Отговор: Избор на LCD/Plasma телевизори-2014 / FAQ - на първа страница
Благодаря за бързия отговор! За футбол кои матрици са по-добри IPS или VA? И коя от двете има по-добра рязкост и контраст? Знам че отговора на тези въпроси е субективен, но бих искал да чуя точно твоето мнение. Предварително благодаря.
Повтаряли сме го десетки пъти...
VA - по-добър контраст, по-малък зрителен ъгъл, малко по-бърза като реакция(с 1 мс)
IPS - по-голям зрителен ъгъл, по-малък контраст, малко по-бавна като реакция
http://www.tftcentral.co.uk/articles...chnologies.htm
LCD Type matrix
specification |
Name
········· | Nickname ······················· | Summary ······································· | Positives ······································· | Negatives ······································· | Typical Spec
Features ······································· |
| TN | Twisted Nematic | Produced by most manufacturers
Dominate smaller screen market almost exclusively (15 - 19")
Also available in larger sizes up to 27" max
Low cost to produce, low retail costs for screens | Responsive especially since introduction of overdrive - key choice for gamer screens
Can natively support 120Hz+ refresh rates
120Hz+ screens often feature LightBoost backlight systems for improved motion blur | Most restrictive viewing angles, especially in vertical plane
Not great for colour critical work due to viewing angles primarily
Movie noise problematic, especially where overdrive used | 1 - 2ms G2G response time
1000:1 contrast ratio (realistic)
170/160 viewing angles (unrealistic in vertical field)
16.7m colour depth through 6-bit+FRC panels
Fairly light AG coating used
120Hz+ refresh rate support from some |
| VA | Vertical Aligment | Early MVA panels designed to improve on TN Film. Offered improved viewing angles but very slow response times
Later P-MVA and S-MVA panels offered improved response times. Also improved contrast ratios to 1000 - 1200:1 typically
Modern AMVA panels from AU Optronics. Improved response times further and contrast ratios now 3000 - 5000:1 | Contrast ratios very high with >3000:1 common in practice
Response times adequate for most users and vastly improved over older generations of MVA
8-bit colour depth
Some now support 120Hz refresh rate | Response time still normally slow compared with TN Film and IPS offerings.
Off-centre contrast shift inherent to all MVA panel generations. Not ideal for colour critical work
Viewing angles not as wide as IPS/PLS. Some improvements in very recent generations
No current 10-bit panels | 5 - 6ms G2G response time (in practice mostly much slower)
5000:1 contrast ratio (figures over 3000:1 common and realistic)
178/178 viewing angles (somewhat unrealistic considering contrast shifts and off-centre contrast issue)
60Hz refresh rate generally
Some 120Hz support emerging
16.7m colour depth through 8-bit panels
Light / semi-glossy AG coating used |
| PVA | Patterned Vertical Alignment | Early PVA panels designed as alternative to MVA, very similar performance overall
Later S-PVA and cPVA panels offered improved response times. Also improved contrast ratios to 2000- 4200:1 typically
PVA now rarely used or produced in desktop monitor market. Samsung seemingly concentrating on PLS instead. | Contrast ratios pretty high with >1200:1 common in practice
Response times adequate for some users where overdrive is used (S-PVA, cPVA generations mostly) | Response time still slow compared with TN Film and IPS offerings.
No support for native 120Hz+ refresh rates
Off-centre contrast shift inherent to all PVA panel generations. Not ideal for colour critical work
No 10-bit panels available | 8ms G2G response time (in practice mostly much slower)
16.7m colour depth through 8-bit panels mostly, some 6-bit+FRC used
| IPS | In Plane Switching | Early IPS panels designed for colour enthusiasts
S-IPS improved response times somewhat. Contrast ratio still an issue
H-IPS changed pixel structure, improved response times with overdrive, contrast ratio improved
e-IPS and other variants of H-IPS helped drive down production costs and make IPS more mainstream
p-IPS developed to offer 10-bit colour depth support
AH-IPS is current generation being produced
Alternative IPS-like technologies introduced by Samsung (PLS) and AU Optronics (AHVA) to compete.
Contrast 850:1< | Viewing angles are widest of the technologies. Reduced contrast and colour shift. Freedom from off-centre contrast shift seen from VA matrices
Response times of modern generations now very good, better than VA
10-bit panels available | No support for native 120Hz+ refresh rates
Older variants criticised for grainy AG coating
Distracting white glow from an angle when viewing dark content (IPS glow) | 5ms G2G response time (in practice a little slower)
1000:1 contrast ratio (typically achieving 800 - 1000:1 now)
178/178 viewing angles (mostly realistic)
16.7m colour depth common through 8-bit panels mostly, some 6-bit+FRC used
1.07b colour support available from 8-bit+FRC and 10-bit panels
Many older panels have grainy AG coating
Lighter AG coating used on most modern AH-IPS panels |
| LCD matrix |
Значи VA е "моята" матрица :) щом реагира по-бързо се надявам на бързи кадри по-малко да замазва. След това заключение по метода на изключването дилемата се стеснява до Самсунг 6410 или Панасоник 640.
