 GHz frequency band
· Auto detects and configures ISP type
· Auto configures MAC address authentication
· URL content filtering
· Power LED indicator
· WAN LED activity indicator
· WLAN LED activity indicator
· LAN activity indicator
· Wall mountable
· Protocols:
· TCP/IP NAT PPPoE DHCP (client and server) HTTP UDP PAP CHAP RIP1 DDNS
нов, няма гаранция (внос от САЩ) , имам 2 броя
ЦЕНА – SOLD
_________________________________________________________________
4-Port 10/100 PCI Router Card RealTek RTL8139D
· 4-Port PCI Router Card
· General Features:
· RealTek RTL8139D and RTL8305SB chipsets
· 4-ports
· NWay switch
· 10/100 Mbps auto negotiation
· IEEE 802.3x, 802.3/3u compliant
· Auto MDIX function
· Supports 2048 MAC address table
· Supports store and forward architecture
· PCI 2.2 compliant interface
· Supports Wake On Lan (WOL)
· Supports Boot ROM function
· Retail Package Includes:
· 4-port PCI router card
· Driver/Software CD
Additional Information:
Comaptibility
· Linux Compatibility:
· Found to work with Slackware version 9.1, using the 8139too.o driver, as...
· ...a 4-port Ethernet card. Provided Internet connection sharing software...
· ...is NOT Linux compatible.
Product Requirements
· Microsoft Windows 95/98/NT/2000/ME/XP
· 486 class processor or faster
· 32 MB RAM
· ISDN, xDSL, DirectPC or cable modem with ISP
· Integrated network firewall
ЦЕНА – SOLD
нова, няма гаранция (внос от САЩ)
________________________________________________________________________________
Gigabyte 802.11g 54Mbps Wireless LAN PCI Router Card
http://www.gigabyte.com.tw/Support/C...?ProductID=977
· 802.11g 54 Mbps WLAN PCI Router Card
· General Features:
· IEEE 802.11g standards
· 54 Mbps data transfers
· 2.4 GHz Frequency Range
· 64-bit/128-bit WEP Encryption Security
· NAT (Network Address Translation) supported
· VPN pass-through
· External antenna connector (antenna not included)
· Data Rate:
· 6/9/12/18/24/36/48/54 Mbps
· Modulation:
· DSSS (DBPSK, DQPSK, CCK) OFDM (BPSK, QPSK, 16-QAM, 64-QAM)
· Connectors:
· One (1) 10/100 Mbps Ethernet RJ-45 LAN port
· One (1) 10/100 Mbps Ethernet RJ-45 WAN port
· Reset
· Power LED
· Regulatory Approvals:
· FCC
· CE
Package Includes:
· Notes:
· OEM version of the card used in the Gigabyte GN-BC01 kit
· Antenna NOT Included
· Product Requirements:
· Cable or DSL modem
· PC or Switch with RJ-45 port
· PCI slot
· Wi-Fi Antenna
Това чудо е изцяло хардуерен рутер в корпус на PCI платка и работи като такъв (не се инсталира, не иска дарйвери) , има си Web интерфейс за настройка и т.н.
Монтира се в какво да е PC , трябва ви само OS и браузър. Аз го пробвах с Linux boot cd (Knoppix) , дори не е нужно да имате харддиск .
ЦЕНА – 45 лв.
нов, няма гаранция (внос от САЩ), имам 2 броя
Адаптер за 2,5 инчов HDD (от лаптоп) към обикновен IDE контролер.
Позволява да вържете HDD от лаптоп към обикновен компютър.
DESCRIPTION
Notebook Hard Disk Adapter /2.5 Laptop to 3.5 IDE Drive .
Features:
· Easy to connect the 2.5 inch hard disk (notebook hard disk) to your desktop computer
· easy to transfer the data to the 2.5 inch hard disk, also
· It convert the 44 pin (notebook HDD IDE) to IDE 40 pin (3.5 inch IDE HDD
ЦЕНА: SOLD
Вентилатор Zalman CNPS-7000AlCu . Става за всички сокети : 478,939,754,775
http://www.zalman.co.kr/usa/product/cnps7000alcu.htm
http://www.enicomp.com/shopping/product.php?p=17530
http://www.comexgroup.com/technologi...zalman7000.htm
ЦЕНА – 30 лв.
Ползван е около 6 месеца
Всички чаркове са намират във Варна , имам човек в София , за останалите - куриер с наложен платеж .
За контакти gsm:0889233004 , icq:58571607 и тук.
