здравеите!-имам задача да флашна 2м битов биос на асус дъно и четох за хот флаш но само на определени дъна но сие опасно все пак щот приятели с такова дъно не се навиват да опитат --четох че някои лан карти имат цокъл за такива чипове за ботване на компа от там при настроика от биоса--имам такава лан карта-um9008f-umc на иса слот свалих драиверите и като разархивирах има флаш ехе и еепром ехе фаилчета -**
** EEPROM Utility
** v3.20 Sep. 2004
Introduction:
This document shows you how to use the eeprom utility. This utility runs
under DOS environment.
Contents of the Subdirectory:
EEPROM.EXE The eeprom utility program file.
EEPROM.CFG The eeprom utility default configuration file.
EEPROM.TXT This file.
Usage:
The eeprom menu consists of four functions:
1. F1: Create Data File
You should use this function to create a new EEPROM data file.
The default value of "Ethernet ID", "Subsystem ID", "Subsystem Vendor ID"
and "PHY address" are invalid. Modify them to the valid value and
save to a file.
2. F2: Open Data File
If you want to modify an existed EEPROM data file, you could use
this function.
3. F3: Write to EEPROM
After the EEPROM data file is OK, you could use this function
to write the data file into EEPROM.
4. Esc: Exit
Exit this program.
Command line usage
Usage: EEPROM [option]
option: -? This help.
-h This help.
-p[#] [MAC Address] filename [-i [filename1]] [-o filename2]
Program EEPROM with data in filename and output the
programmed MAC address to filename2 if -o is specified.
use alternative way to modify MAC address if -i is specified.
if filename1 is omitted, the program will read MAC from console.
# : ( 1 ~ 8 ) card number, could be ignored.
[MAC Address]: 12 HEX characters, could be ignored.
p file1.nic : Program file1.nic with first adapter.
p4 rpl.nic : Program rpl.nic with 4th adapter.
-v[#] filename Verify EEPROM with data in filename.
p file1.nic : Verify file1.nic with first adapter.
p4 rpl.nic : Verify rpl.nic with 4th adapter.
-f[#] filename Write filename with EEPROM data.
f file1.nic : Write file1.nic with first adapter.
f4 rpl.nic : Write rpl.nic with 4th adapter.
-e Display extened menu item.
-bt[#] <PXE|RPL> Select BootROM boot type.
PXE : Select PXE boot.
RPL : Select RPL boot.
-bm[#] <19|18|BBS|NO> Enable boot up methods.
bm 19 : Try network boot first, then local drives.
bm 18 : Try local drives boot first, then network.
bm BBS: According to BIOS(Boot Entry Vector).
bm NO : Local drives boot.
-g[#] Generate 1's compliment checksum and write it to EEPROM 0fh (high byte).
-c[#] Check if the checksum stored in EEPROM is valid or not.
-mi num filename Increase MAC address in filename by num.
-md num filename Decrease MAC address in filename by num.
-km[#] mac-address Write mac-address to #th NIC's EEPROM MAC address field.
-kv[#] SVID Write SVID to #th NIC's EEPROM subsys-vendor ID field.
-ks[#] SSID Write SSID to #th NIC's EEPROM subsys-system ID field.
-l[#] <00|01|10|11> Set EEPROM PHY LED Setting bits (LEDS1,LEDS0).
00 : set (LEDS1,LEDS0) to (0,0).
01 : set (LEDS1,LEDS0) to (0,1).
10 : set (LEDS1,LEDS0) to (1,0).
11 : set (LEDS1,LEDS0) to (1,1).
Exit status:
0 Command execution success.
1 Command execution fail.
и другия--**
** FLASH Utility
** v3.12 Sep. 2004
Introduction:
This document shows you how to use the flash utility.
FLASH.EXE The flash utility program file.
FLASH.TXT This file.
Usage:
The flash menu consists of four functions:
1. Select Boot ROM Type:
Choose the flash ROM type of the one mounting on the board.
2. Load Image File:
Loading the image file that you are going to write in.
3. FlashROM Enable/Disable:
Select to enable or disable the FlashROM.
4. Write to Boot ROM:
Excute to write image file to FlashROM.
5. Esc: Exit
Exit this program.
Command line options
Usage: Flash [option]
-h This help.
-t [flash_type] Specific model of the FlashROM to write.
Show all FlashROM supported if not given flash_type.
-p[#] filename Program Boot ROM with data in filename.
-p file.img : Program file.img with first card
-p3 file.img : Program file.img with 3th card.
-v[#] filename Verify Boot ROM with data in filename.
-v file.img : Verify file.img with first card.
-v3 file.img : Verify file.img with 3th card.
-f[#] filename Create a file by Boot ROM content.
-f file.img : Create file.img with first card.
-f3 file.img : Create file.img with 3th card.
-c[#] filename Check Boot ROM image's device ID.
-c file.img : Check device ID in file.img with first card.
-c3 file.img : Check device ID in file.img with 3th card.
-e[#] [0|16|32|64] Enable or disable Boot ROM.
0 to disable boot ROM.
16 to enable 16K EPROM.
32 to enable 32K EPROM.
64 to enable 64K EPROM or FlashROM.
Please, reboot computer to enable Boot ROM.
Exit status:
Support EEPROM models:
SST:
SST29xE512, SST29xE512A, SST29xE010, SST29xE010A,
SST29xE020, SST29xE020A, SST39xF512, SST39xF010,
SST39xF020.
Winbond:
W29EE512, W29C010, W29C011, W29C020, W29C020C, W29C022,
W39L020.
--е2прома ми е sst 39sf020 и как да разбера с каква организация е той? или ако знаете програмки за флашване -програмиране на еепром през цокъл на лан карта??