Този белият 6410..половинката ти ли го избра? :) питам защото жените си падат по беличко, розовичко....
Doshisha - Vivid color 23-inch LCD TV models | AkihabaraNews
Хаха да, на нея цвета и хареса повече а на мен стойката. Не че това е от голямо значение , но при еднакви праметри... и това играе роля.
Между другото мисля че има още една разлика - 6410 има тунер за сателитна телевизия.
Чудно ми е, кой българин е допълнил последният линк от тази статия в уикипедия..
Sharp Aquos - Wikipedia, the free encyclopedia
Smart TV 2015
Забележки:
Android OS няма да се прилага във всички серии на Philips и Sony TV(Sony ще намалят сериите в модели 2015).
Новата WebOS 2.0 изглежда ще се приложи само в горните серии на LG TV 2015.
Същото ще важи и за новата OS на Panasonic.
LG webOS | webOS TV, Tablet, Phone Forum
SDK Download(Software development kit) - Samsung Smart TV Apps Developer Forum
::: LG Developer | webOS TV :::
Import your bookmarks to Symbaloo
https://internet.sony.tv/customer/
https://wiki.mozilla.org/FirefoxOS/S...idget_Approach
http://forum.xda-developers.com/andr...id-tv-t2935545
Как да инсталираме приложение на нашият Philips Android TV
1. Устанавяваме на тв от плеймаркета Developer Tools
2. Влизаме в Developers settings и поставяме чавка на "Отладка по USB". В никакъв случай не поставяйте чавка на "Show more apps in Google Play"!!! Това ще доведе до закритие на достъпа от вашият акаунт. Лекува се с връщане на завдскоте настройки на тв и презареждане.
3. Сваляме и установяваме на компютъра JDK
http://www.oracle.com/technetwork/java/javase/downlo…oads-2133151.html
4. Сваляме и устанавяваме на компютъра Android studio. Свалих си го от тук
http://developer.android.com/sdk/index.html.
5. Намираме папка platform-tools, при мен беше тук C:\Users\Andrii\AppData\Local\Android\sdk и за удобство я копираме в ядрото на диск C (не е задължително, но в режим команден ред така е по-удобно)
6. Трябва в в уиндоус да отредактирате системните переменные. Тук
http://www.4tablet-pc.net/reviews-a-articles/143-pro…-system-user.html в п.3 описано как да се направи
7. Запускаем в винде режим командной строки и преминаваме в папка platform-tools
8. Пишем команда adb connect айпи адреса на телевизора. Може да го видите в настройките на тв Мрежа->преглед на параметрите на мрежата. Ако всичко е направено правилно, то трябва да се появи надпис connected to айпи телевизора:5555
9. После нужният apk файл копираме в папка platform-tools и го установяваме на тв, с команда adb install название файла.apk
Привет на всички отново!
Подавам обратна информация - от вчера в хола се нанесе един нов Самсунг 40Н7000! На първо четене всичко е ок, само сега предстои заиграване с настройките му. Свързването към интернета на виваком стана без проблем. Само дето нещо не ми е активен браузъра...:confused: Искам да благодаря на всички взели отношение по моите въпроси! :thumbupСъщо много полезно е нещото, прочетено тук, но не помня на кого беше поста-с други думи да се опитаме да спечелим служител от магазина на наша страна. От опит да ви кажа има полза! Жената, с която говорих няколко пъти в ТП излезе голям 'пич' и 'угаждаше' на всичките ми 'прищевки'. Успех на всички избиращи нов тв!
от колко метра ще ги гледаш тези 40". Иначе поздрави, един от най-добрите тв тази година.
Красимир Камарев
вземай самсуняка няма какво да му мислиш. Тази година H6400 серия е идеален от към цена/качество.
hristoslav2
мачове,филми и музика(концерти)от лаптопа,Булсат тв,
Вчера в Технополис харесах това LG 40UB800V и ще помоля за отзиви за него. Има ли смисъл от Ultra HD на тези 40"? Телевизорът ще се използва най-вече за гледане на ТВ (Булсат), филми от флашка или PC, от време на време футбол - от около 2,5 м. 3Д не ми е приоритет, смарт функциите също, но то май няма как да се избяга от тях...
Извинявам се, сега видях, че питането ми е за друга тема, ще го пусна там :oops:
JacksonSoloist
Ами 3м и по-малко...май ще е според зависи. по принцип казват да е по-голям диагонал за такова разстояние, но при мен играят много фактори. И мерси :Drinks:надявам се всеки да направи избор, който да го удовлетворява.
drew
След прочитането на другата тема си модифицирам въпроса - LG-то отпада - търсенето ми е за 40"-42" - с панел препоръчително 100 Hz, 3D и смарт не ме интересуват, както казах по-горе - ще се използва за ТВ, филми от флашка или PC. Бюджет - 1000 лв.
Благодаря за предложенията! 40AS640E и аз го загледах, че е с много добра цена онлайн.
А на Sony 40W605 каква му е реалната честота на панела?
