Tenda W302R Wireless-N Broadband Router
[img width=391 height=600]http://www.tenda.cn/pdtData/wireless/w302r/ok.jpg[/img]
Standard IEEE802.11b √
IEEE802.11g √
IEEE802.11n √
Connection Type PPPOE √
Static IP √
Dynamic IP √
PPTP √
L2TP √
802.1x √
Wireless Access √
Basic Setting IP Address Change √
MAC Address Clone √
DNS Setting √
Wireless Setting Wireless Basic Setting √
WEP √
WPA-PSK/WPA2-PSK √
WPA/WPA2 √
802.1x √
WDS √
WPS √
Wireless Access Control √
DHCP DHCP Server √
DHCP Client List √
Virtual Server Single Port Forwarding √
Port Range Forwarding √
Port Trigger √
ALG FTP/TFTP/PPTP/IPSEC/L2TP √
DMZ Host √
UPnP √
Bandwidth Control Port-based √
IP-based √
Security Setting Client Filtering √
URL Filtering √
DNS Filtering ×
MAC Address Filtering √
Network Anti-attack √
Specific Application Filtering ×
Local Web Management √
Remote Web Management √
WAN Ping √
Routing Table Routing Table √
Static Routing √
System Tools Time Setting √
Dynamic DNS √
Backup/Restore √
Firmware Upgrade √
Restore to Factory Default Setting √
Reboot √
Login Password Modification √
Syslog √
Integrates router, wireless access point, four-port switch and firewall in one
Complies with IEEE802.11n, IEEE802.11b and IEEE802.11g standards MIMO technology utilizes reflection signal to increase three times transmission distance of original 802.11G standard to reduce the blind spots
Provides 300Mbps receiving rate and 300Mbps sending rate
Wireless priority server makes your voice and video more smooth
Supports 64/128-bit WEP data encryption and many encryption modes such as WPA / WAP2
Supports remote/local Web management
Supports wireless Roaming technology and ensures high-efficient wireless connections
Supports wireless SSID stealth mode and MAC address access control
Supports Auto MDI/MDIX
Provides system log to record the status of the router
Supports MAC address filtering, NAT, NAPT
Supports UPnP and DDNS
Supports the access control over 30 MAC addresses
Supports DHCP server/client
Supports SNTP
Supports virtual server and DMZ host
Supports auto wireless channel selection
Supports 20MHz/40MHz frequency width ( the user have the authority to choose the frequency width 20MHz)
W302R employs advanced MIMO technology and extends the wireless network coverage greatly. Compatible with IEEE802.11n and IEEE802.11g/b standards, it can provide up to 300Mbps stable transmission rate. Additionally, it integrates router, wireless access point, four-port switch and firewall in one. Its extraordinary intelligent software...
Цена: 69 лв. Нови с 24м. гаранция.
Wi-Fi N Router Tenda W311R 150Mbps - 55 лв.
Router Tenda R502 Broadband - 27 лв.
Lan card 10/100 PCI Realtek chipset - 3.99 лв ( цена на едро )
Switch 5 port Tenda - 14 лв.
PCB switch 8 port - 11 лв.
Отстъпки за количества, търговци и дилъри!
http://www.secondparts.com
office(at)secondparts.com
ж.к. Борово, ул. Борово No57
тел. 8505014
 Новини
 Новини Форум
 Форум Актуално
 Актуално сървър
 сървър
  Отговор с цитат
  Отговор с цитат
