Продавам бутална помпа CAT PUMP модел 1050. Помпата не е използвана. Подходяща за водоструики.
www.catpumps.com/select/pdfs/1050.pdf
Model 1050 Only
Flow*................................................................... 12 gpm (45 l/m)
Pressure Range*....................................100 to 1800 psi (7 to 125 bar)
RPM*............................................................. 1150 RPM (1150 RPM)
Inlet Pressure Range* .................................20 to 60 psi (1.4 to 4 bar)
Maximum Liquid Temperature*.............................100°F (38°C)
*C.A.T. Required
Common Specifications
Bore......................................................................0.945” (24 mm)
Stroke...................................................................1.180” (30 mm)
Crankcase Capacity..............................................42 oz. (1.26 l)
Inlet Ports (2)..................................................3/4” NPTF (3/4” NPTF)
Flushing Ports (2) (1051C)..............................1/8” NPTF (1/8” NPTF)
Discharge Ports (2).........................................1/2” NPTF (1/2” NPTF)
Pulley Mounting............................................. Either Side (Either Side)
Shaft Diameter......................................................1.181” (30 mm)
Weight..................................................................44 lbs. (20 kg)
Dimensions....................................16.28 x 12.99 x 6.44” (414 x 330 x 164 mm)
Цена 2000 лв.
Вана от пластмаса с тефлоново покритие. Размери 2,6х2,6х2,4h м.
Цена 2000 лв.
За контакт Николай-0899707368 град Стара Загора.
